At_main
double precision, dimension(:), allocatable tmmet
 tmmet —> time (in sec) of the meteo profile More...
double precision, dimension(:), allocatable zdmet
 zdmet —> altitudes of the dynamic profiles (read in the input meteo file) More...
double precision, dimension(:), allocatable ztmet
 ztmet –> altitudes of the temperature profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable umet
 umet –> meteo u profiles (read in the input meteo file) More...
double precision, dimension(:,:), allocatable vmet
 vmet –> meteo v profiles (read in the input meteo file) More...
double precision, dimension(:,:), allocatable wmet
 wmet –> meteo w profiles - unused More...
double precision, dimension(:,:), allocatable ekmet
 ekmet —> meteo turbulent kinetic energy profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable epmet
 epmet —> meteo turbulent dissipation profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable ttmet
 ttmet —> meteo temperature (Celsius) profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable qvmet
 qvmet —> meteo specific humidity profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable ncmet
 ncmet —> meteo specific drplet number profile (read in the input meteo file) More...
double precision, dimension(:), allocatable pmer
 pmer —> Sea level pressure (read in the input meteo file) More...
double precision, dimension(:), allocatable xmet
 xmet –> X axis cooordinates of the meteo profile (read in the input meteo file) More...
double precision, dimension(:), allocatable ymet
 ymet –> Y axis cooordinates of the meteo profile (read in the input meteo file) More...
double precision, dimension(:,:), allocatable rmet
 rmet –> density profile More...
double precision, dimension(:,:), allocatable tpmet
 tpmet –> potential temperature profile More...
double precision, dimension(:,:), allocatable phmet
 phmet –> hydrostatic pressure from Laplace integration More...
double precision, dimension(:), allocatable nebdia
 Diagnosed nebulosity. More...
double precision, dimension(:), allocatable nn
 fractional nebulosity More...
integer, save itotwt
 itotwt—> total water content (for humid atmosphere) More...
integer, save intdrp
 intdrp—> total number of droplets (for humid atmosphere) More...
integer, save itempc
 itempc—> temperature (in celsius) More...
integer, save iliqwt
 iliqwt—> liquid water content More...
integer, save imomst
 imomst –> momentum source term field id (useful when iatmst > 0) More...
integer, save imeteo
 imeteo –> flag for reading the meteo input file More...
integer, save nbmetd
 nbmetd –> numbers of altitudes for the dynamics More...
integer, save nbmett
 nbmett –> numbers of altitudes for the temperature and specific humidity More...
integer, save nbmetm
 nbmetm –> numbers of time steps for the meteo profiles More...
integer, dimension(nozppm), save iprofm
 iprofm –> read zone boundary conditions from profile More...
integer, dimension(:), allocatable iautom
 iautom –> automatic inlet/outlet boundary condition flag (0: not auto (default); 1,2: auto) When meteo momentum source terms are activated (iatmst = 1), iautom = 1 corresponds to a Dirichlet on the pressure and a Neumann on the velocity, whereas iautom = 2 imposes a Dirichlet on both pressure and velocity More...
integer, save initmeteo
 initmeteo –> use meteo profile for variables initialization (0: not used; 1: used (default)) More...
integer, save iatmst
 iatmst –> add a momentum source term based on the meteo profile More...
integer, save theo_interp
 theo_interp –> flag for meteo velocity field interpolation 0: linear interpolation of the meteo profile 1: the user can directly impose the exact meteo velocity by declaring the 'meteo_velocity' field Useful for iatmst = 1 More...
double precision, save ps
 reference pressure (to compute potential temp: 1.0d+5) More...
double precision, save rvsra
 ratio gaz constant h2o/ dry air: 1.608d0 More...
double precision, save cpvcpa
 ratio Cp h2o/ dry air: 1.866d0 More...
double precision, save clatev
 latent heat of evaporation: 2.501d+6 More...
double precision, save gammat
 temperature gradient for the standard atmosphere (-6.5d-03 K/m) More...
double precision, save rvap
 rvsra*rair More...
integer, save syear
 syear –> starting year More...
integer, save squant
 squant –> starting quantile More...
integer, save shour
 shour –> starting hour More...
integer, save smin
 smin –> starting min More...
double precision, save ssec
 ssec –> starting second More...
double precision, save xlon
 xlon –> longitude of the domain origin More...
double precision, save xlat
 xlat –> latitude of the domain origin More...
integer, save nbmaxt
 Number of vertical levels (cf. 1D radiative scheme. More...
integer, save ihpm
 ihpm –> flag to compute the hydrostastic pressure by Laplace integration in the meteo profiles More...
integer, save ivert
 ivert –> flag for the definition of the vertical grid More...
integer, save nvert
 nvert –> number of vertical arrays More...
integer, save kvert
 kvert –> number of levels (up to the top of the domain) More...
integer, save kmx
 kmx –> Number of levels (up to 11000 m if ray1d used) (automatically computed) More...
integer, save iatra1
 iatra1 –> flag for the use of the 1d atmo radiative model More...
integer, save nfatr1
 nfatr1 –> 1d radiative model pass frequency More...
integer, save iqv0
 iqv0 –> flag for the standard atmo humidity profile More...
integer, save idrayi
 pointer for 1D infrared profile More...
integer, save idrayst
 pointer for 1D solar profile More...
integer, save igrid
 grid formed by 1D profiles More...
integer, save irdu
 Flag for the computation of downward and upward infrared radiative fluxes 0: disabled 1: enabled. More...
