8.3
cs_boundary.h File Reference
+ Include dependency graph for cs_boundary.h:
Data Structures
struct  cs_boundary_t
 Structure storing information related to the "physical" boundaries associated with the computational domain. More...
Macros
#define CS_BOUNDARY_PRESSURE_NO_RESCALING   1
#define CS_BOUNDARY_PRESSURE_RESCALING   0
#define CS_BOUNDARY_WALLS_NAME   "auto:wall"
#define CS_BOUNDARY_UNDEFINED   0
Typedefs
typedef int cs_boundary_type_t
Enumerations
enum  cs_boundary_category_t { CS_BOUNDARY_CATEGORY_FLOW , CS_BOUNDARY_CATEGORY_ALE , CS_BOUNDARY_CATEGORY_RADIATIVE }
enum  cs_boundary_flow_subtype_bits_t {
  CS_BOUNDARY_WALL = 1<<0 , CS_BOUNDARY_INLET = 1<<1 , CS_BOUNDARY_OUTLET = 1<<2 , CS_BOUNDARY_SYMMETRY = 1<<3 ,
  CS_BOUNDARY_ROUGH_WALL = 1<<4 , CS_BOUNDARY_SLIDING_WALL = 1<<5 , CS_BOUNDARY_IMPOSED_VEL = 1<<6 , CS_BOUNDARY_IMPOSED_P = 1<<7 ,
  CS_BOUNDARY_FREE_INLET_OUTLET = 1<<8 , CS_BOUNDARY_CONVECTIVE_INLET = 1<<9 , CS_BOUNDARY_INLET_QH = 1<<10 , CS_BOUNDARY_INLET_SUBSONIC_PH = 1<<11 ,
  CS_BOUNDARY_SUBSONIC = 1<<12 , CS_BOUNDARY_SUPERSONIC = 1<<13 , CS_BOUNDARY_FREE_SURFACE = 1<<14 , CS_BOUNDARY_COUPLED = 1<<15 ,
  CS_BOUNDARY_COUPLED_DF = 1<<16
enum  cs_boundary_ale_subtype_bits_t {
  CS_BOUNDARY_ALE_FIXED = 1<<0 , CS_BOUNDARY_ALE_SLIDING = 1<<1 , CS_BOUNDARY_ALE_IMPOSED_VEL = 1<<2 , CS_BOUNDARY_ALE_IMPOSED_DISP = 1<<3 ,
  CS_BOUNDARY_ALE_INTERNAL_COUPLING = 1<<4 , CS_BOUNDARY_ALE_EXTERNAL_COUPLING = 1<<5 , CS_BOUNDARY_ALE_FREE_SURFACE = 1<<6
bool cs_boundary_has_type (const cs_boundary_t *boundaries, int type_flag)
 Check if a boundary with a given flag is present. More...
int cs_boundary_id_by_zone_id (const cs_boundary_t *boundaries, int z_id)
 Retrieve the related id associated to a boundary from its zone id. More...
void cs_boundary_set_default (cs_boundary_t *boundaries, cs_boundary_type_t type)
 Set the default boundary related to the given cs_boundary_t structure. More...
cs_boundary_tcs_boundary_create (cs_boundary_category_t category, cs_boundary_type_t default_type)
 Create a default boundary structure for the computational domain. More...
void cs_boundary_free (cs_boundary_t **p_boundaries)
 Free all metadate related to the domain boundaries. More...
void cs_boundary_add (cs_boundary_t *bdy, cs_boundary_type_t type, const char *zone_name)
 Add a new boundary type for a given boundary zone. More...
void cs_boundary_build_type_array (const cs_boundary_t *boundaries, cs_lnum_t n_b_faces, cs_boundary_type_t bf_type[])
 Build an array on boundary faces which specifies the boundary type for each face. More...
void cs_boundary_def_wall_zones (cs_boundary_t *boundaries)
 Add a new zone gathering all CS_BOUNDARY_WALL type zones. More...
int cs_boundary_need_pressure_rescaling (cs_lnum_t n_b_faces, const cs_boundary_type_t bf_type[])
 Check if one needs to perform a pressure rescaling (in case of a Dirichlet on the velocity for the whole boundary) Use in CDO schemes for Navier–Stokes. More...
