logical | imbrication_flag |
activation flag More... | |
logical, save | imbrication_verbose |
logical | cressman_u |
Flags for activating the cressman interpolation for the boundary conditions. More... | |
logical | cressman_v |
logical | cressman_tke |
logical | cressman_eps |
logical | cressman_theta |
logical | cressman_qw |
logical | cressman_nc |
double precision | horizontal_influence_radius |
numerical parameters for the cressman interpolation formulas More... | |
double precision | vertical_influence_radius |
integer | line_len |
Parameter for "meteo" files. More... | |
character(line_len) | imbrication_files_list |
character(line_len), dimension(:), allocatable | imbrication_files |
integer | number_of_files |
character *(3) | skip_chars |
integer | thermal_profile_dim |
Profile dimension variable. More... | |
integer | dynamical_profile_dim |
integer | sections_per_file |
Time sections per files. More... | |
integer, dimension(:,:), allocatable | years |
read data from "meteo" files More... | |
integer, dimension(:,:), allocatable | ordinals |
integer, dimension(:,:), allocatable | hours |
integer, dimension(:,:), allocatable | minutes |
double precision, dimension(:,:), allocatable | seconds |
double precision, dimension(:,:), allocatable | xpos |
Positions. More... | |
double precision, dimension(:,:), allocatable | ypos |
double precision, dimension(:,:), allocatable | ground_pressure |
double precision, dimension(:,:,:), allocatable | zt |
Vertical grid for temperature and humidity variables. More... | |
double precision, dimension(:,:,:), allocatable | tempc |
double precision, dimension(:,:,:), allocatable | qw |
double precision, dimension(:,:,:), allocatable | nc |
double precision, dimension(:,:,:), allocatable | zd |
Vertical grid for wind variables. More... | |
double precision, dimension(:,:,:), allocatable | u |
double precision, dimension(:,:,:), allocatable | v |
double precision, dimension(:,:,:), allocatable | tke |
double precision, dimension(:,:,:), allocatable | eps |
double precision, dimension(:,:), allocatable, target | times |
derived data More... | |
double precision, dimension(:,:,:), allocatable | pressure |
double precision, dimension(:,:,:), allocatable | theta |
double precision, dimension(:,:,:), allocatable | density |
double precision, dimension(:,:), allocatable | ti_zt |
time interpolated profiles More... | |
double precision, dimension(:,:), allocatable | ti_tempc |
double precision, dimension(:,:), allocatable | ti_qw |
double precision, dimension(:,:), allocatable | ti_nc |
double precision, dimension(:,:), allocatable | ti_zd |
double precision, dimension(:,:), allocatable | ti_u |
double precision, dimension(:,:), allocatable | ti_v |
double precision, dimension(:,:), allocatable | ti_tke |
double precision, dimension(:,:), allocatable | ti_eps |
double precision, dimension(:,:), allocatable | ti_pressure |
double precision, dimension(:,:), allocatable | ti_theta |
double precision, dimension(:,:), allocatable | ti_density |
double precision, dimension(:,:,:), allocatable | coordinates_th |
additional variables More... | |
double precision, dimension(:,:,:), allocatable | influence_param_th |
double precision, dimension(:,:,:), allocatable | coordinates_dyn |
double precision, dimension(:,:,:), allocatable | influence_param_dyn |
integer | id_u |
integer | id_v |
integer | id_tke |
integer | id_eps |
integer | id_theta |
integer | id_qw |
integer | id_nc |
double precision, dimension(:), pointer | times_sequence =>null() |
1D array of times at which profiles are given More... | |
double precision, dimension(:,:,:), allocatable coordinates_dyn |
double precision, dimension(:,:,:), allocatable coordinates_th |
logical cressman_eps |
logical cressman_nc |
logical cressman_qw |
logical cressman_theta |
logical cressman_tke |
logical cressman_u |
logical cressman_v |
double precision, dimension(:,:,:), allocatable density |
integer dynamical_profile_dim |
double precision, dimension(:,:,:), allocatable eps |
double precision, dimension(:,:), allocatable ground_pressure |
double precision horizontal_influence_radius |
integer, dimension(:,:), allocatable hours |
integer id_eps |
integer id_nc |
integer id_qw |
integer id_theta |
integer id_tke |
integer id_u |
integer id_v |
character(line_len), dimension(:), allocatable imbrication_files |
character(line_len) imbrication_files_list |
logical imbrication_flag |
activation flag
logical, save imbrication_verbose |
double precision, dimension(:,:,:), allocatable influence_param_dyn |
double precision, dimension(:,:,:), allocatable influence_param_th |
integer line_len |
integer, dimension(:,:), allocatable minutes |
double precision, dimension(:,:,:), allocatable nc |
integer number_of_files |
integer, dimension(:,:), allocatable ordinals |
double precision, dimension(:,:,:), allocatable pressure |
double precision, dimension(:,:,:), allocatable qw |
double precision, dimension(:,:), allocatable seconds |
integer sections_per_file |
character*(3) skip_chars |
double precision, dimension(:,:,:), allocatable tempc |
integer thermal_profile_dim |
double precision, dimension(:,:,:), allocatable theta |
double precision, dimension(:,:), allocatable ti_density |
double precision, dimension(:,:), allocatable ti_eps |
double precision, dimension(:,:), allocatable ti_nc |
double precision, dimension(:,:), allocatable ti_pressure |
double precision, dimension(:,:), allocatable ti_qw |
double precision, dimension(:,:), allocatable ti_tempc |
double precision, dimension(:,:), allocatable ti_theta |
double precision, dimension(:,:), allocatable ti_tke |
double precision, dimension(:,:), allocatable ti_u |
double precision, dimension(:,:), allocatable ti_v |
double precision, dimension(:,:), allocatable ti_zd |
double precision, dimension(:,:), allocatable ti_zt |
double precision, dimension(:,:), allocatable, target times |
derived data
double precision, dimension(:), pointer times_sequence =>null() |
double precision, dimension(:,:,:), allocatable tke |
double precision, dimension(:,:,:), allocatable u |
double precision, dimension(:,:,:), allocatable v |
double precision vertical_influence_radius |
double precision, dimension(:,:), allocatable xpos |
Positions.
integer, dimension(:,:), allocatable years |
Time variables
double precision, dimension(:,:), allocatable ypos |
double precision, dimension(:,:,:), allocatable zd |
double precision, dimension(:,:,:), allocatable zt |