integer, save soldu
 Flag for storage of downward and upward solar radiative fluxes 0: disabled 1: enabled. More...
double precision, dimension(:,:), allocatable xyvert
 horizontal coordinates of the vertical grid More...
double precision, dimension(:), allocatable zvert
 vertical grid for 1D radiative scheme initialize in cs_user_atmospheric_model.f90 More...
double precision, dimension(:), allocatable acinfe
 absorption for CO2 + 03 More...
double precision, dimension(:), allocatable dacinfe
 differential absorption for CO2 + 03 More...
double precision, dimension(:,:), allocatable aco2
 absorption for CO2 only More...
double precision, dimension(:,:), allocatable aco2s
double precision, dimension(:,:), allocatable daco2
 differential absorption for CO2 only More...
double precision, dimension(:,:), allocatable daco2s
double precision, dimension(:), allocatable acsup
 idem acinfe, flux descendant More...
double precision, dimension(:), allocatable acsups
double precision, dimension(:), allocatable dacsup
 internal variable for 1D radiative model More...
double precision, dimension(:), allocatable dacsups
double precision, dimension(:), allocatable tauzq
double precision, dimension(:), allocatable zq
double precision, save tausup
double precision, dimension(:), allocatable zray
double precision, dimension(:,:), allocatable rayi
double precision, dimension(:,:), allocatable rayst
double precision, dimension(:,:), allocatable iru
 Upward and downward radiative fluxes (infrared, solar) along each vertical. More...
double precision, dimension(:,:), allocatable ird
double precision, dimension(:,:), allocatable solu
double precision, dimension(:,:), allocatable sold
integer, save iatsoil
 iatsoil –> flag to use the ground model More...
double precision, save w1ini
 Water content of the first ground reservoir. More...
double precision, save w2ini
 Water content of the second ground reservoir. More...
integer, save modsub
 Option for subgrid models. More...
integer, save moddis
 Option for liquid water content distribution models. More...
integer, save modnuc
 Option for nucleation. More...
integer, save modsedi
 sedimentation flag More...
integer, save moddep
 deposition flag More...
double precision, save sigc
 adimensional : sigc=0.53 other referenced values are 0.28, 0.15 More...
integer, save init_at_chem
 force initilization in case of restart (this option is automatically set in lecamp) More...
integer, save kopint
 key id for optimal interpolation More...
◆ acinfe
◆ aco2
◆ aco2s
◆ acsup
◆ acsups
◆ clatev
◆ cpvcpa
◆ dacinfe
◆ daco2
◆ daco2s
◆ dacsup
◆ dacsups
◆ ekmet
◆ epmet
◆ gammat
◆ iatmst
◆ iatra1
  • = 0 no use (default)
  • = 1 use
◆ iatsoil
◆ iautom
◆ idrayi
◆ idrayst
◆ igrid
integer, save igrid
◆ ihpm
integer, save ihpm
  • = 0 : bottom to top Laplace integration, based on P(sea level) (default)
  • = 1 : top to bottom Laplace integration based on P computed for the standard atmosphere at z(nbmaxt)
◆ iliqwt
◆ imeteo
  • = 0 -> no reading
  • = 1 -> reading
◆ imomst
◆ init_at_chem
◆ initmeteo
◆ intdrp
◆ iprofm
◆ iqv0
integer, save iqv0
  • = 0 : q = 0 (default)
  • = 1 : q = decreasing exponential
◆ ird
◆ irdu
integer, save irdu
◆ iru
◆ itempc
◆ itotwt
◆ ivert
integer, save ivert
◆ kmx
integer, save kmx
◆ kopint
◆ kvert
integer, save kvert
◆ moddep
deposition flag
◆ moddis
  • moddis = 1 : all or nothing
  • moddis = 2 : Gaussian distribution
◆ modnuc
  • modnuc = 0 : without nucleation
  • modnuc = 1 : Pruppacher and Klett 1997
  • modnuc = 2 : Cohard et al. 1998,1999
  • modnuc = 3 : Abdul-Razzak et al. 1998,2000 logaritmic standard deviation of the log-normal law of the droplet spectrum
◆ modsedi
sedimentation flag
◆ modsub
  • modsub = 0 : the simplest parameterization (for numerical verifications)
  • modsub = 1 : Bechtold et al. 1995 (Luc Musson-Genon)
  • modsub = 2 : Bouzereau et al. 2004
  • modsub = 3 : Cuijpers and Duynkerke 1993, Deardorff 1976, Sommeria and Deardorff 1977
◆ nbmaxt
◆ nbmetd
◆ nbmetm
◆ nbmett
◆ ncmet
◆ nebdia
◆ nfatr1
◆ nn
◆ nvert
integer, save nvert
◆ phmet
◆ pmer
◆ ps
◆ qvmet
◆ rayi
◆ rayst
◆ rmet
◆ rvap
rvsra*rair
◆ rvsra
◆ shour
integer, save shour
◆ sigc
◆ smin
integer, save smin
◆ sold
◆ soldu
integer, save soldu
◆ solu
◆ squant
◆ ssec
◆ syear
integer, save syear
◆ tausup
◆ tauz
◆ tauzq
◆ theo_interp
◆ tmmet
◆ tpmet
◆ ttmet
◆ umet
◆ vmet
◆ w1ini
◆ w2ini
◆ wmet
◆ xlat
◆ xlon
◆ xmet
◆ xyvert
◆ ymet
◆ zdmet
◆ zq
◆ zray
◆ ztmet
◆ zvert
