#include "cs_defs.h"#include <string.h>#include "bft_mem.h"#include "bft_printf.h"#include "mei_node.h"#include "mei_parser_glob.h"#include <stddef.h>
Macros | |
| #define | YYBISON 1 |
| #define | YYBISON_VERSION "3.0.4" |
| #define | YYSKELETON_NAME "yacc.c" |
| #define | YYPURE 0 |
| #define | YYPUSH 0 |
| #define | YYPULL 1 |
| #define | YY_NULLPTR 0 |
| #define | YYERROR_VERBOSE 0 |
| #define | YY_YY_SRC_MEI_MEI_PARSER_H_INCLUDED |
| #define | YYDEBUG 0 |
| #define | YYTOKENTYPE |
| #define | YYSTYPE_IS_TRIVIAL 1 |
| #define | YYSTYPE_IS_DECLARED 1 |
| #define | YYSIZE_T size_t |
| #define | YYSIZE_MAXIMUM ((YYSIZE_T) -1) |
| #define | YY_(Msgid) Msgid |
| #define | YY_ATTRIBUTE(Spec) /* empty */ |
| #define | YY_ATTRIBUTE_PURE YY_ATTRIBUTE ((__pure__)) |
| #define | YY_ATTRIBUTE_UNUSED YY_ATTRIBUTE ((__unused__)) |
| #define | _Noreturn YY_ATTRIBUTE ((__noreturn__)) |
| #define | YYUSE(E) ((void) (E)) |
| #define | YY_INITIAL_VALUE(Value) Value |
| #define | YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN |
| #define | YY_IGNORE_MAYBE_UNINITIALIZED_END |
| #define | YYSTACK_ALLOC YYMALLOC |
| #define | YYSTACK_FREE YYFREE |
| #define | YYSTACK_ALLOC_MAXIMUM YYSIZE_MAXIMUM |
| #define | YYMALLOC malloc |
| #define | YYFREE free |
| #define | YYSTACK_GAP_MAXIMUM (sizeof (union yyalloc) - 1) |
| #define | YYSTACK_BYTES(N) |
| #define | YYCOPY_NEEDED 1 |
| #define | YYSTACK_RELOCATE(Stack_alloc, Stack) |
| #define | YYCOPY(Dst, Src, Count) |
| #define | YYFINAL 34 |
| #define | YYLAST 1149 |
| #define | YYNTOKENS 38 |
| #define | YYNNTS 5 |
| #define | YYNRULES 38 |
| #define | YYNSTATES 98 |
| #define | YYUNDEFTOK 2 |
| #define | YYMAXUTOK 277 |
| #define | YYTRANSLATE(YYX) ((unsigned int) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK) |
| #define | YYPACT_NINF -28 |
| #define | yypact_value_is_default(Yystate) (!!((Yystate) == (-28))) |
| #define | YYTABLE_NINF -37 |
| #define | yytable_value_is_error(Yytable_value) 0 |
| #define | yyerrok (yyerrstatus = 0) |
| #define | yyclearin (yychar = YYEMPTY) |
| #define | YYEMPTY (-2) |
| #define | YYEOF 0 |
| #define | YYACCEPT goto yyacceptlab |
| #define | YYABORT goto yyabortlab |
| #define | YYERROR goto yyerrorlab |
| #define | YYRECOVERING() (!!yyerrstatus) |
| #define | YYBACKUP(Token, Value) |
| #define | YYTERROR 1 |
| #define | YYERRCODE 256 |
| #define | YYDPRINTF(Args) |
| #define | YY_SYMBOL_PRINT(Title, Type, Value, Location) |
| #define | YY_STACK_PRINT(Bottom, Top) |
| #define | YY_REDUCE_PRINT(Rule) |
| #define | YYINITDEPTH 200 |
| #define | YYMAXDEPTH 10000 |
| #define | YYPOPSTACK(N) (yyvsp -= (N), yyssp -= (N)) |
| typedef unsigned char | yytype_uint8 |
| typedef signed char | yytype_int8 |
| typedef unsigned short int | yytype_uint16 |
| typedef short int | yytype_int16 |
Enumerations | |
| enum | yytokentype { NUMBER = 258, VAR = 259, FUN1 = 260, FUN2 = 261, FUN3 = 262, FUN4 = 263, IN1D = 264, WHILE = 265, IF = 266, PRINT = 267, IFX = 268, ELSE = 269, OR = 270, AND = 271, EQ = 272, NE = 273, GE = 274, LE = 275, UMINUS = 276, UPLUS = 277, NUMBER = 258, VAR = 259, FUN1 = 260, FUN2 = 261, FUN3 = 262, FUN4 = 263, IN1D = 264, WHILE = 265, IF = 266, PRINT = 267, IFX = 268, ELSE = 269, OR = 270, AND = 271, EQ = 272, NE = 273, GE = 274, LE = 275, UMINUS = 276, UPLUS = 277 } |
| int | yyparse (void) |
| void * | malloc (YYSIZE_T) |
| void | free (void *) |
| static void | yydestruct (const char *yymsg, int yytype, YYSTYPE *yyvaluep) |
| void | yyerror (const char *s) |
