#include <assert.h>#include <ctype.h>#include <float.h>#include <math.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include "cs_field.h"#include "cs_gwf_soil.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_parall.h"#include "cs_param.h"#include "cs_post.h"#include "cs_reco.h"#include "cs_gwf_tracer.h"
Macros | |
| #define | CS_GWF_TRACER_DBG 0 |
| static void | _get_time_pty4std_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *input, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations This function fits the generic prototype of cs_xdef_cell_eval_t. More... | |
| static void | _get_time_pty4std_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *input, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations This function fits the generic prototype of cs_xdef_cell_eval_cw_t. More... | |
| static void | _get_reaction_pty4std_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *input, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. This function fits the generic prototype of cs_xdef_cell_eval_t. More... | |
| static void | _get_reaction_pty4std_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *input, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. This function fits the generic prototype of cs_xdef_cell_eval_cw_t. More... | |
| static void | _update_diff_pty4std_tracer (void *input, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval) |
| Update physical properties for a standard tracer model. Only the diffusivity needs an update (reaction property and time property are defined by function). Generic function relying on the prototype cs_gwf_tracer_update_t. More... | |
| static void | _free_std_tracer (void *input) |
| Free the input related to a standard tracer equation Rely on the generic prototype cs_gwf_tracer_free_input_t. More... | |
| cs_gwf_tracer_t * | cs_gwf_tracer_init (int tracer_id, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, cs_gwf_tracer_model_t model) |
| Create a new cs_gwf_tracer_t structure and initialize its members by default. Add a new equation related to the groundwater flow module. This equation is a specific transport equation. Tracer is advected thanks to the darcian velocity which is given by the resolution of the Richards equation. Diffusion/reaction parameters result from a physical modelling. More... | |
| cs_gwf_tracer_t * | cs_gwf_tracer_free (cs_gwf_tracer_t *tracer) |
| Free a cs_gwf_tracer_t structure. More... | |
| void | cs_gwf_set_standard_tracer (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef, double reaction_rate) |
| Set a tracer for a specified soil when the tracer is attached to the default model. More... | |
| void | cs_gwf_tracer_standard_add_terms (cs_gwf_tracer_t *tracer) |
| Add terms to the algebraic system related to a tracer equation according to the settings. Case of the standar tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t. More... | |
| void | cs_gwf_tracer_standard_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
| Set the parameters related to a standard tracer equation. More... | |
| static const char | _err_empty_tracer [] |
| #define CS_GWF_TRACER_DBG 0 |
static |
| [in,out] | input | pointer to a structure cast on-the-fly |
inlinestatic |
| [in] | elt_ids | list of element ids |
| [in] | compact | indirection for output (true or false) |
| [in] | input | pointer to an input structure cast on-the_fly |
| [in,out] | result | array storing the result (must be allocated) |
inlinestatic |
inlinestatic |
inlinestatic |
static |
| void cs_gwf_set_standard_tracer | ( | cs_gwf_tracer_t * | tracer, |
| const char * | soil_name, | ||
| double | wmd, | ||
| double | alpha_l, | ||
| double | alpha_t, | ||
| double | distrib_coef, | ||
| double | reaction_rate | ||
| [in,out] | tracer | pointer to a cs_gwf_tracer_t structure |
| [in] | soil_name | name of the related soil (or NULL if all soils are selected) |
| [in] | wmd | value of the water molecular diffusivity |
| [in] | alpha_l | value of the longitudinal dispersivity |
| [in] | alpha_t | value of the transversal dispersivity |
| [in] | distrib_coef | value of the distribution coefficient |
| [in] | reaction_rate | value of the first order rate of reaction |
| cs_gwf_tracer_t* cs_gwf_tracer_free | ( | cs_gwf_tracer_t * | tracer | ) |
| cs_gwf_tracer_t* cs_gwf_tracer_init | ( | int | tracer_id, |
| const char * | eq_name, | ||
| cs_adv_field_t * | adv_field, | ||
| cs_gwf_tracer_model_t | model | ||
| [in] | tracer_id | id number of the soil |
| [in] | eq_name | name of the tracer equation |
| [in] | var_name | name of the related variable |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| [in] | model | model related to this tracer |
| void cs_gwf_tracer_standard_add_terms | ( | cs_gwf_tracer_t * | tracer | ) |
Add terms to the algebraic system related to a tracer equation according to the settings. Case of the standar tracer modelling Rely on the generic functinon: cs_gwf_tracer_add_terms_t.
| void cs_gwf_tracer_standard_setup | ( | const cs_cdo_connect_t * | connect, |
| cs_gwf_tracer_t * | tracer | ||
static |
