mei_evaluate.h
1 #ifndef __MEI_EVALUATE_H__
2 #define __MEI_EVALUATE_H__
10 /*
11  This file is part of Code_Saturne, a general-purpose CFD tool.
13  Copyright (C) 1998-2019 EDF S.A.
14
15  This program is free software; you can redistribute it and/or modify it under
16  the terms of the GNU General Public License as published by the Free Software
17  Foundation; either version 2 of the License, or (at your option) any later
18  version.
19
20  This program is distributed in the hope that it will be useful, but WITHOUT
21  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
22  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
23  details.
24
25  You should have received a copy of the GNU General Public License along with
26  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
27  Street, Fifth Floor, Boston, MA 02110-1301, USA.
28 */
30 /*----------------------------------------------------------------------------*/
33  * Local headers
36 #include "mei_hash_table.h"
37 #include "mei_node.h"
38
41 #ifdef __cplusplus
42 extern "C" {
43 #endif /* __cplusplus */
46  * Type definitions
48
53 struct _mei_tree_t {
54  char *string;
55  int errors;
56  int *columns;
57  int *lines;
58  char **labels;
59  hash_table_t *symbol;
60  mei_node_t *node;
61 };
62
67 typedef struct _mei_tree_t mei_tree_t;
68
69 /*============================================================================
70  * Public function prototypes
71  *============================================================================*/
72
73 /*----------------------------------------------------------------------------
74  * Returns a new interpreter.
75  *
76  * The node member is empty, the string member contains the mathematical
77  * expression and the symbol table is initialize with the standard symbols.
78  *
79  * parameters:
80  * expr <-- string characters of the mathematical expression
81  *
82  * returns:
83  * pointer to new interpreter structure.
84  *----------------------------------------------------------------------------*/
85
86 mei_tree_t *
87 mei_tree_new(const char *expr);
88
89 /*----------------------------------------------------------------------------
90  * Returns a new interpreter. The node member is empty,
91  * the string member contains the mathematical expression and
92  * the symbol table is initialize with a existing table, which is shared by
93  * multiple interpreter.
94  *
95  * parameters:
96  * expr <-- string characters of the mathematical expression
97  * symbol_table <-- shared table of symbols
98  *
99  * returns:
100  * pointer to new interpreter structure.
101  *----------------------------------------------------------------------------*/
102
103 mei_tree_t *
104 mei_tree_new_with_shared_symbols(const char *expr,
105  hash_table_t *symbol_table);
106
107 /*----------------------------------------------------------------------------
108  * Returns a new table of symbols. The table contains standard mathematical
109  * symbols
110  *----------------------------------------------------------------------------*/
111
112 hash_table_t *
114
115 /*----------------------------------------------------------------------------
116  * Calls the yacc parser.
117  * Returns 0 if the parsing is ok, or the number of errors, if errors occurs
118  *
119  * parameters:
120  * ev <-- interpreter
121  *----------------------------------------------------------------------------*/
122
123 int
124 mei_tree_builder(mei_tree_t *ev);
125
126 /*----------------------------------------------------------------------------
127  * Inserts a constant (label and value) in the table of symbols associated to
128  * an interpreter.
129  *
130  * parameters:
131  * ev <-- interpreter
132  * str <-- label of the constant
133  * value <-- value associated to the constant
134  *----------------------------------------------------------------------------*/
135
136 void
137 mei_tree_insert(mei_tree_t *ev,
138  const char *str,
139  const double value);
140
141 /*----------------------------------------------------------------------------
142  * Inserts a constant (label and value) in a table of symbols.
143  *
144  * parameters:
145  * symbo_table <-- table of symbols
146  * str <-- label of the constant
147  * value <-- value associated to the constant
148  *----------------------------------------------------------------------------*/
149
150 void
151 mei_symbol_table_insert(hash_table_t *symbol_table,
152  const char *str,
153  const double value);
154
155 /*----------------------------------------------------------------------------
156  * Checks if the symbol 'str' exists in the expression stored in 'ev'.
157  *
158  * parameters:
159  * ev <-- interpreter in which we want to know if str exists
160  * str <-- symbol to find
161  *
162  * returns:
163  * 0 if the symbol exists in the symbol table, 1 otherwise.
