bft_error.h
1 #ifndef __BFT_ERROR_H__
2 #define __BFT_ERROR_H__
5  * Base error handling
30 #include "cs_defs.h"
35  * Standard C library headers
38 #include <stdarg.h>
40 /*----------------------------------------------------------------------------
41  * Local headers
42  *----------------------------------------------------------------------------*/
44 /*-----------------------------------------------------------------------------*/
45
49  * Public types
51
52 typedef void (bft_error_handler_t) (const char *const file_name,
53  const int line_num,
54  const int sys_error_code,
55  const char *const format,
56  va_list arg_ptr);
57
61
62 /*
63  * Calls the error handler (set by bft_error_handler_set() or default).
64  *
65  * With the default error handler, bft_print_flush() is called, an error
66  * message is output to stderr, and the current process exits with an
67  * EXIT_FAILURE code.
68  *
69  * parameters:
70  * file_name: <-- name of source file from which error handler called.
71  * line_num: <-- line of source file from which error handler called.
72  * sys_error_code: <-- error code if error in system or libc call, 0 otherwise.
73  * format: <-- format string, as printf() and family.
74  * ... : <-- variable arguments based on format string.
75  */
76
77 #if defined(__GNUC__)
78
79 void
80 bft_error(const char *const file_name,
81  const int line_num,
82  const int sys_error_code,
83  const char *const format,
84  ...)
85  __attribute__((format(printf, 4, 5)));
86
87 #else
88
89 void
90 bft_error(const char *const file_name,
91  const int line_num,
92  const int sys_error_code,
93  const char *const format,
94  ...);
95
96 #endif
97
98 /*
99  * Returns the error handler associated with the bft_error() function.
100  *
101  * returns:
102  * pointer to the error handler function.
103  */
104
107
108 /*
109  * Associates an error handler with the bft_error() function.
110  *
111  * parameters:
112  * handler: <-- pointer to the error handler function.
113  */
114
115 void
117
118 /*----------------------------------------------------------------------------*/
119
121
122 #endif /* __BFT_ERROR_H__ */
Definition: cs_defs.h:467
void bft_error_handler_set(bft_error_handler_t *const handler)
Definition: bft_error.c:227
void() bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition: bft_error.h:52
bft_error_handler_t * bft_error_handler_get(void)
Definition: bft_error.c:215
Definition: bft_error.c:193
Definition: cs_defs.h:468
