80 for (
short int e = 0; e < fm->
n_ef; e++)
82 p_f *= 0.5 / pfq.
meas;
115 for (
int ie = cm->
f2e_idx[f]; ie < cm->f2e_idx[f+1]; ie++) {
117 p_f += (p_v[v[0]] + p_v[v[1]]) * cm->
tef[ie];
119 p_f *= 0.5 / pfq.
meas;
143 if (p_v == NULL || cm == NULL)
149 for (
short int v = 0;
v < cm->
n_vc;
v++)
150 p_c += cm->
wvc[
v] * p_v[
v];
void cs_reco_cw_cgrd_wbs_from_pvc(const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *cgrd)
Compute the mean value of a gradient inside a given primal cell. Use the WBS algo. for approximating the gradient. The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}.
Definition: cs_reco.c:995
static bool cs_flag_test(cs_flag_t flag_to_check, cs_flag_t reference)
Check if a two flag share the same pattern Return true if the flag to check has at least the pattern ...
Definition: cs_flag.h:188
double * tef
Definition: cs_cdo_local.h:196
void cs_reco_cw_cell_vect_from_face_dofs(const cs_cell_mesh_t *cm, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
Reconstruct the vector-valued quantity inside each cell from the face DoFs (interior and boundary)...
Definition: cs_reco.c:744
void cs_reco_ccen_edge_dof(cs_lnum_t cid, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *dof, double reco[])
Reconstruct at the cell center a field of edge-based DoFs.
Definition: cs_reco.c:608
void cs_reco_cell_vect_from_face_dofs(const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
Definition: cs_reco.c:264
#define CS_FLAG_COMP_FEQ
Definition: cs_flag.h:141
void cs_reco_conf_vtx_dofs(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *dof, double *p_crec[], double *p_frec[])
Reconstruct at cell centers and face centers a vertex-based field Linear interpolation. If p_crec and/or p_frec are not allocated, this done in this subroutine.
Definition: cs_reco.c:81
double * wvc
Definition: cs_cdo_local.h:166
double * tef
Definition: cs_cdo_local.h:235
Definition: cs_mesh_adjacencies.h:90
Definition: cs_defs.h:467
double meas
Definition: cs_cdo_quantities.h:88
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:146
static cs_real_t cs_reco_cw_scalar_pv_at_cell_center(const cs_cell_mesh_t *cm, const cs_real_t *p_v)
Reconstruct the value of a scalar potential at the cell center from an array of values defined on pri...
Definition: cs_reco.h:138
Definition: cs_cdo_connect.h:74
void cs_reco_pv_at_cell_center(cs_lnum_t c_id, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Reconstruct the value at the cell center from an array of values defined on primal vertices...
Definition: cs_reco.c:323
short int * f2e_ids
Definition: cs_cdo_local.h:195
void cs_reco_grad_cell_from_pv(cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *pdi, cs_real_t val_xc[])
Reconstruct the value at the cell center of the gradient of a field defined on primal vertices...
Definition: cs_reco.c:692
short int n_ef
Definition: cs_cdo_local.h:232
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
#define CS_FLAG_COMP_PFQ
Definition: cs_flag.h:137
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
Definition: cs_field_pointer.h:134
cs_real_t cs_reco_cw_scalar_pv_inside_cell(const cs_cell_mesh_t *cm, const cs_real_t pdi[], const cs_real_t length_xcxp, const cs_real_t unitv_xcxp[], cs_real_t wbuf[])
Reconstruct the value of a scalar potential at a point inside a cell The scalar potential has DoFs lo...
Definition: cs_reco.c:841
void cs_reco_ccen_edge_dofs(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *dof, double *p_ccrec[])
Reconstruct at each cell center a field of edge-based DoFs.
Definition: cs_reco.c:650
void cs_reco_vect_pv_at_cell_centers(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Reconstruct the value at all cell centers from an array of values defined on primal vertices...
Definition: cs_reco.c:213
#define CS_FLAG_COMP_EV
Definition: cs_flag.h:139
short int * e2v_ids
Definition: cs_cdo_local.h:238
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:56
cs_quant_t * face
Definition: cs_cdo_local.h:182
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
cs_flag_t flag
Definition: cs_cdo_local.h:148
void cs_reco_dfbyc_in_cell(const cs_cell_mesh_t *cm, const cs_real_t *array, cs_real_3_t val_c)
Reconstruct a constant vector inside the cell c. array is scanned thanks to the c2e connectivity...
Definition: cs_reco.c:509
cs_quant_t face
Definition: cs_cdo_local.h:222
static cs_real_t cs_reco_fw_scalar_pv_at_face_center(const cs_face_mesh_t *fm, const cs_real_t *p_v)
Reconstruct the value at the face center from an array of values defined on primal vertices...
Definition: cs_reco.h:70
Definition: cs_cdo_quantities.h:86
Definition: cs_defs.h:298
short int n_vc
Definition: cs_cdo_local.h:163
void cs_reco_dfbyc_at_cell_center(cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *array, cs_real_3_t val_xc)
Reconstruct a constant vector at the cell center from an array of values defined on dual faces lying ...
Definition: cs_reco.c:468
static cs_real_t cs_reco_cw_scalar_pv_at_face_center(const short int f, const cs_cell_mesh_t *cm, const cs_real_t *p_v)
Definition: cs_reco.h:101
Definition: cs_defs.h:468
short int * e2v_ids
Definition: cs_cdo_local.h:186
void cs_reco_vect_pv_from_pc(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *val, cs_real_t *reco_val)
Reconstruct a vector-valued array at vertices from a vector-valued array at cells.
Definition: cs_reco.c:366
void cs_reco_pf_from_pv(cs_lnum_t f_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *pdi, cs_real_t *pdi_f)
Definition: cs_reco.c:417
void cs_reco_cw_vgrd_wbs_from_pvc(const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *vgrd)
Compute the weighted (by volume) gradient inside a given primal cell for the related vertices...
Definition: cs_reco.c:897
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:212
Definition: cs_flag.h:140
void cs_reco_cw_cell_grad_from_scalar_pv(const cs_cell_mesh_t *cm, const cs_real_t pdi[], cs_real_t *cell_gradient)
Definition: cs_reco.c:800
#define CS_FLAG_COMP_PVQ
Definition: cs_flag.h:132
short int * f2e_idx
Definition: cs_cdo_local.h:194
void cs_reco_pv_at_cell_centers(const cs_adjacency_t *c2v, const cs_cdo_quantities_t *quant, const double *array, cs_real_t *val_xc)
Definition: cs_reco.c:167
void cs_reco_dfbyc_in_pec(const cs_cell_mesh_t *cm, short int e, const cs_real_t *array, cs_real_3_t val_pec)
Reconstruct a constant vector inside pec which is a volume surrounding the edge e inside the cell c...
Definition: cs_reco.c:555
