struct | cs_pressure_correction_cdo_t |
void | cs_pressure_correction_fv_activate (void) |
Activate the pressure increment solving with Legacy FV. More... | |
void | cs_pressure_correction_cdo_destroy_all (void) |
Free the main structure related to the pressure correction. More... | |
void | cs_pressure_correction_cdo_activate (void) |
Activate the pressure increment solving with CDO. More... | |
void | cs_pressure_correction_model_activate (void) |
Activate the pressure increment, either FV or CDO. More... | |
bool | cs_pressure_correction_cdo_is_activated (void) |
Test if pressure solving with CDO is activated. More... | |
void | cs_pressure_correction_cdo_init_setup (void) |
Start setting-up the pressure increment equation At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More... | |
void | cs_pressure_correction_cdo_finalize_setup (const cs_domain_t *domain) |
Finalize setting-up the pressure increment equation At this stage, numerical settings should be completely determined. More... | |
void | cs_pressure_correction (int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[], cs_lnum_t ltmast[], const int isostd[], cs_real_t vel[][3], cs_real_t da_uu[][6], cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_dp, cs_real_t spcond[], cs_real_t svcond[], cs_real_t frcxt[][3], cs_real_t dfrcxt[][3], cs_real_t i_visc[], cs_real_t b_visc[]) |
Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly compressible flows. More... | |
void cs_pressure_correction | ( | int | iterns, |
cs_lnum_t | nfbpcd, | ||
cs_lnum_t | ncmast, | ||
cs_lnum_t | ifbpcd[], | ||
cs_lnum_t | ltmast[], | ||
const int | isostd[], | ||
cs_real_t | vel[][3], | ||
cs_real_t | da_uu[][6], | ||
cs_field_bc_coeffs_t * | bc_coeffs_v, | ||
cs_field_bc_coeffs_t * | bc_coeffs_dp, | ||
cs_real_t | spcond[], | ||
cs_real_t | svcond[], | ||
cs_real_t | frcxt[][3], | ||
cs_real_t | dfrcxt[][3], | ||
cs_real_t | i_visc[], | ||
cs_real_t | b_visc[] | ||
Either the legacy FV method or a CDO face-based scheme is used.
For the legacy case, the mass flux is updated as follows:
[in] | iterns | Navier-Stokes iteration number |
[in] | nfbpcd | number of faces with condensation source term |
[in] | ncmast | number of cells with condensation source terms |
[in] | ifbpcd | index of faces with condensation source term |
[in] | ltmast | list of cells with condensation source terms (1 to n numbering) |
[in] | isostd | indicator of standard outlet and index of the reference outlet face |
[in] | vel | velocity |
[in,out] | da_uu | velocity matrix |
[in] | bc_coeffs_v | boundary condition structure for the variable |
[in] | bc_coeffs_dp | boundary conditions structure for the pressure increment |
[in] | spcond | variable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate ![]() |
[in] | svcond | variable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate ![]() |
[in] | frcxt | external forces making hydrostatic pressure |
[in] | dfrcxt | variation of the external forces composing the hydrostatic pressure |
[in] | i_visc | visc*surface/dist aux faces internes |
[in] | b_visc | visc*surface/dist aux faces de bord |
void cs_pressure_correction_cdo_activate | ( | void | ) |
void cs_pressure_correction_cdo_destroy_all | ( | void | ) |
void cs_pressure_correction_cdo_finalize_setup | ( | const cs_domain_t * | domain | ) |
[in] | domain | pointer to a cs_domaint_t structure |
void cs_pressure_correction_cdo_init_setup | ( | void | ) |
bool cs_pressure_correction_cdo_is_activated | ( | void | ) |
void cs_pressure_correction_fv_activate | ( | void | ) |
void cs_pressure_correction_model_activate | ( | void | ) |
