bft_mem.h
1 #ifndef __BFT_MEM_H__
2 #define __BFT_MEM_H__
5  * Base memory allocation wrappers with optional tracing
30 #include "cs_defs.h"
34 /* BFT headers */
36 #include "bft_error.h"
38 /*-----------------------------------------------------------------------------*/
43  * Public types
45
47  * Public macros
49
50 /*
51  * Allocate memory for _ni items of type _type.
52  *
53  * This macro calls bft_mem_malloc(), automatically setting the
54  * allocated variable name and source file name and line arguments.
55  *
56  * parameters:
57  * _ptr --> pointer to allocated memory.
58  * _ni <-- number of items.
59  * _type <-- element type.
60  */
61
62 #define BFT_MALLOC(_ptr, _ni, _type) \
63 _ptr = (_type *) bft_mem_malloc(_ni, sizeof(_type), \
64  #_ptr, __FILE__, __LINE__)
65
66 /*
67  * Reallocate memory for _ni items of type _type.
68  *
69  * This macro calls bft_mem_realloc(), automatically setting the
70  * allocated variable name and source file name and line arguments.
71  *
72  * parameters:
73  * _ptr <-> pointer to allocated memory.
74  * _ni <-- number of items.
75  * _type <-- element type.
76  */
77
78 #define BFT_REALLOC(_ptr, _ni, _type) \
79 _ptr = (_type *) bft_mem_realloc(_ptr, _ni, sizeof(_type), \
80  #_ptr, __FILE__, __LINE__)
81
82 /*
83  * Free allocated memory.
84  *
85  * This macro calls bft_mem_free(), automatically setting the
86  * allocated variable name and source file name and line arguments.
87  *
88  * The freed pointer is set to NULL to avoid accidental reuse.
89  *
90  * parameters:
91  * _ptr <-> pointer to allocated memory.
92  */
93
94 #ifdef __cplusplus /* avoid casting from void for C++ */
95
96 #define BFT_FREE(_ptr) \
97 bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL
98
99 #else
100
101 #define BFT_FREE(_ptr) \
102 _ptr = bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__)
103
104 #endif /* __cplusplus */
105
106 /*
107  * Allocate aligned memory for _ni items of type _type.
108  *
109  * This macro calls bft_mem_memalign(), automatically setting the
110  * allocated variable name and source file name and line arguments.
111  *
112  * parameters:
113  * _ptr --> pointer to allocated memory.
114  * _align <-- alignment.
115  * _ni <-- number of items.
116  * _type <-- element type.
117  */
118
119 #define BFT_MEMALIGN(_ptr, _align, _ni, _type) \
120 _ptr = (_type *) bft_mem_memalign(_align, _ni, sizeof(_type), \
121  #_ptr, __FILE__, __LINE__)
122
123 /*============================================================================
124  * Public function prototypes
125  *============================================================================*/
126
127 /*
128  * Initialize memory handling.
129  *
130  * This function should be called before any other bft_mem_...()
131  * function. To activate memory allocation logging, a logfile
132  * name should be given as an argument. The resulting file will
133  * be a regular, local file. If this file cannot be opened for
134  * some reason, logging is silently de-activated.
135  *
136  * parameter:
137  * log_file_name <-- name of optional log_file (if NULL, no log).
138  */
139
140 void
141 bft_mem_init(const char *log_file_name);
142
143 /*
144  * End memory handling.
145  *
146  * This function should be called after all other bft_mem_...()
147  * functions. In case of memory allocation logging, it
148  * writes final information to the log file and closes is.
149  */
150
151 void
152 bft_mem_end(void);
153
154 /*
155  * Initialize memory handling.
156  *
157  * This function should be called before any other bft_mem_...()
158  * function. To activate memory allocation logging, a logfile
159  * name should be given as an argument. The resulting file will
160  * be a regular, local file. If this file cannot be opened for
161  * some reason, logging is silently de-activated.
162  *
163  * parameter:
164  * log_file_name <-- name of optional log_file (if NULL, no log).
165  */
166
167 /*
168  * Indicates if bft_mem_...() functions are initialized.
169  *
170  * returns:
171  * 1 if bft_mem_init has been called, 0 otherwise.
172  */
173
174 int
175 bft_mem_initialized(void);
176
177 /*
178  * Allocate memory for ni items of size bytes.
179  *
180  * This function calls malloc(), but adds tracing capabilities, and
181  * automatically calls the bft_error() errorhandler if it fails to
182  * allocate the required memory.
183  *
184  * parameters:
185  * ni <-- number of items.
186  * size <-- element size.
187  * var_name <-- allocated variable name string.
188  * file_name <-- name of calling source file.
189  * line_num <-- line number in calling source file.
