Files | |
| file | cs_advection_field.c |
| file | cs_advection_field.h [code] |
| file | cs_basis_func.c |
| file | cs_basis_func.h [code] |
| file | cs_cdo_advection.c |
| Build discrete advection operators for CDO vertex-based schemes. | |
| file | cs_cdo_advection.h [code] |
| file | cs_cdo_bc.c |
| file | cs_cdo_bc.h [code] |
| file | cs_cdo_connect.c |
| Build additional connectivities (or adjacencies) useful for building CDO or HHO schemes. | |
| file | cs_cdo_connect.h [code] |
| file | cs_cdo_diffusion.c |
| Build discrete stiffness matrices and handled boundary conditions for diffusion term in CDO vertex-based and vertex+cell schemes. | |
| file | cs_cdo_diffusion.h [code] |
| file | cs_cdo_headers.h [code] |
| file | cs_cdo_local.c |
| Routines to handle low-level actions related to CDO local quantities: | |
| file | cs_cdo_local.h [code] |
| file | cs_cdo_main.c |
| file | cs_cdo_main.h [code] |
| file | cs_cdo_quantities.c |
| file | cs_cdo_quantities.h [code] |
| file | cs_cdo_time.c |
| file | cs_cdo_time.h [code] |
| file | cs_cdofb_ac.c |
| Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with an artificial compressibility algorithm. | |
| file | cs_cdofb_ac.h [code] |
| file | cs_cdofb_monolithic.c |
| Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a monolithic approach. | |
| file | cs_cdofb_monolithic.h [code] |
| file | cs_cdofb_navsto.c |
| Shared routines among all face-based schemes for building and solving Stokes and Navier-Stokes problem. | |
| file | cs_cdofb_navsto.h [code] |
| file | cs_cdofb_predco.c |
| Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a prediction/correction algorithm. A first equation related to the velocity prediction is solved and then a second equation related to the pressure correction is solved to project the velocity field into the space of divergence-free field. | |
| file | cs_cdofb_predco.h [code] |
| file | cs_cdofb_priv.h [code] |
| file | cs_cdofb_scaleq.c |
| Build an algebraic CDO face-based system for unsteady convection-diffusion-reaction of scalar-valued equations with source terms. | |
| file | cs_cdofb_scaleq.h [code] |
| file | cs_cdofb_uzawa.c |
| Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with an Augmented Lagrangian-Uzawa algorithm. | |
| file | cs_cdofb_uzawa.h [code] |
| file | cs_cdofb_vecteq.c |
| file | cs_cdofb_vecteq.h [code] |
| file | cs_cdovb_priv.h [code] |
| Structures for building an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction equations with source terms. | |
| file | cs_cdovb_scaleq.c |
| Build an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction of scalar-valued equations with source terms. | |
| file | cs_cdovb_scaleq.h [code] |
| file | cs_cdovb_vecteq.c |
| Build an algebraic CDO vertex-based system for unsteady convection-diffusion-reaction of vector-valued equations with source terms. | |
| file | cs_cdovb_vecteq.h [code] |
| file | cs_cdovcb_scaleq.c |
| Build an algebraic CDO vertex+cell-based system for unsteady convection diffusion reaction of scalar-valued equations with source terms. | |
| file | cs_cdovcb_scaleq.h [code] |
| file | cs_dbg.c |
| file | cs_dbg.h [code] |
| file | cs_domain.c |
| Manage a computational domain. | |
| file | cs_domain.h [code] |
| file | cs_domain_op.c |
| file | cs_domain_op.h [code] |
| file | cs_domain_setup.c |
| Routines to handle the setup of a computational domain High level interface for handling the computation. | |
| file | cs_domain_setup.h [code] |
| file | cs_equation.c |
| file | cs_equation.h [code] |
| file | cs_equation_assemble.c |
| Assembly of local cellwise system into a cs_matrix_t structure through the cs_matrix_assembler_t and its related structures. | |
| file | cs_equation_assemble.h [code] |
| file | cs_equation_bc.c |
| file | cs_equation_bc.h [code] |
| file | cs_equation_common.c |
| file | cs_equation_common.h [code] |
| file | cs_equation_param.c |
| file | cs_equation_param.h [code] |
| Structure and routines handling the specific settings related to a cs_equation_t structure. | |
| file | cs_equation_priv.h [code] |
| file | cs_evaluate.c |
| file | cs_evaluate.h [code] |
| file | cs_flag.c |
| file | cs_flag.h [code] |
| file | cs_gwf.c |
| Main functions dedicated to groundwater flows when using CDO schemes. | |
| file | cs_gwf.h [code] |
| file | cs_gwf_soil.c |
| Main functions dedicated to soil management in groundwater flows when using CDO schemes. | |
| file | cs_gwf_soil.h [code] |
| file | cs_gwf_tracer.c |
| file | cs_gwf_tracer.h [code] |
| file | cs_hho_builder.c |
| file | cs_hho_builder.h [code] |
| file | cs_hho_scaleq.c |
| file | cs_hho_scaleq.h [code] |
| file | cs_hho_stokes.c |
| file | cs_hho_stokes.h [code] |
| file | cs_hho_vecteq.c |
| file | cs_hho_vecteq.h [code] |
| file | cs_hodge.c |
| Build discrete Hodge operators. | |
| file | cs_hodge.h [code] |
| file | cs_mesh_deform.c |
| file | cs_mesh_deform.h [code] |
| file | cs_navsto_coupling.c |
| Routines to handle the settings of coupling algorithms. | |
| file | cs_navsto_coupling.h [code] |
| Routines to handle structures used as a context when solving the Navier-Stokes equations. Structures are cast on-the-fly according to the type of coupling. Routines to handle the settings of coupling algorithms. | |
| file | cs_navsto_param.c |
| file | cs_navsto_param.h [code] |
| file | cs_navsto_system.c |
| Routines to handle the cs_navsto_system_t structure. | |
| file | cs_navsto_system.h [code] |
| file | cs_param.c |
| file | cs_param.h [code] |
| file | cs_param_cdo.c |
| file | cs_param_cdo.h [code] |
| file | cs_property.c |
| file | cs_property.h [code] |
| file | cs_quadrature.c |
| file | cs_quadrature.h [code] |
| file | cs_reco.c |
| file | cs_reco.h [code] |
| file | cs_scheme_geometry.c |
| file | cs_scheme_geometry.h [code] |
| file | cs_sdm.c |
| file | cs_sdm.h [code] |
| file | cs_source_term.c |
| file | cs_source_term.h [code] |
| file | cs_static_condensation.c |
| file | cs_static_condensation.h [code] |
| file | cs_walldistance.c |
| file | cs_walldistance.h [code] |
| file | cs_xdef.c |
| file | cs_xdef.h [code] |
| file | cs_xdef_cw_eval.c |
| file | cs_xdef_cw_eval.h [code] |
| file | cs_xdef_eval.c |
| file | cs_xdef_eval.h [code] |
