#include "cs_config.h"#include "cs_defs.h"#include <math.h>#include <string.h>#include <time.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_map.h"#include "cs_timer.h"#include "cs_time_plot.h"#include "cs_timer_stats.h"
Include dependency graph for cs_timer_stats.cpp:Macros | |
| #define | _POSIX_C_SOURCE 200112L |
| void | cs_timer_stats_initialize (void) |
| Initialize timer statistics handling. More... | |
| void | cs_timer_stats_finalize (void) |
| Finalize timer statistics handling. More... | |
| void | cs_timer_stats_set_start_time (int time_id) |
| Set a start time for time stats. More... | |
| void | cs_timer_stats_set_plot_options (cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime) |
| Set global timer statistics plot options. More... | |
| void | cs_timer_stats_increment_time_step (void) |
| Increment time step for timer statistics. More... | |
| int | cs_timer_stats_create (const char *parent_name, const char *name, const char *label) |
| Create a timer statistics structure. More... | |
| int | cs_timer_stats_id_by_name (const char *name) |
| Return the id of a defined statistic based on its name. More... | |
| void | cs_timer_stats_set_plot (int id, int plot) |
| Enable or disable plotting for a timer statistic. More... | |
| int | cs_timer_stats_is_active (int id) |
| indicate if a timer for a given statistic is currently active. More... | |
| void | cs_timer_stats_start (int id) |
| Start a timer for a given statistic. More... | |
| void | cs_timer_stats_stop (int id) |
| Stop a timer for a given statistic. More... | |
| int | cs_timer_stats_switch (int id) |
| Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More... | |
| void | cs_timer_stats_add_diff (int id, const cs_timer_t *t0, const cs_timer_t *t1) |
| Add a timing range to an inactive timer. More... | |
| void | cs_timer_stats_define_defaults (void) |
| Define default timer statistics. More... | |
Application timer statistics and graphs.
These statistics are intended to provide a synthetic view of the relative costs of various operations and stages, and are defined as sets of trees so as to allow a form of grouping.
This logic does not replace having specific timers for operators, which allow for more detail, but more difficult to provide an overview for. Timer statistics also allow for incrementing results from base timers (in addition to starting/stopping their own timers), so they may be used to assist logging and plotting of other timers.
| #define _POSIX_C_SOURCE 200112L |
| void cs_timer_stats_add_diff | ( | int | id, |
| const cs_timer_t * | t0, | ||
| const cs_timer_t * | t1 | ||
This does not modify parent timers, so consistency of active and inactive timers must be ensured by the caller.
| [in] | id | id of statistic |
| [in] | t0 | oldest timer value |
| [in] | t1 | most recent timer value |
| int cs_timer_stats_create | ( | const char * | parent_name, |
| const char * | name, | ||
| const char * | label | ||
| [in] | parent_name | name of parent statistic, or nullptr |
| [in] | name | associated canonical name |
| [in] | label | associated label, or nullptr |
| void cs_timer_stats_define_defaults | ( | void | ) |
This creates 2 statistic timer trees, whose roots ids are:
| void cs_timer_stats_finalize | ( | void | ) |
| int cs_timer_stats_id_by_name | ( | const char * | name | ) |
If no timer with the given name exists, -1 is returned.
| [in] | name | statitic name |
| void cs_timer_stats_increment_time_step | ( | void | ) |
| void cs_timer_stats_initialize | ( | void | ) |
| int cs_timer_stats_is_active | ( | int | id | ) |
| void cs_timer_stats_set_plot | ( | int | id, |
| int | plot | ||
By default plotting is enabled for all statistics, except root statistic 1 (as it measures the same total time as root 0, with a different subtree).
This function is only effective before the first call to cs_timer_stats_increment_time_step.
| [in] | plot | 0 to disable, 1 to enable |
| void cs_timer_stats_set_plot_options | ( | cs_time_plot_format_t | format, |
| int | frequency, | ||
| int | n_buffer_steps, | ||
| double | flush_wtime | ||
| [in] | format | associated file format |
| [in] | frequency | plot every n time steps |
| [in] | n_buffer_steps | number of time steps in output buffer if file is not to be kept open |
| [in] | flush_wtime | elapsed time interval between file flushes (if < 0, no forced flush) |
| void cs_timer_stats_set_start_time | ( | int | time_id | ) |
This is useful to shift the time id for restarts. This function must not be called after cs_timer_stats_increment_time_step.
| [in] | time_id | associated starting time id |
| void cs_timer_stats_start | ( | int | id | ) |
Parents of the current statistic are also started, if not active.
If a timer with the same root but different parents is active, we assume the current operation is a subset of the active timer, so the timer is not started, so as to avoid having a sum of parts larger than the total.
| void cs_timer_stats_stop | ( | int | id | ) |
Children of the current statistic are also stopped, if active.
| int cs_timer_stats_switch | ( | int | id | ) |
| [in] | id | id of statistic with same root |
