1 #ifndef __CS_PROPERTY_H__ 2 #define __CS_PROPERTY_H__ 55 #define CS_PROPERTY_POST_FOURIER (1 << 0) 297 static inline const char *
void cs_property_log_setup(void)
Print a summary of the settings for all defined cs_property_t structures.
Definition: cs_property.c:1361
cs_xdef_t * cs_property_def_by_array(cs_property_t *pty, cs_flag_t loc, cs_real_t *array, bool is_owner, cs_lnum_t *index)
Define a cs_property_t structure thanks to an array of values.
Definition: cs_property.c:864
void() cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) ...
Definition: cs_xdef_eval.h:66
#define restrict
Definition: cs_defs.h:127
void() cs_analytic_func_t(cs_real_t time, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *coords, bool compact, void *input, cs_real_t *retval)
Generic function pointer for an analytic function elt_ids is optional. If not NULL, it enables to access in coords at the right location and the same thing to fill retval if compact is set to false.
Definition: cs_param.h:66
cs_property_t * cs_property_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure.
Definition: cs_property.c:293
cs_property_t * cs_property_by_name(const char *name)
Find the related property definition from its name.
Definition: cs_property.c:336
#define CS_FLAG_STATE_UNIFORM
Definition: cs_flag.h:76
void cs_property_set_shared_pointers(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_property.c:259
Definition: cs_field.h:124
cs_xdef_t * cs_property_def_aniso_by_value(cs_property_t *pty, const char *zname, cs_real_t tens[3][3])
Define an anisotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:643
char *restrict name
Definition: cs_property.h:106
cs_property_type_t
Type of property to consider.
Definition: cs_property.h:93
Definition: cs_defs.h:467
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:146
void cs_property_destroy_all(void)
Free all cs_property_t structures and the array storing all the structures.
Definition: cs_property.c:412
int n_definitions
Definition: cs_property.h:116
int id
Definition: cs_property.h:107
Definition: cs_cdo_connect.h:74
cs_xdef_t * cs_property_def_ortho_by_value(cs_property_t *pty, const char *zname, double val[])
Define an orthotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:599
static cs_property_type_t cs_property_get_type(const cs_property_t *pty)
Retrieve the type of a property.
Definition: cs_property.h:317
void cs_property_finalize_setup(void)
Last stage of the definition of a property based on several definitions (i.e. definition by subdomain...
Definition: cs_property.c:451
void cs_property_def_by_field(cs_property_t *pty, cs_field_t *field)
Definition: cs_property.c:931
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
Definition: cs_property.h:72
cs_xdef_t * cs_property_def_iso_by_value(cs_property_t *pty, const char *zname, double val)
Define an isotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:555
cs_xdef_t * cs_property_def_by_func(cs_property_t *pty, const char *zname, void *context, cs_xdef_eval_t *get_eval_at_cell, cs_xdef_cw_eval_t *get_eval_at_cell_cw)
Define a cs_property_t structure thanks to law depending on one scalar variable in a subdomain attach...
Definition: cs_property.c:817
cs_flag_t process_flag
Definition: cs_property.h:109
Definition: cs_property.h:97
Definition: cs_property.h:113
cs_real_t cs_property_value_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval)
Compute the value of a property at the cell center Version using a cs_cell_mesh_t structure...
Definition: cs_property.c:1257
void cs_property_tensor_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, bool do_inversion, cs_real_3_t *tensor)
Compute the value of the tensor attached a property at the cell center Version using a cs_cell_mesh_t...
Definition: cs_property.c:1178
static const char * cs_property_get_name(const cs_property_t *pty)
Retrieve the name of a property.
Definition: cs_property.h:298
cs_real_t cs_property_get_cell_value(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty)
Compute the value of a property at the cell center.
Definition: cs_property.c:1126
void cs_property_eval_at_cells(cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
Evaluate the value of the property at each cell. Store the evaluation in the given array...
Definition: cs_property.c:987
cs_flag_t state_flag
Definition: cs_property.h:108
Definition: cs_xdef.h:126
cs_xdef_t * cs_property_def_by_time_func(cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
Define a cs_property_t structure thanks to an analytic function in a subdomain attached to the mesh l...
Definition: cs_property.c:696
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a ce...
Definition: cs_xdef_cw_eval.h:70
void cs_property_set_option(cs_property_t *pty, cs_property_key_t key)
Set optional parameters related to a cs_property_t structure.
Definition: cs_property.c:383
cs_xdef_t * cs_property_def_by_analytic(cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
Definition: cs_property.c:764
Definition: cs_defs.h:298
cs_xdef_cw_eval_t ** get_eval_at_cell_cw
Definition: cs_property.h:133
void cs_property_get_cell_tensor(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty, bool do_inversion, cs_real_3_t *tensor)
Compute the value of the tensor attached a property at the cell center.
Definition: cs_property.c:1026
void cs_property_get_fourier(const cs_property_t *pty, cs_real_t t_eval, double dt, cs_real_t fourier[])
Compute the Fourier number in each cell.
Definition: cs_property.c:1296
void() cs_time_func_t(int time_iter, double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the number of iteration already done...
Definition: cs_param.h:88
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
cs_property_t * cs_property_by_id(int id)
Find the related property definition from its id.
Definition: cs_property.c:363
Definition: cs_property.h:73
Definition: cs_property.h:95
short int * def_ids
Definition: cs_property.h:121
Definition: cs_property.h:96
cs_xdef_t ** defs
Definition: cs_property.h:117
Definition: cs_property.h:99
static bool cs_property_is_isotropic(const cs_property_t *pty)
returns true if the property is isotropic, otherwise false
Definition: cs_property.h:276
cs_property_key_t
List of available keys for setting options on a property.
Definition: cs_property.h:70
static bool cs_property_is_uniform(const cs_property_t *pty)
returns true if the property is uniform, otherwise false
Definition: cs_property.h:254
int cs_property_get_n_properties(void)
Retrieve the number of properties.
Definition: cs_property.c:276
Definition: cs_property.h:104
cs_xdef_eval_t ** get_eval_at_cell
Definition: cs_property.h:129
