8.3
cs_coolprop.hxx
1#ifndef __CS_COOLPROP_HXX__
2#define __CS_COOLPROP_HXX__
5 * Equation of state
35 * Local headers
40#include "cs_base.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Local Macro Definitions
49
51 * Structure definition
53
54/*============================================================================
55 * Global variables definition
57
58/*============================================================================
59 * Public function prototypes
60 *============================================================================*/
61
62/*----------------------------------------------------------------------------*/
78/*----------------------------------------------------------------------------*/
79
80void
81cs_phys_prop_coolprop(char *coolprop_material,
82 const char *coolprop_backend,
84 cs_phys_prop_type_t property,
85 const cs_lnum_t n_vals,
86 const cs_real_t var1[],
87 const cs_real_t var2[],
88 cs_real_t val[]);
89
90/*----------------------------------------------------------------------------*/
95
96void
98
100
102
103#endif /* __CS_COOLPROP_HXX__ */
104
void cs_coolprop_finalize(void)
Free state for Coolprop plugin.
Definition: cs_coolprop.cxx:360
void cs_phys_prop_coolprop(char *coolprop_material, const char *coolprop_backend, cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_coolprop.cxx:112
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
Definition: cs_physical_properties.h:42
cs_phys_prop_type_t
Definition: cs_physical_properties.h:54
