48 #define CS_APP_NAME "Code_Saturne" 49 #define CS_APP_VERSION PACKAGE_VERSION 54 #define _CS_ARCH_Blue_Gene 56 #elif defined(__linux__) || defined(__linux) || defined(linux) 57 #define _CS_ARCH_Linux 59 #elif defined(__sun__) || defined(__sun) || defined(sun) 60 #define _CS_ARCH_SunOS 69 #define CS_MEM_ALIGN 32 71 #define CS_MEM_ALIGN 0 74 #define CS_BASE_STRING_LEN 80 107 static inline const char *
148 #if defined(HAVE_MPI) 433 #if defined(HAVE_DLOPEN) 520 bool errors_are_fatal);
void cs_base_trace_set(bool trace)
Definition: cs_base.c:1845
void cs_base_string_f_to_c_free(char **c_str)
Definition: cs_base.c:2130
void cs_base_mem_finalize(void)
Definition: cs_base.c:1558
void() cs_base_atexit_t(void)
Definition: cs_base.h:87
void * cs_base_dlopen_plugin(const char *name)
Load a plugin's dynamic library.
Definition: cs_base.c:2352
Definition: cs_defs.h:467
char * cs_base_string_f_to_c_create(const char *f_str, int f_len)
Definition: cs_base.c:2073
void * cs_base_dlopen(const char *filename)
Load a dynamic library.
Definition: cs_base.c:2312
const char * cs_base_get_localedir(void)
Definition: cs_base.c:2188
const char * cs_base_get_pkglibdir(void)
Definition: cs_base.c:2221
void cs_base_warn(const char *file_name, int line_num)
Definition: cs_base.c:2035
void cs_base_option_string_clean(char *s)
Definition: cs_base.c:2158
void cs_base_mem_init(void)
Definition: cs_base.c:1489
void cs_base_mpi_init(int *argc, char **argv[])
Definition: cs_base.c:1289
void cs_base_bft_printf_init(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:1864
bool cs_base_bft_printf_suppressed(void)
Definition: cs_base.c:2021
int cs_base_dlopen_get_flags(void)
Get flags for dlopen.
Definition: cs_base.c:2383
void cs_exit(int status)
Definition: cs_base.c:1401
void cs_base_logfile_head(int argc, char *argv[])
Definition: cs_base.c:1099
void * cs_base_get_dl_function_pointer(void *handle, const char *name, bool errors_are_fatal)
Get a shared library function pointer.
Definition: cs_base.c:2450
char * cs_base_get_app_name(int argc, const char *argv[])
Definition: cs_base.c:1040
void cs_base_backtrace_dump(FILE *f, int lv_start)
Dump a stack trace to a file.
Definition: cs_base.c:2481
void cs_base_check_bool(bool *b)
Definition: cs_base.c:2239
Definition: cs_defs.h:468
void cs_base_update_status(const char *format,...)
Update status file.
Definition: cs_base.c:1768
void cs_base_dlopen_set_flags(int flags)
Set flags for dlopen.
Definition: cs_base.c:2397
static const char * cs_base_strtf(bool boolean)
Return a string "true" or "false" according to the boolean.
Definition: cs_base.h:108
FILE * cs_base_open_properties_data_file(const char *base_name)
Definition: cs_base.c:2269
const char * cs_base_get_pkgdatadir(void)
Definition: cs_base.c:2203
void cs_base_bft_printf_set(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:1942
void cs_base_error_init(bool signal_defaults)
Definition: cs_base.c:1443
void cs_base_time_summary(void)
Definition: cs_base.c:1688
void cs_base_dlclose(const char *filename, void *handle)
Unload a dynamic library.
Definition: cs_base.c:2417
void cs_base_atexit_set(cs_base_atexit_t *const fct)
Definition: cs_base.c:2054
double precision, save b
const char * cs_base_bft_printf_name(void)
Definition: cs_base.c:2005
