#include <stdio.h>#include <string.h>#include <errno.h>#include <stdlib.h>#include "cs_defs.h"#include "bft_mem.h"#include "bft_error.h"#include "mei_hash_table.h"#include "mei_evaluate.h"#include "mei_node.h"#include "mei_parser.h"#include "mei_parser_glob.h"#include <unistd.h>
Macros | |
| #define | YY_INT_ALIGNED short int |
| #define | FLEX_SCANNER |
| #define | YY_FLEX_MAJOR_VERSION 2 |
| #define | YY_FLEX_MINOR_VERSION 6 |
| #define | YY_FLEX_SUBMINOR_VERSION 1 |
| #define | FLEX_BETA |
| #define | FLEXINT_H |
| #define | INT8_MIN (-128) |
| #define | INT16_MIN (-32767-1) |
| #define | INT32_MIN (-2147483647-1) |
| #define | INT8_MAX (127) |
| #define | INT16_MAX (32767) |
| #define | INT32_MAX (2147483647) |
| #define | UINT8_MAX (255U) |
| #define | UINT16_MAX (65535U) |
| #define | UINT32_MAX (4294967295U) |
| #define | yyconst const |
| #define | yynoreturn |
| #define | YY_NULL 0 |
| #define | YY_SC_TO_UI(c) ((unsigned int) (unsigned char) c) |
| #define | BEGIN (yy_start) = 1 + 2 * |
| #define | YY_START (((yy_start) - 1) / 2) |
| #define | YYSTATE YY_START |
| #define | YY_STATE_EOF(state) (YY_END_OF_BUFFER + state + 1) |
| #define | YY_NEW_FILE yyrestart(yyin ) |
| #define | YY_END_OF_BUFFER_CHAR 0 |
| #define | YY_BUF_SIZE 16384 |
| #define | YY_STATE_BUF_SIZE ((YY_BUF_SIZE + 2) * sizeof(yy_state_type)) |
| #define | YY_TYPEDEF_YY_BUFFER_STATE |
| #define | YY_TYPEDEF_YY_SIZE_T |
| #define | EOB_ACT_CONTINUE_SCAN 0 |
| #define | EOB_ACT_END_OF_FILE 1 |
| #define | EOB_ACT_LAST_MATCH 2 |
| #define | YY_LESS_LINENO(n) |
| #define | YY_LINENO_REWIND_TO(ptr) |
| #define | yyless(n) |
| #define | unput(c) yyunput( c, (yytext_ptr) ) |
| #define | YY_STRUCT_YY_BUFFER_STATE |
| #define | YY_BUFFER_NEW 0 |
| #define | YY_BUFFER_NORMAL 1 |
| #define | YY_BUFFER_EOF_PENDING 2 |
| #define | YY_CURRENT_BUFFER |
| #define | YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)] |
| #define | YY_FLUSH_BUFFER yy_flush_buffer(YY_CURRENT_BUFFER ) |
| #define | yy_new_buffer yy_create_buffer |
| #define | yy_set_interactive(is_interactive) |
| #define | yy_set_bol(at_bol) |
| #define | YY_AT_BOL() (YY_CURRENT_BUFFER_LVALUE->yy_at_bol) |
| #define | yytext_ptr yytext |
| #define | YY_DO_BEFORE_ACTION |
| #define | YY_NUM_RULES 23 |
| #define | YY_END_OF_BUFFER 24 |
| #define | REJECT reject_used_but_not_detected |
| #define | yymore() yymore_used_but_not_detected |
| #define | YY_MORE_ADJ 0 |
| #define | YY_RESTORE_YY_MORE_OFFSET |
| #define | YY_INPUT(b, r, ms) ( r = my_yyinput(b, ms) ) |
| #define | INITIAL 0 |
| #define | YY_EXTRA_TYPE void * |
| #define | YY_READ_BUF_SIZE 8192 |
| #define | ECHO do { if (fwrite( yytext, (size_t) yyleng, 1, yyout )) {} } while (0) |
| #define | yyterminate() return YY_NULL |
| #define | YY_START_STACK_INCR 25 |
