| cs_gwf_tracer_t * | cs_gwf_tracer_init (int tracer_id, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, cs_gwf_tracer_model_t model) |
| | Create a new cs_gwf_tracer_t structure and initialize its members by default. Add a new equation related to the groundwater flow module. This equation is a specific transport equation. Tracer is advected thanks to the darcian velocity which is given by the resolution of the Richards equation. Diffusion/reaction parameters result from a physical modelling. More...
| cs_gwf_tracer_t * | cs_gwf_tracer_free (cs_gwf_tracer_t *tracer) |
| | Free a cs_gwf_tracer_t structure. More...
| void | cs_gwf_set_standard_tracer (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef, double reaction_rate) |
| | Set a tracer for a specified soil when the tracer is attached to the default model. More...
| void | cs_gwf_tracer_standard_add_terms (cs_gwf_tracer_t *tracer) |
| | Add terms to the algebraic system related to a tracer equation according to the settings. Case of the standar tracer modelling Rely on the generic functinon: cs_gwf_tracer_add_terms_t. More...
| void | cs_gwf_tracer_standard_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
| | Set the parameters related to a standard tracer equation. More...
◆ cs_gwf_tracer_add_terms_t
Generic function to update the terms to build in the algebraic system for a tracer equation according to the settings.
- Parameters
◆ cs_gwf_tracer_free_input_t
| typedef void() cs_gwf_tracer_free_input_t(void *input) |
Generic function to free the input of a tracer model.
- Parameters
| [in,out] | input | pointer to a structure cast on-the-fly |
◆ cs_gwf_tracer_setup_t
Generic function to set the parameters related to a tracer equation.
- Parameters
◆ cs_gwf_tracer_update_t
Generic function to update the phisical properties related to a tracer modelling.
- Parameters
◆ cs_gwf_tracer_model_t
| Enumerator |
| CS_GWF_TRACER_STANDARD | |
| CS_GWF_TRACER_USER | |
| CS_GWF_N_TRACER_MODELS | |
◆ cs_gwf_set_standard_tracer()
| void cs_gwf_set_standard_tracer |
cs_gwf_tracer_t * |
tracer, |
const char * |
soil_name, |
double |
wmd, |
double |
alpha_l, |
double |
alpha_t, |
double |
distrib_coef, |
double |
reaction_rate |
- Parameters
| [in,out] | tracer | pointer to a cs_gwf_tracer_t structure |
| [in] | soil_name | name of the related soil (or NULL if all soils are selected) |
| [in] | wmd | value of the water molecular diffusivity |
| [in] | alpha_l | value of the longitudinal dispersivity |
| [in] | alpha_t | value of the transversal dispersivity |
| [in] | distrib_coef | value of the distribution coefficient |
| [in] | reaction_rate | value of the first order rate of reaction |
◆ cs_gwf_tracer_free()
◆ cs_gwf_tracer_init()
- Parameters
| [in] | tracer_id | id number of the soil |
| [in] | eq_name | name of the tracer equation |
| [in] | var_name | name of the related variable |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| [in] | model | model related to this tracer |
- Returns
- a pointer to the new allocated structure
◆ cs_gwf_tracer_standard_add_terms()
- Parameters
- Parameters
◆ cs_gwf_tracer_standard_setup()
- Parameters
