Include dependency graph for cs_mass_source_terms.h:Go to the source code of this file.
| void | cs_mass_source_terms (int iterns, int dim, cs_lnum_t ncesmp, const cs_lnum_t icetsm[], int itpsmp[], const cs_real_t volume[], const cs_real_t pvara[], const cs_real_t smcelp[], const cs_real_t gamma[], cs_real_t st_exp[], cs_real_t st_imp[], cs_real_t gapinj[]) |
| Implicit and explicit mass source terms computation. More... | |
| void cs_mass_source_terms | ( | int | iterns, |
| int | dim, | ||
| cs_lnum_t | n_elts, | ||
| const cs_lnum_t | elt_ids[], | ||
| int | mst_type[], | ||
| const cs_real_t | volume[], | ||
| const cs_real_t | pvara[], | ||
| const cs_real_t | mst_val[], | ||
| const cs_real_t | gamma[], | ||
| cs_real_t | st_exp[], | ||
| cs_real_t | st_imp[], | ||
| cs_real_t | gapinj[] | ||
Arrays st_exp, st_imp, and gapinj are incremented, so should be initialized.
| [in] | iterns | iteration number on Navier-Stoke |
| [in] | dim | associated field dimension |
| [in] | n_elts | number of cells with mass source term |
| [in] | elt_ids | source mass cells pointer (1-based numbering) |
| [in] | mst_type | mass source type for the working variable |
| [in] | volume | cells volume |
| [in] | pvara | variable value at time step beginning |
| [in] | mst_val | value of the variable associated with mass source |
| [in] | gamma | volume mass injection value |
| [in,out] | st_exp | explicit source term part linear in the variable |
| [in,out] | st_imp | associated value with tsexp to be stored in the matrix |
| [in,out] | gapinj | explicit source term part independent of the variable |