| #define | YY_FATAL_ERROR(msg) yy_fatal_error( msg ) |
| #define | YY_DECL_IS_OURS 1 |
| #define | YY_DECL int yylex (void) |
| #define | YY_USER_ACTION |
| #define | YY_BREAK /*LINTED*/break; |
| #define | YY_RULE_SETUP YY_USER_ACTION |
| #define | YY_EXIT_FAILURE 2 |
| #define | YYTABLES_NAME "yytables" |
| typedef signed char | flex_int8_t |
| typedef short int | flex_int16_t |
| typedef int | flex_int32_t |
| typedef unsigned char | flex_uint8_t |
| typedef unsigned short int | flex_uint16_t |
| typedef unsigned int | flex_uint32_t |
| typedef size_t | yy_size_t |
| typedef unsigned char | YY_CHAR |
| typedef int | yy_state_type |
| void | yyrestart (FILE *input_file) |
| void | yy_switch_to_buffer (YY_BUFFER_STATE new_buffer) |
| YY_BUFFER_STATE | yy_create_buffer (FILE *file, int size) |
| void | yy_delete_buffer (YY_BUFFER_STATE b) |
| void | yy_flush_buffer (YY_BUFFER_STATE b) |
| void | yypush_buffer_state (YY_BUFFER_STATE new_buffer) |
| void | yypop_buffer_state (void) |
| static void | yyensure_buffer_stack (void) |
| static void | yy_load_buffer_state (void) |
| static void | yy_init_buffer (YY_BUFFER_STATE b, FILE *file) |
| YY_BUFFER_STATE | yy_scan_buffer (char *base, yy_size_t size) |
| YY_BUFFER_STATE | yy_scan_string (yyconst char *yy_str) |
| YY_BUFFER_STATE | yy_scan_bytes (yyconst char *bytes, int len) |
| void * | yyalloc (yy_size_t) |
| void * | yyrealloc (void *, yy_size_t) |
| void | yyfree (void *) |
| static yy_state_type | yy_get_previous_state (void) |
| static yy_state_type | yy_try_NUL_trans (yy_state_type current_state) |
| static int | yy_get_next_buffer (void) |
| static void yynoreturn | yy_fatal_error (yyconst char *msg) |
| int | my_yyinput (char *buffer, int max_size) |
| static int | yy_init_globals (void) |
| int | yylex_destroy (void) |
| int | yyget_debug (void) |
| void | yyset_debug (int debug_flag) |
| YY_EXTRA_TYPE | yyget_extra (void) |
| void | yyset_extra (YY_EXTRA_TYPE user_defined) |
| FILE * | yyget_in (void) |
| void | yyset_in (FILE *_in_str) |
| FILE * | yyget_out (void) |
| void | yyset_out (FILE *_out_str) |
| int | yyget_leng (void) |
| char * | yyget_text (void) |
| int | yyget_lineno (void) |
| void | yyset_lineno (int _line_number) |
| int | yywrap (void) |
| static void | yyunput (int c, char *buf_ptr) |
| static int | input (void) |
| int | yylex (void) |
| if (!(yy_init)) | |
| int | yyleng |
| FILE * | yyin = NULL |
| FILE * | yyout = NULL |
| static size_t | yy_buffer_stack_top = 0 |
| static size_t | yy_buffer_stack_max = 0 |
| static YY_BUFFER_STATE * | yy_buffer_stack = NULL |
| static char | yy_hold_char |
| static int | yy_n_chars |
| static char * | yy_c_buf_p = NULL |
| static int | yy_init = 0 |
| static int | yy_start = 0 |
| static int | yy_did_buffer_switch_on_eof |
| int | yylineno = 1 |
