#include <string.h>#include "cs_base.h"#include "cs_boundary_zone.h"#include "cs_param.h"#include "cs_quadrature.h"#include "cs_volume_zone.h"
| struct | cs_xdef_t |
| Structure storing medata for defining a quantity in a very flexible way. More... | |
| struct | cs_xdef_array_input_t |
| Input structure when an array is used for the definition. More... | |
| struct | cs_xdef_analytic_input_t |
| Input structure when an analytic function is used for the definition. More... | |
| struct | cs_xdef_time_func_input_t |
| Input structure when a time step function is used for the definition. More... | |
| static int | cs_get_vol_zone_id (const char *z_name) |
| Retrieve the volume zone if from the zone name (If name = NULL or has an empty length, all entities are selected) More... | |
| static int | cs_get_bdy_zone_id (const char *z_name) |
| Retrieve the boundary zone if from the zone name (If name = NULL or has an empty length, all entities are selected) More... | |
| cs_xdef_t * | cs_xdef_volume_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *input) |
| Allocate and initialize a new cs_xdef_t structure based on volumic elements. More... | |
| cs_xdef_t * | cs_xdef_boundary_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *input) |
| Allocate and initialize a new cs_xdef_t structure based on boundary elements. More... | |
| cs_xdef_t * | cs_xdef_timestep_create (cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *input) |
| Allocate and initialize a new cs_xdef_t structure for setting the time step. More... | |
| cs_xdef_t * | cs_xdef_free (cs_xdef_t *d) |
| Free a cs_xdef_t structure. More... | |
| cs_xdef_t * | cs_xdef_copy (cs_xdef_t *src) |
| copy a cs_xdef_t structure More... | |
| void | cs_xdef_set_array (cs_xdef_t *d, bool is_owner, cs_real_t *array) |
| In case of definition by array, set the array after having added this definition. More... | |
| void | cs_xdef_set_array_index (cs_xdef_t *d, cs_lnum_t *array_index) |
| In case of definition by array, set the index to get access to the array values. More... | |
| void | cs_xdef_set_quadrature (cs_xdef_t *d, cs_quadrature_type_t qtype) |
| Set the type of quadrature to use for evaluating the given description. More... | |
| cs_quadrature_type_t | cs_xdef_get_quadrature (cs_xdef_t *d) |
| Get the type of quadrature to use for evaluating the given description. More... | |
| cs_xdef_type_t | cs_xdef_get_type (const cs_xdef_t *d) |
| Retrieve the flag dedicated to the state. More... | |
| cs_flag_t | cs_xdef_get_state_flag (const cs_xdef_t *d) |
| void | cs_xdef_log (const char *prefix, const cs_xdef_t *d) |
| Output the settings related to a cs_xdef_t structure. More... | |
| enum cs_xdef_support_t |
| enum cs_xdef_type_t |
| Enumerator | |
| CS_XDEF_BY_ANALYTIC_FUNCTION | Definition relying on an analytic function (see cs_analytic_func_t) |
| CS_XDEF_BY_ARRAY | Definition based on an array |
| CS_XDEF_BY_FIELD | Definition based on a field (see cs_field_t) |
| CS_XDEF_BY_FUNCTION | Definition relying on a generic user-defined function. TODO |
| CS_XDEF_BY_QOV | QOV = Quantity Over a Volume Definition which enables to spread a given quantity inside a volume. Useful to initialized a tracer in a subdomain for instance. |
| CS_XDEF_BY_TIME_FUNCTION | Definition relying on a function for setting the time step (see cs_time_func_t) |
| CS_XDEF_BY_VALUE | Simple definition by a constant value |
| CS_N_XDEF_TYPES | |
inlinestatic |
| [in] | z_name | name of the zone |
inlinestatic |
| cs_xdef_t* cs_xdef_boundary_create | ( | cs_xdef_type_t | type, |
| int | dim, | ||
| int | z_id, | ||
| cs_flag_t | state, | ||
| cs_flag_t | meta, | ||
| void * | input | ||
| [in] | type | type of definition |
| [in] | dim | dimension of the values to define |
| [in] | z_id | volume zone id |
| [in] | state | flag to know if this uniform, cellwise, steady... |
| [in] | meta | metadata associated to this description |
| [in] | input | pointer to a structure |
| cs_quadrature_type_t cs_xdef_get_quadrature | ( | cs_xdef_t * | d | ) |
| [in] | d | pointer to a cs_xdef_t structure |
| cs_xdef_type_t cs_xdef_get_type | ( | const cs_xdef_t * | d | ) |
| void cs_xdef_log | ( | const char * | prefix, |
| const cs_xdef_t * | d | ||
| [in,out] | d | pointer to a cs_xdef_t structure |
| [in] | is_owner | manage or not the lifecycle of the array values |
| [in] | array | values |
| [in] | array_index | index on array values |
| void cs_xdef_set_quadrature | ( | cs_xdef_t * | d, |
| cs_quadrature_type_t | qtype | ||
| [in] | qtype | type of quadrature |
| cs_xdef_t* cs_xdef_timestep_create | ( | cs_xdef_type_t | type, |
| void * | input | ||
| [in] | input | pointer to a structure storing the parameters (cast on-the-fly according to the type of definition) |
| cs_xdef_t* cs_xdef_volume_create | ( | cs_xdef_type_t | type, |
| int | dim, | ||
| int | z_id, | ||
| void * | input | ||
