1 #ifndef __CS_CDOVB_VECTEQ_H__ 2 #define __CS_CDOVB_VECTEQ_H__ Store common elements used when building an algebraic system related to an equation.
Definition: cs_equation_common.h:61
time step descriptor
Definition: cs_time_step.h:51
void cs_cdovb_vecteq_extra_op(const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Definition: cs_cdovb_vecteq.c:1600
cs_real_t * cs_cdovb_vecteq_get_vertex_values(void *context)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovb_vecteq.c:1543
void cs_cdovb_vecteq_set_dir_bc(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context, cs_real_t field_val[])
Set the boundary conditions known from the settings when the fields stem from a vector CDO vertex-bas...
Definition: cs_cdovb_vecteq.c:1270
Definition: cs_field.h:124
Definition: cs_equation_param.h:148
void * cs_cdovb_vecteq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme...
Definition: cs_cdovb_vecteq.c:932
bool cs_cdovb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Vb scheme are allocated.
Definition: cs_cdovb_vecteq.c:789
Definition: cs_defs.h:467
void cs_cdovb_vecteq_solve_steady_state(const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction eq...
Definition: cs_cdovb_vecteq.c:1315
void cs_cdovb_vecteq_finalize_common(void)
Free work buffer and general structure related to CDO vertex-based schemes.
Definition: cs_cdovb_vecteq.c:896
Definition: cs_cdo_connect.h:74
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
Definition: cs_cdo_local.h:93
cs_real_t * cs_cdovb_vecteq_get_cell_values(void *context)
Compute an array of values at mesh cells by interpolating the variable field associated to the given ...
Definition: cs_cdovb_vecteq.c:1566
void cs_cdovb_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values if required (...
Definition: cs_cdovb_vecteq.c:1507
void cs_cdovb_vecteq_init_common(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms)
Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set sha...
Definition: cs_cdovb_vecteq.c:811
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:56
double precision, dimension(:,:), allocatable solu
Definition: atincl.f90:265
Definition: cs_defs.h:468
void * cs_cdovb_vecteq_free_context(void *builder)
Destroy a cs_cdovb_vecteq_t structure.
Definition: cs_cdovb_vecteq.c:1139
void cs_cdovb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovb_vecteq.c:874
void cs_cdovb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued CDO-Vb schemes.
Definition: cs_cdovb_vecteq.c:1172
Structure and routines handling the specific settings related to a cs_equation_t structure.
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:86
