8.3
cs_paramedmem_remapper.h
1#ifndef __CS_PARAMEDMEM_REMAPPER_HXX__
2#define __CS_PARAMEDMEM_REMAPPER_HXX__
5 * Parallel interpolation using ParaMEDMEM OverlapDEC
28/*----------------------------------------------------------------------------
29 * Local headers
30 *----------------------------------------------------------------------------*/
32#include "cs_defs.h"
34/*----------------------------------------------------------------------------*/
38typedef struct _cs_paramedmem_remapper_t cs_paramedmem_remapper_t;
53/*----------------------------------------------------------------------------*/
54
57 const char *sel_criteria,
58 char *file_name,
59 char *mesh_name,
60 cs_real_t center[3],
61 cs_real_t radius);
62
63/*----------------------------------------------------------------------------*/
71/*----------------------------------------------------------------------------*/
72
75
76/*----------------------------------------------------------------------------*/
97/*----------------------------------------------------------------------------*/
98
101 char *field_name,
102 cs_real_t default_val,
103 int time_choice,
104 double tval);
105
106/*----------------------------------------------------------------------------*/
118/*----------------------------------------------------------------------------*/
119
120cs_real_t *
122 char *field_name,
123 cs_real_t default_val,
124 int dt,
125 int it);
126
127/*----------------------------------------------------------------------------*/
134/*----------------------------------------------------------------------------*/
135
136void
138 cs_real_t translation[3]);
139
140/*----------------------------------------------------------------------------*/
149/*----------------------------------------------------------------------------*/
150
151void
153 cs_real_t invariant[3],
154 cs_real_t axis[3],
155 cs_real_t angle);
156
157/*----------------------------------------------------------------------------*/
161/*----------------------------------------------------------------------------*/
162
163void
165
166/*----------------------------------------------------------------------------*/
167
169
170#endif /* __CS_PARAMEDMEM_REMAPPER_HXX__ */
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
@ dt
cs_real_t * cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval)
Interpolate a given field on the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:708
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_paramedmem_remapper.cxx:554
cs_real_t * cs_paramedmem_remap_field_one_time(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it)
Remaps a field from the med file to the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:593
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create(char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius)
Creates a new cs_paramedmem_remapper_t instance.
Definition: cs_paramedmem_remapper.cxx:496
void cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition: cs_paramedmem_remapper.cxx:836
void cs_paramedmem_remapper_destroy_all(void)
Destroy all remappers.
Definition: cs_paramedmem_remapper.cxx:868
void cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_paramedmem_remapper.cxx:804
Definition: cs_paramedmem_remapper.h:38
