1#ifndef __CS_VOLUME_ZONE_H__
2#define __CS_VOLUME_ZONE_H__
61#define CS_VOLUME_ZONE_INITIALIZATION (1 << 0)
64#define CS_VOLUME_ZONE_POROSITY (1 << 1)
67#define CS_VOLUME_ZONE_HEAD_LOSS (1 << 2)
70#define CS_VOLUME_ZONE_SOURCE_TERM (1 << 3)
73#define CS_VOLUME_ZONE_MASS_SOURCE_TERM (1 << 4)
76#define CS_VOLUME_ZONE_GWF_SOIL (1 << 5)
79#define CS_VOLUME_ZONE_SOLID (1 << 6)
82#define CS_VOLUME_ZONE_PHYSICAL_PROPERTIES (1 << 7)
167 const char *criteria,
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void() cs_mesh_location_select_t(void *input, const cs_mesh_t *m, int location_id, cs_lnum_t *n_elts, cs_lnum_t **elt_ids)
Definition: cs_mesh_location.h:110
int cs_volume_zone_n_zones_time_varying(void)
Return number of volume zones which may vary in time.
Definition: cs_volume_zone.cpp:442
void cs_volume_zone_tag_cell_type(int zone_type_flag, int tag_value, int tag[])
Tag cells of a given zone type.
Definition: cs_volume_zone.cpp:1041
void cs_volume_zone_finalize(void)
Free all volume zone structures.
Definition: cs_volume_zone.cpp:404
void cs_volume_zone_set_type(int id, int type_flag)
Set type flag for a given volume zone.
Definition: cs_volume_zone.cpp:756
int cs_volume_zone_id_by_name(const char *z_name)
Retrieve the volume zone id from its zone name. If the zone name is equal to NULL or has an empty len...
Definition: cs_volume_zone.cpp:727
void cs_volume_zone_set_time_varying(int id, bool time_varying)
Set time varying behavior for a given volume zone.
Definition: cs_volume_zone.cpp:774
cs_lnum_t cs_volume_zone_n_type_cells(int type_flag)
Return number of volume zone cells associated with a given zone flag.
Definition: cs_volume_zone.cpp:974
const int * cs_volume_zone_cell_zone_id(void)
Return pointer to zone id associated with each cell.
Definition: cs_volume_zone.cpp:810
int cs_volume_zone_define(const char *name, const char *criteria, int type_flag)
Define a new volume zone using a selection criteria string.
Definition: cs_volume_zone.cpp:574
const cs_zone_t * cs_volume_zone_by_name_try(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.cpp:703
void cs_volume_zone_initialize(void)
Initialize volume zone structures.
Definition: cs_volume_zone.cpp:378
const cs_zone_t * cs_volume_zone_by_id(int id)
Return a pointer to a volume zone based on its id.
Definition: cs_volume_zone.cpp:653
int cs_volume_zone_n_type_zones(int type_flag)
Return number of volume zones associated with a given zone flag.
Definition: cs_volume_zone.cpp:947
void cs_volume_zone_log_info(const cs_zone_t *z)
Print info relative to a given volume zone to log file.
Definition: cs_volume_zone.cpp:824
int cs_volume_zone_define_by_func(const char *name, cs_mesh_location_select_t *func, void *input, int type_flag)
Define a new mesh location with an associated selection function.
Definition: cs_volume_zone.cpp:618
void cs_volume_zone_log_setup(void)
Log setup information relative to defined volume zones.
Definition: cs_volume_zone.cpp:921
void cs_volume_zone_select_type_cells(int type_flag, cs_lnum_t cell_ids[])
Select cells associated with volume zones of a given type.
Definition: cs_volume_zone.cpp:1000
void cs_volume_zone_set_overlay(int id, bool allow_overlay)
Set overlay behavior for a given volume zone.
Definition: cs_volume_zone.cpp:792
int cs_volume_zone_n_zones(void)
Return number of volume zones defined.
Definition: cs_volume_zone.cpp:428
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Definition: cs_volume_zone.cpp:677
void cs_volume_zone_print_info(void)
Print volume zones information to listing file.
Definition: cs_volume_zone.cpp:1071
void cs_volume_zone_build_all(bool mesh_modified)
Update association of volume zones with a mesh.
Definition: cs_volume_zone.cpp:465
