410 const double in_vals[],
void cs_hodge_compute_wbs_surfacic(const cs_face_mesh_t *fm, cs_sdm_t *hf)
Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney...
Definition: cs_hodge.c:2854
void cs_hodge_vb_voro_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc C...
Definition: cs_hodge.c:1384
void cs_hodge_vpcd_voro_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to d...
Definition: cs_hodge.c:2056
Definition: cs_defs.h:467
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:146
void cs_hodge_vb_cost_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc ...
Definition: cs_hodge.c:1164
Definition: cs_cdo_connect.h:74
void cs_hodge_fped_voro_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual...
Definition: cs_hodge.c:2247
void cs_hodge_matvec(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_param_hodge_t h_info, const cs_property_t *pty, const double in_vals[], cs_real_t t_eval, double result[])
Compute cellwise a discrete hodge operator and multiple it with a vector.
Definition: cs_hodge.c:2598
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
void cs_hodge_epfd_voro_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual...
Definition: cs_hodge.c:2105
void cs_hodge_vb_cost_get_iso_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. Case of CDO vertex-based schemes and isot...
Definition: cs_hodge.c:814
void cs_hodge_edfp_voro_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal...
Definition: cs_hodge.c:2382
Definition: cs_field_pointer.h:134
void cs_hodge_vpcd_wbs_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual ...
Definition: cs_hodge.c:1946
void cs_hodge_vb_wbs_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic WBS algo. WBS standing for Whitney Barycentric Subdi...
Definition: cs_hodge.c:1476
void cs_hodge_vcb_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Definition: cs_hodge.c:1610
void cs_hodge_vcb_wbs_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the WBS algo. This function is specific for verte...
Definition: cs_hodge.c:1830
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:56
void cs_hodge_epfd_cost_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dua...
Definition: cs_hodge.c:2166
void cs_hodge_edfp_cost_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to prima...
Definition: cs_hodge.c:2436
void cs_hodge_fb_cost_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Definition: cs_hodge.c:690
void cs_hodge_vb_cost_get_aniso_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. Case of CDO vertex-based schemes...
Definition: cs_hodge.c:989
void() cs_hodge_t(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local operator for a given cell (stored in cb->hdg for a discrete Hodge operator or in cb->lo...
Definition: cs_hodge.h:63
Definition: cs_defs.h:468
void cs_hodge_fb_get_mass(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes.
Definition: cs_hodge.c:1756
void cs_hodge_fped_cost_get(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dua...
Definition: cs_hodge.c:2301
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:212
void cs_hodge_edfp_cost_get_opt(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2517
void cs_hodge_fb_voro_get_stiffness(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Definition: cs_hodge.c:753
Definition: cs_param_cdo.h:129
Definition: cs_property.h:104
