1#ifndef __CS_FUNCTION_DEFAULT_H__
2#define __CS_FUNCTION_DEFAULT_H__
Definition: cs_defs.h:542
Definition: cs_defs.h:543
Definition: cs_defs.h:335
cs_function_t * cs_function_define_property_cells(char *property_name)
Define output function of a property (which is not a field).
Definition: cs_function_default.cpp:1751
cs_function_t * cs_function_define_boundary_thermal_flux(void)
Define function object for computation of boundary thermal flux.
Definition: cs_function_default.cpp:888
cs_function_t * cs_function_define_boundary_stress(void)
Define function object for computation of boundary stress.
Definition: cs_function_default.cpp:786
void cs_function_default_define(void)
Define functions based on code_saturne case setup.
Definition: cs_function_default.cpp:629
cs_function_t * cs_function_define_q_criterion(void)
Define function for computation of cell Q criterion.
Definition: cs_function_default.cpp:1002
cs_function_t * cs_function_define_mpi_rank_id(cs_mesh_location_type_t location_id)
Create or access a function for evaluation of element's MPI rank id.
Definition: cs_function_default.cpp:668
void cs_function_q_criterion(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute the Q-criterion from Hunt et. al over each cell of a specified volume region.
Definition: cs_function_default.cpp:1708
void cs_function_boundary_stress_normal(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute normal stress at boundary.
Definition: cs_function_default.cpp:1296
cs_function_t * cs_function_define_refinement_generation(cs_mesh_location_type_t location_id)
Create or access a function for evaluation of mesh element's refinement generation (i....
Definition: cs_function_default.cpp:731
cs_function_t * cs_function_define_boundary_stress_tangential(void)
Define function object for computation of tangential boundary stress.
Definition: cs_function_default.cpp:854
void cs_function_boundary_thermal_flux(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute thermal flux at boundary (in ),.
Definition: cs_function_default.cpp:1414
cs_function_t * cs_function_define_boundary_nusselt(void)
Define function for computation of boundary layer Nusselt.
Definition: cs_function_default.cpp:942
void cs_function_class_or_zone_id(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Extract optional boundary face class of element zone id.
Definition: cs_function_default.cpp:1044
void cs_function_boundary_stress(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute stress at boundary.
Definition: cs_function_default.cpp:1244
cs_function_t * cs_function_define_boundary_stress_normal(void)
Define function object for computation of normal boundary stress.
Definition: cs_function_default.cpp:820
void cs_function_field_boundary_nr(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute non-reconstructed cell-based field values at boundary.
Definition: cs_function_default.cpp:1094
cs_function_predefined_t
Definition: cs_function_default.h:51
@ CS_FUNCTION_CELL_RANK_ID
Definition: cs_function_default.h:53
@ CS_FUNCTION_B_FACE_RANK_ID
Definition: cs_function_default.h:54
void cs_function_boundary_nusselt(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute local Nusselt number near boundary.
Definition: cs_function_default.cpp:1483
void cs_function_boundary_stress_tangential(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Compute tangential stress at boundary.
Definition: cs_function_default.cpp:1352
Definition: cs_mesh_location.h:60
Definition: cs_function.h:121
