mei_parser.h
1 /* A Bison parser, made by GNU Bison 3.0.4. */
2
3 /* Bison interface for Yacc-like parsers in C
4
5  Copyright (C) 1984, 1989-1990, 2000-2015 Free Software Foundation, Inc.
6
7  This program is free software: you can redistribute it and/or modify
8  it under the terms of the GNU General Public License as published by
9  the Free Software Foundation, either version 3 of the License, or
10  (at your option) any later version.
11
12  This program is distributed in the hope that it will be useful,
13  but WITHOUT ANY WARRANTY; without even the implied warranty of
14  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
15  GNU General Public License for more details.
16
17  You should have received a copy of the GNU General Public License
18  along with this program. If not, see <http://www.gnu.org/licenses/>. */
19
20 /* As a special exception, you may create a larger work that contains
21  part or all of the Bison parser skeleton and distribute that work
22  under terms of your choice, so long as that work isn't itself a
23  parser generator using the skeleton or a modified version thereof
24  as a parser skeleton. Alternatively, if you modify or redistribute
25  the parser skeleton itself, you may (at your option) remove this
26  special exception, which will cause the skeleton and the resulting
27  Bison output files to be licensed under the GNU General Public
28  License without this special exception.
30  This special exception was added by the Free Software Foundation in
31  version 2.2 of Bison. */
32
33 #ifndef YY_YY_SRC_MEI_MEI_PARSER_H_INCLUDED
34 # define YY_YY_SRC_MEI_MEI_PARSER_H_INCLUDED
35 /* Debug traces. */
36 #ifndef YYDEBUG
37 # define YYDEBUG 0
38 #endif
39 #if YYDEBUG
40 extern int yydebug;
41 #endif
43 /* Token type. */
44 #ifndef YYTOKENTYPE
45 # define YYTOKENTYPE
47  {
48  NUMBER = 258,
49  VAR = 259,
50  FUN1 = 260,
51  FUN2 = 261,
52  FUN3 = 262,
53  FUN4 = 263,
54  IN1D = 264,
55  WHILE = 265,
56  IF = 266,
57  PRINT = 267,
58  IFX = 268,
59  ELSE = 269,
60  OR = 270,
61  AND = 271,
62  EQ = 272,
63  NE = 273,
64  GE = 274,
65  LE = 275,
66  UMINUS = 276,
67  UPLUS = 277
68  };
69 #endif
70
71 /* Value type. */
72 #if ! defined YYSTYPE && ! defined YYSTYPE_IS_DECLARED
73
74 union YYSTYPE
75 {
76 #line 50 "./src/mei/mei_parser.y" /* yacc.c:1909 */
77
78  double iValue; /* double value */
79  char sIndex[200]; /* variable, constant or function identifier */
80  mei_node_t *nPtr; /* node pointer */
81
82 #line 83 "./src/mei/mei_parser.h" /* yacc.c:1909 */
83 };
84
85 typedef union YYSTYPE YYSTYPE;
86 # define YYSTYPE_IS_TRIVIAL 1
87 # define YYSTYPE_IS_DECLARED 1
88 #endif
89
90
91 extern YYSTYPE yylval;
92
93 int yyparse (void);
94
95 #endif /* !YY_YY_SRC_MEI_MEI_PARSER_H_INCLUDED */
Definition: mei_parser.h:63
Definition: mei_parser.h:56
Definition: mei_parser.h:50
Definition: mei_parser.h:51
Definition: mei_parser.h:62
int yyparse(void)
Definition: mei_parser.c:1296
Definition: mei_parser.h:65
yytokentype
Definition: mei_parser.c:143
Definition: mei_parser.h:58
Definition: mei_parser.h:67
Definition: mei_parser.h:55
Definition: mei_parser.h:64
Definition: mei_parser.h:66
Definition: mei_parser.h:59
YYSTYPE yylval
Definition: mei_parser.h:48
Definition: mei_parser.h:54
Definition: mei_parser.h:53
Definition: mei_parser.h:57
Definition: mei_parser.h:60
Definition: mei_parser.h:49
Definition: mei_parser.h:61
Definition: mei_parser.h:52