void cs_boundary_get_type_descr (const cs_boundary_t *bdy, cs_boundary_type_t b_type, int descr_len_max, char descr[])
 Build a boundary type description. More...
void cs_boundary_log_setup (const cs_boundary_t *bdy)
 Summarize the setup of the boundary of the computational domain. More...
cs_boundary_tcs_glob_boundaries
◆ CS_BOUNDARY_PRESSURE_NO_RESCALING
◆ CS_BOUNDARY_PRESSURE_RESCALING
◆ CS_BOUNDARY_UNDEFINED
◆ CS_BOUNDARY_WALLS_NAME
Typedef Documentation
◆ cs_boundary_type_t
Flag values defining boundary condition subtypes (0 for none)
◆ cs_boundary_ale_subtype_bits_t
Enumerator
fixed
sliding
imposed velocity
imposed displacement
internal coupling
external coupling
free surface
◆ cs_boundary_category_t
Enumerator
◆ cs_boundary_flow_subtype_bits_t
Enumerator
CS_BOUNDARY_WALL
wall
CS_BOUNDARY_INLET
inlet
CS_BOUNDARY_OUTLET
outlet
symmetry
rough wall
sliding wall
imposed velocity
imposed pressure
free inlet-outlet
convective inlet
compressible inlet, imposed flux and enthalpy
compressible (subsonic) inlet, imposed pressure and enthalpy
compressible subsonic
compressible supersonic
free surface
CS_BOUNDARY_COUPLED
coupled
coupled with decentered flux
◆ cs_boundary_add()
void cs_boundary_add ( cs_boundary_t bdy,
const char *  zone_name
[in,out]bdypointer to a structure storing boundary info
[in]typetype of boundary to set
[in]zone_namename of the zone related to this boundary
◆ cs_boundary_build_type_array()
void cs_boundary_build_type_array ( const cs_boundary_t boundaries,
[in]boundariespointer to the domain boundaries
[in]n_b_facesnumber of boundaries faces
[in,out]bf_typeboundary type flag
[in,out]bf_typearray to define the type of boundary
◆ cs_boundary_create()
cs_boundary_t * cs_boundary_create ( cs_boundary_category_t  category,
[in]categorydefault type of boundary to set
[in]default_typedefault type of boundary to set
a pointer to the new allocated structure
◆ cs_boundary_def_wall_zones()
void cs_boundary_def_wall_zones ( cs_boundary_t boundaries)
[in,out]boundariespointer to the domain boundaries
◆ cs_boundary_free()
void cs_boundary_free ( cs_boundary_t **  p_boundaries)
[in,out]p_boundariespointer to the structure to free
◆ cs_boundary_get_type_descr()
void cs_boundary_get_type_descr ( const cs_boundary_t bdy,
int  descr_len_max,
char  descr[]
[in]bdypointer to a structure storing boundary info
[in]b_typetype flag
[in]descr_len_maxmaximum name length
[out]descrsubtype name
◆ cs_boundary_has_type()
bool cs_boundary_has_type ( const cs_boundary_t boundaries,
int  type_flag
[in]boundariespointer to a cs_boundary_t structure
[in]type_flagboundary type flag
true or false
◆ cs_boundary_id_by_zone_id()
int cs_boundary_id_by_zone_id ( const cs_boundary_t boundaries,
int  z_id
[in]z_idid of the related zone
the associated boundary id in the boundary list
◆ cs_boundary_log_setup()
void cs_boundary_log_setup ( const cs_boundary_t bdy)
◆ cs_boundary_need_pressure_rescaling()
int cs_boundary_need_pressure_rescaling ( cs_lnum_t  n_b_faces,
[in]n_b_facesnumber of border faces
[in]bf_typearray of types of boundary for each boundary face
1 if a pressure rescaling is needed otherwise 0
CS_BOUNDARY_PRESSURE_RESCALING (=0) or CS_BOUNDARY_PRESSURE_NO_RESCALING (=1)
◆ cs_boundary_set_default()
void cs_boundary_set_default ( cs_boundary_t boundaries,
[in,out]boundariespointer to a structure storing boundary info
◆ cs_glob_boundaries
cs_boundary_t* cs_glob_boundaries
extern
