Build an interpreter for a mathematical expression.
More...
| struct | mei_tree_t |
| | Structure defining an interpreter for a mathematical expression. More...
| mei_tree_t * | mei_tree_new (const char *expr) |
| | Returns a new interpreter. The node member is empty, the string member contains the mathematical expression and the symbol table is initialize with the standard symbols. More...
| mei_tree_t * | mei_tree_new_with_shared_symbols (const char *expr, hash_table_t *symbol_table) |
| | Returns a new interpreter. The node member is empty, the string member contains the mathematical expression and the symbol table is initialize with a existing table, which is shared by multiple interpreter. More...
| hash_table_t * | mei_table_symbols_new (void) |
| | Returns a new table of symbols. The table contains standard mathematical symbols. More...
| int | mei_tree_builder (mei_tree_t *ev) |
| | Call the yacc parser. Return 0 if the parsing is ok, or the number of errors, if errors occurs. More...
| void | mei_tree_insert (mei_tree_t *ev, const char *str, const double value) |
| | Inserts a constant (label and value) in the table of symbols associated to an interpreter. More...
| void | mei_symbol_table_insert (hash_table_t *symbol_table, const char *str, const double value) |
| | Inserts a constant (label and value) in a table of symbols. More...
| int | mei_tree_find_symbol (mei_tree_t *ev, const char *str) |
| | Check if the symbol str exists in the expression stored in ev. More...
| int | mei_tree_find_symbols (mei_tree_t *ev, const int size, const char **symbol) |
| | Check if the symbol str from a list exists in the expression. The list of missing symbols is stored in ev->labels. More...
| double | mei_tree_lookup (mei_tree_t *ev, const char *str) |
| | Returns a value of the str symbol (variable or constant) from table of symbols of ev interpreter. More...
| double | mei_evaluate (mei_tree_t *ev) |
| | Evaluates the expression ev : 1) computes all values for variables inside the expression 2) returns a value from the intrepreted expression. More...
| void | mei_tree_destroy (mei_tree_t *ev) |
| | Free memory and return NULL. More...
◆ mei_evaluate()
| double mei_evaluate |
mei_tree_t * |
ev | ) |
- Parameters
- Returns
- value from the intrepreted expression
◆ mei_symbol_table_insert()
| void mei_symbol_table_insert |
hash_table_t * |
symbol_table, |
const char * |
str, |
const double |
value |
- Parameters
| [in] | symbol_table | table of symbols |
| [in] | str | label of the constant |
| [in] | value | value associated to the constant |
◆ mei_table_symbols_new()
| hash_table_t* mei_table_symbols_new |
void |
- Returns
- table of symbols
◆ mei_tree_builder()
| int mei_tree_builder |
mei_tree_t * |
ev | ) |
- Parameters
- Returns
- number of parsing errors
◆ mei_tree_destroy()
| void mei_tree_destroy |
mei_tree_t * |
ev | ) |
- Parameters
◆ mei_tree_find_symbol()
| int mei_tree_find_symbol |
mei_tree_t * |
ev, |
const char * |
str |
- Parameters
| [in] | ev | interpreter in which we want to know if str exists |
| [in] | str | symbol to find |
- Returns
- 0 if the symbol exists in the symbol table, 1 if not
◆ mei_tree_find_symbols()
| int mei_tree_find_symbols |
mei_tree_t * |
ev, |
const int |
size, |
const char ** |
symbol |
- Parameters
| [in] | ev | interpreter |
| [in] | size | number of symbols to check |
| [in] | symbol | list of symbols |
- Returns
- 0 if all symbols exist, otherwise return the number of errors
◆ mei_tree_insert()
| void mei_tree_insert |
mei_tree_t * |
ev, |
const char * |
str, |
const double |
value |
- Parameters
◆ mei_tree_lookup()
| double mei_tree_lookup |
mei_tree_t * |
ev, |
const char * |
str |
- Parameters
| [in] | str | name of the symbol |
- Returns
- value of a symbol
◆ mei_tree_new()
| mei_tree_t* mei_tree_new |
const char * |
expr | ) |
- Parameters
| [in] | expr | string characters of the mathematical expression |
- Returns
- new empty interpreter
◆ mei_tree_new_with_shared_symbols()
| mei_tree_t* mei_tree_new_with_shared_symbols |
const char *const |
expr, |
hash_table_t *const |
symbol_table |
- Parameters
| [in] | symbol_table | shared table of symbols |
- Returns