164  *----------------------------------------------------------------------------*/
165
166 int
167 mei_tree_find_symbol(mei_tree_t *ev,
168  const char *str);
169
170 /*----------------------------------------------------------------------------
171  * Checks if the symbols in a list exist in the expression.
172  *
173  * parameters:
174  * ev <-- interpreter in which we want to know if str exists
175  * str <-- symbol to find
176  *
177  * returns:
178  * number of missing symbols
179  *----------------------------------------------------------------------------*/
180
181 int
182 mei_tree_find_symbols(mei_tree_t *ev,
183  const int size,
184  const char **symbol);
185
186 /*----------------------------------------------------------------------------
187  * Returns a value of a symbol (variable or constant) from an interpreter
188  * symbol table.
189  *
190  * parameters:
191  * ev <-- interpreter
192  * str <-- name of the symbol
193  *----------------------------------------------------------------------------*/
194
195 double
196 mei_tree_lookup(mei_tree_t *ev,
197  const char *str);
198
199 /*----------------------------------------------------------------------------
200  * Evaluates the expression :
201  * 1) computes all values for variables inside the expression
202  * 2) returns a value from the intrepreted expression.
203  *
204  * parameters:
205  * ev <-- interpreter
206  *----------------------------------------------------------------------------*/
207
208 double
209 mei_evaluate(mei_tree_t *ev);
210
211 /*----------------------------------------------------------------------------
212  * Free memory and return NULL.
213  *
214  * parameters:
215  * ev <-- interpreter
216  *----------------------------------------------------------------------------*/
217
218 void
219 mei_tree_destroy(mei_tree_t *ev);
220
221 /*----------------------------------------------------------------------------*/
222
223 #ifdef __cplusplus
224 }
225 #endif /* __cplusplus */
226
227 #endif /* __MEI_EVALUATE_H__ */
228
int * columns
Definition: mei_evaluate.h:56
char ** labels
Definition: mei_evaluate.h:58
int mei_tree_find_symbols(mei_tree_t *ev, const int size, const char **symbol)
Check if the symbol str from a list exists in the expression. The list of missing symbols is stored i...
Definition: mei_evaluate.c:789
int mei_tree_builder(mei_tree_t *ev)
Call the yacc parser. Return 0 if the parsing is ok, or the number of errors, if errors occurs...
Definition: mei_evaluate.c:606
Hash table, intended to provide a symbol table.
void mei_symbol_table_insert(hash_table_t *symbol_table, const char *str, const double value)
Definition: mei_evaluate.c:728
mei_tree_t * mei_tree_new(const char *expr)
Returns a new interpreter. The node member is empty, the string member contains the mathematical expr...
Definition: mei_evaluate.c:489
mei_node_t * node
Definition: mei_evaluate.h:60
int mei_tree_find_symbol(mei_tree_t *ev, const char *str)
Check if the symbol str exists in the expression stored in ev.
Definition: mei_evaluate.c:755
void mei_tree_destroy(mei_tree_t *ev)
Definition: mei_evaluate.c:872
void mei_tree_insert(mei_tree_t *ev, const char *str, const double value)
Inserts a constant (label and value) in the table of symbols associated to an interpreter.
Definition: mei_evaluate.c:702
Structure defining an interpreter for a mathematical expression.
Definition: mei_evaluate.h:53
hash_table_t * symbol
Definition: mei_evaluate.h:59
hash_table_t * mei_table_symbols_new(void)
Returns a new table of symbols. The table contains standard mathematical symbols. ...
Definition: mei_evaluate.c:582
double mei_tree_lookup(mei_tree_t *ev, const char *str)
Returns a value of the str symbol (variable or constant) from table of symbols of ev interpreter...
Definition: mei_evaluate.c:827
char * string
Definition: mei_evaluate.h:54
int errors
Definition: mei_evaluate.h:55
mei_tree_t * mei_tree_new_with_shared_symbols(const char *expr, hash_table_t *symbol_table)
Definition: mei_evaluate.c:536
int * lines
Definition: mei_evaluate.h:57
Nodal structure of the interpreter.
double mei_evaluate(mei_tree_t *ev)
Evaluates the expression ev : 1) computes all values for variables inside the expression 2) returns a...
Definition: mei_evaluate.c:857