190  *
191  * returns:
192  * pointer to allocated memory.
193  */
194
195 void *
196 bft_mem_malloc(size_t ni,
197  size_t size,
198  const char *var_name,
199  const char *file_name,
200  int line_num);
201
202 /*
203  * Reallocate memory for ni items of size bytes.
204  *
205  * This function calls realloc(), but adds tracing capabilities, and
206  * automatically calls the bft_error() errorhandler if it fails to
207  * allocate the required memory.
208  *
209  * parameters:
210  * ptr <-> pointer to previous memory location
211  * (if NULL, bft_alloc() called).
212  * ni <-- number of items.
213  * size <-- element size.
214  * var_name <-- allocated variable name string.
215  * file_name <-- name of calling source file.
216  * line_num -> line number in calling source file
217  *
218  * returns:
219  * pointer to allocated memory.
220  */
221
222 void *
223 bft_mem_realloc(void *ptr,
224  size_t ni,
225  size_t size,
226  const char *var_name,
227  const char *file_name,
228  int line_num);
229
230 /*
231  * Free allocated memory.
232  *
233  * This function calls free(), but adds tracing capabilities, and
234  * automatically calls the bft_error() errorhandler if it fails to
235  * free the corresponding memory. In case of a NULL pointer argument,
236  * the function simply returns.
237  *
238  * parameters:
239  * ptr <-> pointer to previous memory location
240  * (if NULL, bft_alloc() called).
241  * var_name <-- allocated variable name string.
242  * file_name <-- name of calling source file.
243  * line_num <-- line number in calling source file.
244  *
245  * returns:
246  * NULL pointer.
247  */
248
249 void *
250 bft_mem_free(void *ptr,
251  const char *var_name,
252  const char *file_name,
253  int line_num);
254
255 /*
256  * Allocate aligned memory for ni elements of size bytes.
257  *
258  * This function calls posix_memalign() if available, but adds tracing
259  * capabilities, and automatically calls the bft_error() errorhandler if
260  * it fails to allocate the required memory.
261  *
262  * The associated function bft_mem_have_memalign() indicates if this
263  * type of allocation may be used on this system.
264  *
265  * parameters:
266  * alignment <-- alignent.
267  * ni <-- number of items.
268  * size <-- element size.
269  * var_name <-- allocated variable name string.
270  * file_name <-- name of calling source file.
271  * line_num <-- line number in calling source file.
272  *
273  * returns:
274  * pointer to allocated memory.
275  */
276
277 void *
278 bft_mem_memalign(size_t alignment,
279  size_t ni,
280  size_t size,
281  const char *var_name,
282  const char *file_name,
283  int line_num);
284
291 size_t
293
300 size_t
301 bft_mem_size_max(void);
302
303 /*
304  * Indicate if a memory aligned allocation variant is available.
305  *
306  * If no such function is available, bft_mem_memalign() will always fail.
307  *
308  * returns:
309  * 1 if memory aligned allocation is possible, 0 otherwise.
310  */
311
312 int
314
315 /* Returns the error handler associated with the bft_mem_...() functions.
316  *
317  * returns:
318  * pointer to the error handler function.
319  */
320
323
324 /*
325  * Associates an error handler with the bft_mem_...() functions.
326  *
327  * With the default error handler, an error message is output to stderr,
328  * (after bft_print_flush() is called), and the general error handler used
329  * by bft_error() is then called (which results in the termination of the
330  * current process or process group).
331  *
332  * parameter:
333  * handler <-- pointer to the error handler function.
334  */
335
336 void
338
339 /*----------------------------------------------------------------------------*/
340
342
343 #endif /* __BFT_MEM_H__ */
int bft_mem_have_memalign(void)
Definition: bft_mem.c:1201
size_t bft_mem_size_current(void)
Return current theoretical dynamic memory allocated.
Definition: bft_mem.c:1146
void bft_mem_end(void)
Definition: bft_mem.c:667
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory for ni elements of size bytes.
Definition: bft_mem.c:763
Definition: cs_defs.h:467
void() bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition: bft_error.h:52
void * bft_mem_memalign(size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:1051
void bft_mem_error_handler_set(bft_error_handler_t *handler)
Definition: bft_mem.c:1187
void bft_mem_init(const char *log_file_name)
Definition: bft_mem.c:590
void * bft_mem_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:978
Definition: cs_defs.h:468
int bft_mem_initialized(void)
Definition: bft_mem.c:741
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory for ni elements of size bytes.
Definition: bft_mem.c:847
bft_error_handler_t * bft_mem_error_handler_get(void)
Definition: bft_mem.c:1170
size_t bft_mem_size_max(void)
Return maximum theoretical dynamic memory allocated.
Definition: bft_mem.c:1158
