#include "cs_base.h"#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_equation_common.h"#include "cs_equation_param.h"#include "cs_field.h"#include "cs_matrix.h"#include "cs_mesh.h"#include "cs_source_term.h"#include "cs_time_step.h"
| bool | cs_cdovb_vecteq_is_initialized (void) |
| Check if the generic structures for building a CDO-Vb scheme are allocated. More... | |
| void | cs_cdovb_vecteq_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms) |
| Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set shared pointers. More... | |
| void | cs_cdovb_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
| void | cs_cdovb_vecteq_finalize_common (void) |
| Free work buffer and general structure related to CDO vertex-based schemes. More... | |
| void * | cs_cdovb_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
| Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme. More... | |
| void * | cs_cdovb_vecteq_free_context (void *builder) |
| Destroy a cs_cdovb_vecteq_t structure. More... | |
| void | cs_cdovb_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued CDO-Vb schemes. More... | |
| void | cs_cdovb_vecteq_set_dir_bc (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t field_val[]) |
| Set the boundary conditions known from the settings when the fields stem from a vector CDO vertex-based scheme. More... | |
| void | cs_cdovb_vecteq_solve_steady_state (const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction equation with a CDO-Vb scheme. One works cellwise and then process to the assembly. More... | |
| void | cs_cdovb_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val) |
| Store solution(s) of the linear system into a field structure Update extra-field values if required (for hybrid discretization) More... | |
| cs_real_t * | cs_cdovb_vecteq_get_vertex_values (void *context) |
| Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| cs_real_t * | cs_cdovb_vecteq_get_cell_values (void *context) |
| Compute an array of values at mesh cells by interpolating the variable field associated to the given context located at mesh vertices The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| void | cs_cdovb_vecteq_extra_op (const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data) |
| void cs_cdovb_vecteq_extra_op | ( | const char * | eqname, |
| void * | data | ||
| [in,out] | data | pointer to cs_cdovb_vecteq_t structure |
| void cs_cdovb_vecteq_finalize_common | ( | void | ) |
| void* cs_cdovb_vecteq_free_context | ( | void * | builder | ) |
| [in,out] | builder | pointer to a cs_cdovb_vecteq_t structure |
| void cs_cdovb_vecteq_get | ( | cs_cell_sys_t ** | csys, |
| cs_real_t* cs_cdovb_vecteq_get_cell_values | ( | void * | context | ) |
| cs_real_t* cs_cdovb_vecteq_get_vertex_values | ( | void * | context | ) |
| void cs_cdovb_vecteq_init_common | ( | const cs_cdo_quantities_t * | quant, |
| void* cs_cdovb_vecteq_init_context | ( | const cs_equation_param_t * | eqp, |
| int | var_id, | ||
| int | bflux_id, | ||
| void cs_cdovb_vecteq_init_values | ( | cs_real_t | t_eval, |
| const int | field_id, | ||
| void * | context | ||
| bool cs_cdovb_vecteq_is_initialized | ( | void | ) |
| void cs_cdovb_vecteq_set_dir_bc | ( | cs_real_t | t_eval, |
| void * | context, | ||
| cs_real_t | field_val[] | ||
| [in,out] | field_val | pointer to the values of the variable field |
| void cs_cdovb_vecteq_solve_steady_state | ( | const cs_mesh_t * | mesh, |
| [in,out] | context | pointer to cs_cdovb_scaleq_t structure |
| [in,out] | context | pointer to cs_cdovb_vecteq_t structure |
| void cs_cdovb_vecteq_update_field | ( | const cs_real_t * | solu, |
| void * | data, | ||
