struct | cs_cfd2sys_intersection_t |
struct | cs_cfd_sys_cplbc_t |
struct | cs_sys_cpl_t |
Enumerations | |
enum | cs_syscpl_bc_type_t { CS_SYS_CPL_BC_INLET , CS_SYS_CPL_BC_OUTLET , CS_SYS_CPL_BC_WALL , CS_SYS_CPL_BC_VOLUME , CS_N_SYS_CPL_BC_TYPES , CS_SYS_CPL_BC_UKNOWN } |
cs_sys_cpl_t * | cs_sys_coupling_by_id (const int cpl_id) |
Get a cfd<-->sys coupling structure by its id. More... | |
cs_sys_cpl_t * | cs_sys_coupling_by_name_try (const char *sys_name) |
Try getting a cfd<-->sys coupling structure by its name. More... | |
cs_sys_cpl_t * | cs_sys_coupling_by_name (const char *sys_name) |
Get a cfd<-->sys coupling structure by its name. More... | |
void | cs_sys_cplbc_add_field_to_send (cs_cfd_sys_cplbc_t *cplbc, const int field_id) |
Add a field to send during coupling to a given coupled BC. More... | |
void | cs_sys_cplbc_add_field_to_recv (cs_cfd_sys_cplbc_t *cplbc, const int field_id) |
Add a field to recieve during coupling to a given coupled BC. More... | |
void | cs_sys_cplbc_define_surf_coeff (cs_cfd_sys_cplbc_t *cplbc, const cs_real_t coeff) |
Define a surface coefficient to a given coupled BC. More... | |
void | cs_sys_cplbc_inverse_bnd_dir (cs_cfd_sys_cplbc_t *cplbc) |
Define a flowrate inversion between CFD and System codes if signs are inversed for a given coupled BC. More... | |
void | cs_sys_cplbc_add_exchanged_field (cs_cfd_sys_cplbc_t *cplbc, const int dir, const int field_id) |
Add a field to send/recv during coupling to a given coupled BC. More... | |
void | cs_sys_coupling_add_cplbc (cs_sys_cpl_t *sys_coupling, cs_syscpl_bc_type_t type, const cs_zone_t *z_input, const char *sel_criteria_output, const char *element_name, const int c0, const int c1, const int n_sys_elts) |
Add a coupled condition to a cfd<-->sys coupling. More... | |
int | cs_sys_coupling_add (const char *sys_name, const int n_cpl_phases) |
Add a cfd<->sys coupling. More... | |
void | cs_sys_coupling_send_data (cs_sys_cpl_t *cpl) |
send data to system code More... | |
void | cs_sys_coupling_recv_data (cs_sys_cpl_t *cpl) |
recieve data from system code More... | |
void | cs_sys_coupling_all_init (void) |
Initialize cfd<->system coupling once all couplings are defined. More... | |
void | cs_sys_coupling_all_finalize (void) |
Finalize all cfd<->sys couplings. More... | |
enum cs_syscpl_bc_type_t |
int cs_sys_coupling_add | ( | const char * | sys_name, |
const int | n_cpl_phases | ||
[in] | sys_name | name of the new coupling |
[in] | n_cpl_phases | number of phases to coupled |
void cs_sys_coupling_add_cplbc | ( | cs_sys_cpl_t * | sys_coupling, |
cs_syscpl_bc_type_t | type, | ||
const cs_zone_t * | z_input, | ||
const char * | sel_criteria_output, | ||
const char * | element_name, | ||
const int | c0, | ||
const int | c1, | ||
const int | n_sys_elts | ||
[in] | sys_coupling | pointer to cfd<->sys coupling |
[in] | type | type of coupled condition |
[in] | z_input | coupled zone (boundary or volume) |
[in] | sel_criteria_output | selection criteria for cfd->sys data selection |
[in] | element_name | name of coupled sys element |
[in] | c0 | first sys cell index |
[in] | c1 | second sys cell index |
[in] | n_sys_elts | number of coupled cells in the system code |
void cs_sys_coupling_all_finalize | ( | void | ) |
void cs_sys_coupling_all_init | ( | void | ) |
cs_sys_cpl_t * cs_sys_coupling_by_id | ( | const int | cpl_id | ) |
[in] | cpl_id | id of the requested coupling |
cs_sys_cpl_t * cs_sys_coupling_by_name | ( | const char * | sys_name | ) |
[in] | sys_name | name of the requested coupling |
cs_sys_cpl_t * cs_sys_coupling_by_name_try | ( | const char * | sys_name | ) |
void cs_sys_coupling_recv_data | ( | cs_sys_cpl_t * | cpl | ) |
[in] | cpl | pointer to coupling structure. |
void cs_sys_coupling_send_data | ( | cs_sys_cpl_t * | cpl | ) |
void cs_sys_cplbc_add_exchanged_field | ( | cs_cfd_sys_cplbc_t * | cplbc, |
const int | dir, | ||
const int | field_id | ||
[in] | cplbc | pointer to coupled condition |
[in] | dir | 0 send; 1 recv |
[in] | field_id | id of the field to exchange |
void cs_sys_cplbc_add_field_to_recv | ( | cs_cfd_sys_cplbc_t * | cplbc, |
[in] | field_id | id of the field to recieve |
void cs_sys_cplbc_add_field_to_send | ( | cs_cfd_sys_cplbc_t * | cplbc, |
[in] | field_id | id of the field to send |
void cs_sys_cplbc_define_surf_coeff | ( | cs_cfd_sys_cplbc_t * | cplbc, |
const cs_real_t | coeff | ||
[in] | coeff | surface coefficient to apply |
void cs_sys_cplbc_inverse_bnd_dir | ( | cs_cfd_sys_cplbc_t * | cplbc | ) |