| char * | yytext |
| static yyconst flex_int16_t | yy_accept [83] |
| static yyconst YY_CHAR | yy_ec [256] |
| static yyconst YY_CHAR | yy_meta [40] |
| static yyconst flex_uint16_t | yy_base [85] |
| static yyconst flex_int16_t | yy_def [85] |
| static yyconst flex_uint16_t | yy_nxt [172] |
| static yyconst flex_int16_t | yy_chk [172] |
| static yy_state_type | yy_last_accepting_state |
| static char * | yy_last_accepting_cpos |
| int | yy_flex_debug = 0 |
| char * | buff = NULL |
| size_t | len |
| YY_DECL | |
| char * | yy_cp |
| char * | yy_bp |
| int | yy_act |
| #define BEGIN (yy_start) = 1 + 2 * |
| #define EOB_ACT_CONTINUE_SCAN 0 |
| #define EOB_ACT_END_OF_FILE 1 |
| #define EOB_ACT_LAST_MATCH 2 |
| #define FLEX_BETA |
| #define FLEX_SCANNER |
| #define FLEXINT_H |
| #define INITIAL 0 |
| #define INT16_MAX (32767) |
| #define INT16_MIN (-32767-1) |
| #define INT32_MAX (2147483647) |
| #define INT32_MIN (-2147483647-1) |
| #define INT8_MAX (127) |
| #define INT8_MIN (-128) |
| #define REJECT reject_used_but_not_detected |
| #define UINT16_MAX (65535U) |
| #define UINT32_MAX (4294967295U) |
| #define UINT8_MAX (255U) |
| #define unput | ( | c | ) | yyunput( c, (yytext_ptr) ) |
| #define YY_AT_BOL | ( | ) | (YY_CURRENT_BUFFER_LVALUE->yy_at_bol) |
| #define YY_BREAK /*LINTED*/break; |
| #define YY_BUF_SIZE 16384 |
| #define YY_BUFFER_EOF_PENDING 2 |
| #define YY_BUFFER_NEW 0 |
| #define YY_BUFFER_NORMAL 1 |
| #define YY_CURRENT_BUFFER |
| #define YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)] |
| #define YY_DECL int yylex (void) |
| #define YY_DECL_IS_OURS 1 |
| #define YY_DO_BEFORE_ACTION |
| #define YY_END_OF_BUFFER 24 |
| #define YY_END_OF_BUFFER_CHAR 0 |
| #define YY_EXIT_FAILURE 2 |
| #define YY_EXTRA_TYPE void * |
| #define YY_FATAL_ERROR | ( | msg | ) | yy_fatal_error( msg ) |
| #define YY_FLEX_MAJOR_VERSION 2 |
| #define YY_FLEX_MINOR_VERSION 6 |
| #define YY_FLEX_SUBMINOR_VERSION 1 |
| #define YY_FLUSH_BUFFER yy_flush_buffer(YY_CURRENT_BUFFER ) |
| #define YY_INPUT | ( | b, | |
| r, | |||
| ms | |||
| ) | ( r = my_yyinput(b, ms) ) |
| #define YY_INT_ALIGNED short int |
| #define YY_LESS_LINENO | ( | n | ) |
| #define YY_LINENO_REWIND_TO | ( | ptr | ) |
| #define YY_MORE_ADJ 0 |
| #define yy_new_buffer yy_create_buffer |
| #define YY_NULL 0 |
| #define YY_NUM_RULES 23 |
| #define YY_READ_BUF_SIZE 8192 |
| #define YY_RESTORE_YY_MORE_OFFSET |
| #define YY_RULE_SETUP YY_USER_ACTION |
| #define YY_SC_TO_UI | ( | c | ) | ((unsigned int) (unsigned char) c) |
| #define yy_set_bol | ( | at_bol | ) |
| #define yy_set_interactive | ( | is_interactive | ) |
| #define YY_START (((yy_start) - 1) / 2) |
| #define YY_START_STACK_INCR 25 |
| #define YY_STATE_BUF_SIZE ((YY_BUF_SIZE + 2) * sizeof(yy_state_type)) |
| #define YY_STATE_EOF | ( | state | ) | (YY_END_OF_BUFFER + state + 1) |
