Include dependency graph for cs_volume_mass_injection.h:Go to the source code of this file.
| void | cs_volume_mass_injection_flag_zones (void) |
| Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. More... | |
| void | cs_volume_mass_injection_build_lists (void) |
| Build the list and zone ids of cells with volume mass injection. More... | |
| void | cs_volume_mass_injection_eval (void) |
| Evaluate contributions to volume mass injection. More... | |
| void | cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *ncesmp, const cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma) |
| Return pointers to the mass source term arrays. More... | |
| void cs_volume_mass_injection_build_lists | ( | void | ) |
| void cs_volume_mass_injection_eval | ( | void | ) |
| void cs_volume_mass_injection_flag_zones | ( | void | ) |
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
| void cs_volume_mass_injection_get_arrays | ( | const cs_field_t * | f, |
| cs_lnum_t * | n_elts, | ||
| const cs_lnum_t ** | elt_ids, | ||
| int ** | mst_type, | ||
| cs_real_t ** | mst_val, | ||
| cs_real_t ** | gamma | ||
| [in] | f | pointer to associated field |
| [out] | ncesmp | number of cells with mass source terms |
| [out] | icetsm | pointet to source mass cells list (1-based numbering) |
| [out] | itpsmp | mass source type for the working variable |
| [out] | s_type | mass source types (0: ambient value, 1: s_val value) |
| [out] | smcelp | pointer to mass source values |
| [out] | gamma | pointer to flow mass value |
| [out] | n_elts | number of cells with mass source terms |
| [out] | elt_ids | pointer to source mass cells list (1-based numbering)//FIXME |
| [out] | mst_type | mass source types (0: ambient value, 1: s_val value) |
| [out] | mst_val | pointer to mass source values |
