| int | cs_mesh_location_n_locations (void) |
| | Return number of mesh locations defined. More...
| void | cs_mesh_location_initialize (void) |
| | Initialize mesh location API. More...
| void | cs_mesh_location_finalize (void) |
| | Finalize mesh location API. More...
| int | cs_mesh_location_get_id_by_name (const char *ref_name) |
| | Find the related location id from the location name. More...
| void | cs_mesh_location_build (cs_mesh_t *mesh, int id) |
| | Associate mesh locations with a mesh. More...
| int | cs_mesh_location_add (const char *name, cs_mesh_location_type_t type, const char *criteria) |
| | Define a new mesh location. More...
| int | cs_mesh_location_add_by_func (const char *name, cs_mesh_location_type_t type, cs_mesh_location_select_t *func, void *input) |
| | Define a new mesh location with an associated selection function. More...
| int | cs_mesh_location_add_by_union (const char *name, cs_mesh_location_type_t type, int n_ml_ids, const int *ml_ids, bool complement) |
| const char * | cs_mesh_location_get_name (int id) |
| | Get a mesh location's name. More...
| cs_mesh_location_type_t | cs_mesh_location_get_type (int id) |
| | Get a mesh location's type. More...
| const cs_lnum_t * | cs_mesh_location_get_n_elts (int id) |
| | Get a mesh location's number of elements. More...
| const cs_lnum_t * | cs_mesh_location_get_elt_list (int id) |
| | Get a mesh location's elements list, if present. More...
| const cs_lnum_t * | cs_mesh_location_get_elt_ids_try (int id) |
| | Get a mesh location's element ids, if present. More...
| const cs_lnum_t * | cs_mesh_location_get_elt_ids (int id) |
| | Get a mesh location's element ids. More...
| cs_mesh_location_def_t | cs_mesh_location_get_definition_method (int id) |
| | Get a mesh location's definition method. More...
| const char * | cs_mesh_location_get_selection_string (int id) |
| | Get a mesh location's selection criteria string. More...
| cs_mesh_location_select_t * | cs_mesh_location_get_selection_function (int id) |
| | Get a mesh location's selection function pointer. More...
| int | cs_mesh_location_get_n_sub_ids (int id) |
| | Get a mesh location's number of sub ids. More...
| int * | cs_mesh_location_get_sub_ids (int id) |
| | Get a mesh location's list of sub ids. More...
| bool | cs_mesh_location_is_complement (int id) |
| | Check if a mesh location is built as a complement of other mesh locations. More...
| bool | cs_mesh_location_get_explicit_ids (int id) |
| | Check if cs_mesh_location_get_elt_ids always returns explicit element ids for a given mesh location. More...
| void | cs_mesh_location_set_explicit_ids (int id, bool explicit_elt_ids) |
| | Set behavior of cs_mesh_location_get_elt_ids for a given mesh location and locations based on it. More...
- Parameters
| [in] | name | name of location to define |
| [in] | type | type of location to define |
| [in] | func | pointer to selection function for associated elements, or NULL |
| [in,out] | input | pointer to optional (untyped) value or structure. |
- Returns
- id of newly defined created mesh location
- Parameters
| [in] | func | pointer to selection function for associated elements, or nullptr |
- Returns
| void cs_mesh_location_build |
cs_mesh_t * |
mesh, |
int |
id |
If mesh_id is negative, all defined mesh locations are associated (which is useful for the common case where only one mesh is present). If mesh_id is non-negative, only the location with the matching id is associated (which may be useful when multiple meshes are defined).
The number of elements are computed based on the underlying mesh, and element lists are built for mesh subset locations.
- Parameters
| [in] | mesh | pointer to associated mesh structure |
| [in] | id | id of mesh location |
| const cs_lnum_t * cs_mesh_location_get_elt_ids_try |
int |
id | ) |
An array of element ids is returned if the location is a subset of a main main location type, and nullptr is returned when the id array would map to the identity function (i.e. {0, 1, 2, ..., n_elts-1}).
- Parameters
- Returns
- pointer to elements array (0 to n-1 numbering).
| void cs_mesh_location_initialize |
void |
By default, 7 mesh locations are built, matching the 7 first values of the cs_mesh_location_type_t enum: CS_MESH_LOCATION_NONE for global values, CS_MESH_LOCATION_CELLS for the cells of the (default) global mesh, CS_MESH_LOCATION_INTERIOR_FACES and CS_MESH_LOCATION_BOUNDARY_FACES for its faces, and CS_MESH_LOCATION_VERTICES for its vertices. CS_MESH_LOCATION_FACES and a placeholder for CS_MESH_LOCATION_EDGES are also added for CDO discretizations.
Locations should then be built once the global mesh is complete, and its halo structures completed.
