Build discrete stiffness matrices and handled boundary conditions for diffusion term in CDO vertex-based and vertex+cell schemes. More...
#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <assert.h>#include <math.h>#include <bft_mem.h>#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_property.h"#include "cs_reco.h"#include "cs_scheme_geometry.h"#include "cs_cdo_diffusion.h"
| void | cs_cdo_diffusion_pena_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement by a penalization technique with a huge value. More... | |
| void | cs_cdo_diffusion_pena_block_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement by a penalization technique with a huge value. Case of a cellwise system defined by block. More... | |
| void | cs_cdo_diffusion_alge_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by keeping the DoFs related to Dirichlet BCs in the algebraic system (i.e. a weak enforcement) The corresponding DoFs are algebraically "removed" of the system. More... | |
| void | cs_cdo_diffusion_alge_block_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by keeping the DoFs related to Dirichlet BCs in the algebraic system (i.e. a weak enforcement) The corresponding DoFs are algebraically "removed" of the system Block version. More... | |
| void | cs_cdo_diffusion_sfb_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of scalar-valued CDO Face-based schemes. More... | |
| void | cs_cdo_diffusion_vfb_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of vector-valued CDO Face-based schemes The idea is to compute the scalar version and dispatch it three times, one for each Cartesian components. More... | |
| void | cs_cdo_diffusion_sfb_wsym_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment Case of scalar-valued CDO Face-based schemes. More... | |
| void | cs_cdo_diffusion_vfb_wsym_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. Case of vector-valued CDO Face-based schemes The idea is to compute the scalar version and dispatch it three times, one for each Cartesian components. More... | |
| void | cs_cdo_diffusion_vfb_wsym_sliding (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account sliding BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. Case of vector-valued CDO Face-based schemes. More... | |
| void | cs_cdo_diffusion_svb_cost_robin (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Robin BCs. Case of scalar-valued CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_svb_cost_generic (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account generic BCs by a weak enforcement using Nitsche technique. According to the settings one can apply Neumann BCs if alpha = 0, Dirichlet BCs if alpha >> 1 or Robin BCs Case of scalar-valued CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_svb_cost_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_vvb_cost_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. A Dirichlet is set for the three components of the vector. Case of vector-valued CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_vvb_cost_sliding (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account a sliding BCs. Case of vector-valued CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_svb_cost_wsym_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. Case of CDO-Vb schemes with a CO+ST algorithm. More... | |
| void | cs_cdo_diffusion_svb_wbs_robin (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Robin BCs. Case of scalar-valued CDO-Vb schemes with a WBS algorithm. More... | |
| void | cs_cdo_diffusion_svb_wbs_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of CDO-Vb schemes with a WBS algorithm. More... | |
| void | cs_cdo_diffusion_svb_wbs_wsym_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. Case of CDO-Vb schemes with a WBS algorithm. More... | |
| void | cs_cdo_diffusion_vcb_weak_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique. Case of CDO-VCb schemes with a WBS algorithm. More... | |
| void | cs_cdo_diffusion_vcb_wsym_dirichlet (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. Case of CDO-VCb schemes with a WBS algorithm. More... | |
| void | cs_cdo_diffusion_svb_cost_get_dfbyc_flux (const cs_cell_mesh_t *cm, const double *pot, cs_cell_builder_t *cb, double *flx) |
| Compute the diffusive flux across dual faces for a given cell The discrete Hodge operator has been previously computed using a COST algorithm. This function is dedicated to vertex-based schemes. Flux = -Hdg * GRAD(pot) More... | |
| void | cs_cdo_diffusion_svb_cost_get_cell_flux (const cs_cell_mesh_t *cm, const double *pot, cs_cell_builder_t *cb, double *flx) |
| Compute the constant approximation of the diffusive flux inside a (primal) cell. Use the CO+ST algo. for computing the discrete Hodge operator. This function is dedicated to vertex-based schemes. Flux = -Hdg * GRAD(pot) More... | |
| void | cs_cdo_diffusion_svb_cost_vbyf_flux (short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *flux) |
| Compute the normal flux for a face assuming only the knowledge of the potential at cell vertices. CO+ST algorithm is used for reconstructing the normal flux from the degrees of freedom. More... | |
| void | cs_cdo_diffusion_wbs_get_dfbyc_flux (const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *flx) |
| Compute the diffusive flux across dual faces for a given cell Use the WBS algo. for approximating the gradient The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}. More... | |
| void | cs_cdo_diffusion_wbs_get_cell_flux (const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *flx) |
| Compute the diffusive flux inside a given primal cell Use the WBS algo. for approximating the gradient The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}. More... | |
| void | cs_cdo_diffusion_wbs_vbyf_flux (short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *flux) |