| YYSTYPE | yylval |
| static const yytype_uint8 | yytranslate [] |
| static const yytype_int16 | yypact [] |
| static const yytype_uint8 | yydefact [] |
| static const yytype_int8 | yypgoto [] |
| static const yytype_int8 | yydefgoto [] |
| static const yytype_int8 | yytable [] |
| static const yytype_int8 | yycheck [] |
| static const yytype_uint8 | yystos [] |
| static const yytype_uint8 | yyr1 [] |
| static const yytype_uint8 | yyr2 [] |
| int | yychar |
| int | yynerrs |
| #define _Noreturn YY_ATTRIBUTE ((__noreturn__)) |
| #define YY_ | ( | Msgid | ) | Msgid |
| #define YY_ATTRIBUTE | ( | Spec | ) | /* empty */ |
| #define YY_ATTRIBUTE_PURE YY_ATTRIBUTE ((__pure__)) |
| #define YY_ATTRIBUTE_UNUSED YY_ATTRIBUTE ((__unused__)) |
| #define YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN |
| #define YY_IGNORE_MAYBE_UNINITIALIZED_END |
| #define YY_INITIAL_VALUE | ( | Value | ) | Value |
| #define YY_NULLPTR 0 |
| #define YY_REDUCE_PRINT | ( | Rule | ) |
| #define YY_STACK_PRINT | ( | Bottom, | |
| Top | |||
| #define YY_SYMBOL_PRINT | ( | Title, | |
| Type, | |||
| Value, | |||
| Location | |||
| #define YY_YY_SRC_MEI_MEI_PARSER_H_INCLUDED |
| #define YYABORT goto yyabortlab |
| #define YYACCEPT goto yyacceptlab |
| #define YYBACKUP | ( | Token, | |
| Value | |||
| #define YYBISON 1 |
| #define YYBISON_VERSION "3.0.4" |
| #define YYCOPY | ( | Dst, | |
| Src, | |||
| Count | |||
| #define YYCOPY_NEEDED 1 |
| #define YYDEBUG 0 |
| #define YYDPRINTF | ( | Args | ) |
| #define YYEMPTY (-2) |
| #define YYEOF 0 |
| #define YYERRCODE 256 |
| #define yyerrok (yyerrstatus = 0) |
| #define YYERROR goto yyerrorlab |
| #define YYERROR_VERBOSE 0 |
| #define YYFINAL 34 |
| #define YYFREE free |
| #define YYINITDEPTH 200 |
| #define YYLAST 1149 |
| #define YYMALLOC malloc |
| #define YYMAXDEPTH 10000 |
| #define YYMAXUTOK 277 |
| #define YYNNTS 5 |
| #define YYNRULES 38 |
| #define YYNSTATES 98 |
| #define YYNTOKENS 38 |
| #define YYPACT_NINF -28 |
| #define yypact_value_is_default | ( | Yystate | ) | (!!((Yystate) == (-28))) |
| #define YYPOPSTACK | ( | N | ) | (yyvsp -= (N), yyssp -= (N)) |
| #define YYPULL 1 |
| #define YYPURE 0 |
| #define YYPUSH 0 |
| #define YYRECOVERING | ( | ) | (!!yyerrstatus) |
| #define YYSIZE_MAXIMUM ((YYSIZE_T) -1) |
| #define YYSIZE_T size_t |
| #define YYSKELETON_NAME "yacc.c" |
| #define YYSTACK_ALLOC YYMALLOC |
| #define YYSTACK_ALLOC_MAXIMUM YYSIZE_MAXIMUM |
| #define YYSTACK_BYTES | ( | N | ) |
| #define YYSTACK_FREE YYFREE |
| #define YYSTACK_GAP_MAXIMUM (sizeof (union yyalloc) - 1) |
| #define YYSTACK_RELOCATE | ( | Stack_alloc, | |
| Stack | |||
| #define YYSTYPE_IS_DECLARED 1 |
| #define YYSTYPE_IS_TRIVIAL 1 |
| #define YYTABLE_NINF -37 |
| #define yytable_value_is_error | ( | Yytable_value | ) | 0 |
| #define YYTERROR 1 |
| #define YYTOKENTYPE |
| #define YYTRANSLATE | ( | YYX | ) | ((unsigned int) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK) |
| #define YYUNDEFTOK 2 |
| #define YYUSE | ( | E | ) | ((void) (E)) |
| typedef short int yytype_int16 |
| typedef signed char yytype_int8 |
| typedef unsigned short int yytype_uint16 |
| typedef unsigned char yytype_uint8 |
| enum yytokentype |
| void free | ( | void * | ) |
| void* malloc | ( | YYSIZE_T | ) |
static |
| void yyerror | ( | const char * | s | ) |
| int yyparse | ( | void | ) |
| int yychar |
static |
static |
static |
| YYSTYPE yylval |
| int yynerrs |
static |
static |
static |
static |
static |
static |
static |
