#include <math.h>#include <string.h>#include <stdlib.h>#include <assert.h>#include <stdio.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_file.h"#include "cs_file_csv_parser.h"
Include dependency graph for cs_file_csv_parser.cpp:Macros | |
| #define | CS_MAX_STR_SIZE 65535 / sizeof(char) |
| static char * | _get_token (const char *str1, const char *str2) |
| Get a token based on the difference between two strings (beginning) More... | |
| static char ** | _parse_line (char *line, const char *separator, int *n_tokens, bool keep_missing_tokens) |
| Parse a line using a given separator and returns the tokens. More... | |
| static int | _check_if_line_is_empty (char *line) |
| Check if a line is empty. More... | |
| static int | _count_lines_in_file (const char *file_name) |
| Count the number of lines in the file. More... | |
| char *** | cs_file_csv_parse (const char *file_name, const char *separator, const int n_headers, const int n_columns, const int *col_idx, const bool ignore_missing_tokens, int *n_rows, int *n_cols) |
| Parse a csv file and export to a dataset (char ***). More... | |
| #define CS_MAX_STR_SIZE 65535 / sizeof(char) |
static |
| [in] | line | text line read from file to check |
static |
| [in] | file_name | Name of the file to open |
static |
| [in] | str1 | Longest string which should contain the token at its beginning |
| [in] | str2 | Shortest string. If null treated as 0 length string. |
static |
| [in] | line | line to parse (char *) |
| [in] | separator | separator (int) |
| [in,out] | n_tokens | number of tokens |
| [in] | keep_missing_tokens | true or false |
| char *** cs_file_csv_parse | ( | const char * | file_name, |
| const char * | separator, | ||
| const int | n_headers, | ||
| const int | n_columns, | ||
| const int * | col_idx, | ||
| const bool | ignore_missing_tokens, | ||
| int * | n_rows, | ||
| int * | n_cols | ||
The caller is responsible for freeing the dataset when not needed anymore.
| [in] | file_name | Name of the file to read |
| [in] | separator | Separator (int) |
| [in] | n_headers | Number of headers (to ignore during import) |
| [in] | n_columns | Number of columns to read. -1 if all columns are to be read |
| [in] | col_idx | Array of indices of columns to read (if n_columns != -1) |
| [in] | ignore_missing_tokens | Ignore missing tokens (nullptr) |
| [in] | n_rows | Pointer to number of rows in file |
| [in] | n_cols | Pointer to number of columns in file |