| Compute the normal flux for a face assuming only the knowledge of the potential at cell vertices (and at cell center). WBS algorithm is used for reconstructing the normal flux from the degrees of freedom. More... | |
| double | cs_cdo_diffusion_wbs_face_flux (const cs_face_mesh_t *fm, const cs_real_t pty_tens[3][3], const double *p_v, const double p_f, const double p_c, cs_cell_builder_t *cb) |
| Compute the diffusive flux across a face (based on a subdivision into tetrahedra of the volume p_{f,c}) More... | |
| void | cs_cdo_diffusion_sfb_cost_flux (short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *flux) |
| Compute the normal diffusive flux for a face assuming only the knowledge of the potential at faces and cell. CO+ST algorithm is used for reconstructing the normal flux from the degrees of freedom. More... | |
| void | cs_cdovb_diffusion_p0_face_flux (const short int f, const cs_cell_mesh_t *cm, const cs_real_3_t *diff_tensor, const cs_real_t *pot_values, cs_real_t *fluxes) |
| Compute the normal flux for a face assuming only the knowledge of the potential at cell vertices. COST algorithm is used for reconstructing a piecewise constant gradient from the degrees of freedom. More... | |
| void cs_cdo_diffusion_alge_block_dirichlet | ( | const cs_equation_param_t * | eqp, |
| cs_face_mesh_t * | fm, | ||
| cs_cell_sys_t * | csys | ||
| | | | | | | | | | | Aii | Aid | | Aii | 0 | |bi| |bi-Aid.xd | |---------—| –> |---------—| and |–| –> |-------—| | | | | | | | | | | | Adi | Add | | 0 | Id | |bd| | xd |
where xd is the value of the Dirichlet BC
| [in,out] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | csys | structure storing the cell-wise system |
| void cs_cdo_diffusion_alge_dirichlet | ( | const cs_equation_param_t * | eqp, |
| | | | | | | | | | | Aii | Aid | | Aii | 0 | |bi| |bi-Aid.bd | |---------—| –> |---------—| and |–| –> |-------—| | | | | | | | | | | | Adi | Add | | 0 | Id | |bd| | xd |
| void cs_cdo_diffusion_pena_block_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_pena_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_sfb_cost_flux | ( | short int | f, |
| cs_real_t * | flux | ||
| [in] | f | face id in the cell mesh |
| [in] | pot | array of values of the potential (all the mesh) |
| [in,out] | cb | auxiliary structure dedicated to diffusion |
| [out] | flux | pointer to the value to set |
| void cs_cdo_diffusion_sfb_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| [in,out] | csys | structure storing the cellwise system |
| void cs_cdo_diffusion_sfb_wsym_dirichlet | ( | const cs_equation_param_t * | eqp, |
Take into account Dirichlet BCs by a weak enforcement using Nitsche technique plus a symmetric treatment - Face-based version Case of scalar-valued CDO Face-based schemes.
| void cs_cdo_diffusion_svb_cost_generic | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_cost_get_cell_flux | ( | const cs_cell_mesh_t * | cm, |
| const double * | pot, | ||
| double * | flx | ||
Compute the constant approximation of the diffusive flux inside a (primal) cell. Use the CO+ST algo. for computing the discrete Hodge op. This function is dedicated to vertex-based schemes. Flux = -Hdg * GRAD(pot)
| [in] | pot | values of the potential fields at specific locations |
| [in,out] | cb | auxiliary structure for computing the flux |
| [in,out] | flx | values of the flux inside the cell |
| void cs_cdo_diffusion_svb_cost_get_dfbyc_flux | ( | const cs_cell_mesh_t * | cm, |
| double * | flx | ||
| [in,out] | flx | values of the flux across specific entities |
| void cs_cdo_diffusion_svb_cost_robin | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_cost_vbyf_flux | ( | short int | f, |
| [in,out] | vf_flux | array of values to set (size: n_vc) |
| void cs_cdo_diffusion_svb_cost_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_cost_wsym_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_wbs_robin | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_wbs_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_svb_wbs_wsym_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vcb_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vcb_wsym_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vfb_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vfb_wsym_dirichlet | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vfb_wsym_sliding | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vvb_cost_sliding | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_diffusion_vvb_cost_weak_dirichlet | ( | const cs_equation_param_t * | eqp, |
| double cs_cdo_diffusion_wbs_face_flux | ( | const cs_face_mesh_t * | fm, |
| const cs_real_t | pty_tens[3][3], | ||
| const double * | p_v, | ||
| const double | p_f, | ||
| const double | p_c, | ||
| [in] | fm | pointer to a cs_face_mesh_t structure |
| [in] | pty_tens | 3x3 matrix related to the diffusion property |
| [in] | p_v | array of values attached to face vertices |
| [in] | p_f | value attached to the face |
| [in] | p_c | value attached to the cell |
| void cs_cdo_diffusion_wbs_get_cell_flux | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t * | flx | ||
| [in] | pot | values of the potential fields at vertices |
| [in,out] | flx | flux vector inside this cell |
| void cs_cdo_diffusion_wbs_get_dfbyc_flux | ( | const cs_cell_mesh_t * | cm, |
| [in,out] | flx | flux across dual faces inside this cell |
| void cs_cdo_diffusion_wbs_vbyf_flux | ( | short int | f, |
| void cs_cdovb_diffusion_p0_face_flux | ( | const short int | f, |
| const cs_real_3_t * | diff_tensor, | ||
| const cs_real_t * | pot_values, | ||
| cs_real_t * | fluxes | ||
| [in] | diff_tensor | property tensor times the face normal |
| [in] | pot_values | array of values of the potential (all the mesh) |
| [in,out] | fluxes | values of the fluxes related to each vertex |