| #define YY_STRUCT_YY_BUFFER_STATE |
| #define YY_TYPEDEF_YY_BUFFER_STATE |
| #define YY_TYPEDEF_YY_SIZE_T |
| #define YY_USER_ACTION |
| #define yyconst const |
| #define yyless | ( | n | ) |
| #define yymore | ( | ) | yymore_used_but_not_detected |
| #define yynoreturn |
| #define YYSTATE YY_START |
| #define YYTABLES_NAME "yytables" |
| #define yyterminate | ( | ) | return YY_NULL |
| #define yytext_ptr yytext |
| typedef short int flex_int16_t |
| typedef int flex_int32_t |
| typedef signed char flex_int8_t |
| typedef unsigned short int flex_uint16_t |
| typedef unsigned int flex_uint32_t |
| typedef unsigned char flex_uint8_t |
| typedef unsigned char YY_CHAR |
| typedef size_t yy_size_t |
| typedef int yy_state_type |
| if | ( | ! | yy_init | ) |
static |
| int my_yyinput | ( | char * | buffer, |
| int | max_size | ||
| YY_BUFFER_STATE yy_create_buffer | ( | FILE * | file, |
| int | size | ||
| void yy_delete_buffer | ( | YY_BUFFER_STATE | b | ) |
static |
| void yy_flush_buffer | ( | YY_BUFFER_STATE | b | ) |
static |
static |
static |
static |
static |
| YY_BUFFER_STATE yy_scan_buffer | ( | char * | base, |
| yy_size_t | size | ||
| YY_BUFFER_STATE yy_scan_bytes | ( | yyconst char * | bytes, |
| int | len | ||
| YY_BUFFER_STATE yy_scan_string | ( | yyconst char * | yy_str | ) |
| void yy_switch_to_buffer | ( | YY_BUFFER_STATE | new_buffer | ) |
static |
| void* yyalloc | ( | yy_size_t | ) |
static |
| void yyfree | ( | void * | ) |
| int yyget_debug | ( | void | ) |
| YY_EXTRA_TYPE yyget_extra | ( | void | ) |
| FILE* yyget_in | ( | void | ) |
| int yyget_leng | ( | void | ) |
| int yyget_lineno | ( | void | ) |
| FILE* yyget_out | ( | void | ) |
| char* yyget_text | ( | void | ) |
| int yylex | ( | void | ) |
| int yylex_destroy | ( | void | ) |
| void yypop_buffer_state | ( | void | ) |
| void yypush_buffer_state | ( | YY_BUFFER_STATE | new_buffer | ) |
| void* yyrealloc | ( | void * | , |
| yy_size_t | |||
| void yyrestart | ( | FILE * | input_file | ) |
| void yyset_debug | ( | int | debug_flag | ) |
| void yyset_extra | ( | YY_EXTRA_TYPE | user_defined | ) |
| void yyset_in | ( | FILE * | _in_str | ) |
| void yyset_lineno | ( | int | _line_number | ) |
| void yyset_out | ( | FILE * | _out_str | ) |
static |
| int yywrap | ( | void | ) |
| char* buff = NULL |
| size_t len |
static |
| int yy_act |
static |
| char * yy_bp |
static |
Stack as an array.
static |
capacity of stack.
static |
index of top of stack.
static |
static |
| char* yy_cp |
| YY_DECL |
The main scanner function which does all the work.
static |
static |
| int yy_flex_debug = 0 |
static |
static |
static |
static |
static |
static |
static |
| FILE * yyin = NULL |
| int yyleng |
| int yylineno = 1 |
| FILE * yyout = NULL |
| char * yytext |
