1#ifndef __CS_RENUMBER_H__
2#define __CS_RENUMBER_H__
175 bool halo_adjacent_faces_last,
207 bool *halo_adjacent_faces_last,
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void cs_renumber_mesh(cs_mesh_t *mesh)
Renumber mesh elements for vectorization or threading depending on code options and target machine.
Definition: cs_renumber.cpp:5892
void cs_renumber_get_min_subset_size(cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size)
Get the minimum sunset sizes when renumbering for threads.
Definition: cs_renumber.cpp:5773
void cs_renumber_set_n_threads(int n_threads)
Set the target number of threads for mesh renumbering.
Definition: cs_renumber.cpp:5713
void cs_renumber_b_faces(cs_mesh_t *mesh)
Renumber boundary faces for vectorization or threading depending on code options and target machine.
Definition: cs_renumber.cpp:6059
cs_renumber_i_faces_type_t
Definition: cs_renumber.h:64
@ CS_RENUMBER_I_FACES_MULTIPASS
Definition: cs_renumber.h:67
@ CS_RENUMBER_I_FACES_SIMD
Definition: cs_renumber.h:68
@ CS_RENUMBER_I_FACES_BLOCK
Definition: cs_renumber.h:66
@ CS_RENUMBER_I_FACES_NONE
Definition: cs_renumber.h:69
void cs_renumber_set_algorithm(bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering)
Select the algorithm for mesh renumbering.
Definition: cs_renumber.cpp:5803
void cs_renumber_b_faces_select_ignore(cs_mesh_t *mesh, cs_lnum_t n_faces, const cs_lnum_t face_ids[])
Renumber boundary faces such that selected faces appear last and will be ignored.
Definition: cs_renumber.cpp:6145
void cs_renumber_i_faces_by_gnum(cs_mesh_t *mesh)
Definition: cs_renumber.cpp:6023
Definition: cs_renumber.h:91
@ CS_RENUMBER_ADJACENT_LOW
Definition: cs_renumber.h:93
@ CS_RENUMBER_ADJACENT_HIGH
Definition: cs_renumber.h:94
Definition: cs_renumber.h:51
@ CS_RENUMBER_CELLS_METIS_PART
Definition: cs_renumber.h:55
@ CS_RENUMBER_CELLS_SCOTCH_PART
Definition: cs_renumber.h:53
@ CS_RENUMBER_CELLS_RCM
Definition: cs_renumber.h:59
@ CS_RENUMBER_CELLS_NONE
Definition: cs_renumber.h:60
@ CS_RENUMBER_CELLS_MORTON
Definition: cs_renumber.h:57
@ CS_RENUMBER_CELLS_METIS_ORDER
Definition: cs_renumber.h:56
@ CS_RENUMBER_CELLS_HILBERT
Definition: cs_renumber.h:58
@ CS_RENUMBER_CELLS_SCOTCH_ORDER
Definition: cs_renumber.h:54
Definition: cs_renumber.h:81
@ CS_RENUMBER_VERTICES_BY_FACE_ADJ
Definition: cs_renumber.h:84
@ CS_RENUMBER_VERTICES_BY_CELL_ADJ
Definition: cs_renumber.h:83
@ CS_RENUMBER_VERTICES_NONE
Definition: cs_renumber.h:85
Definition: cs_renumber.h:73
@ CS_RENUMBER_B_FACES_THREAD
Definition: cs_renumber.h:75
@ CS_RENUMBER_B_FACES_NONE
Definition: cs_renumber.h:77
@ CS_RENUMBER_B_FACES_SIMD
Definition: cs_renumber.h:76
void cs_renumber_b_faces_by_gnum(cs_mesh_t *mesh)
Definition: cs_renumber.cpp:6105
void cs_renumber_cells(cs_mesh_t *mesh)
Renumber cells depending on code options and target machine.
Definition: cs_renumber.cpp:5927
void cs_renumber_get_algorithm(bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering)
Return the algorithms for mesh renumbering.
Definition: cs_renumber.cpp:5846
void cs_renumber_set_min_subset_size(cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size)
Set the minimum sunset sizes when renumbering for threads.
Definition: cs_renumber.cpp:5754
int cs_renumber_get_n_threads(void)
Return the target number of threads for mesh renumbering.
Definition: cs_renumber.cpp:5734
void cs_renumber_vertices(cs_mesh_t *mesh)
Renumber vertices depending on code options and target machine.
Definition: cs_renumber.cpp:6295
void cs_renumber_i_faces(cs_mesh_t *mesh)
Renumber interior faces for vectorization or threading depending on code options and target machine.
Definition: cs_renumber.cpp:5977
