#include "cs_cdo_bc.h"#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_equation_param.h"#include "cs_flag.h"#include "cs_matrix.h"#include "cs_time_step.h"#include "cs_timer.h"#include "cs_source_term.h"
| struct | cs_equation_builder_t |
| Store common elements used when building an algebraic system related to an equation. More... | |
| struct | cs_equation_balance_t |
| static cs_flag_t | cs_equation_cell_mesh_flag (cs_flag_t cell_flag, const cs_equation_builder_t *eqb) |
| Retrieve the flag to give for building a cs_cell_mesh_t structure. More... | |
| static void | cs_equation_set_diffusion_property (const cs_equation_param_t *eqp, const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_cell_builder_t *cb) |
| Set the diffusion property inside a cell and its related quantities. More... | |
| static void | cs_equation_set_diffusion_property_cw (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_cell_builder_t *cb) |
| Set the diffusion property inside a cell and its related quantities. Cellwise version using a cs_cell_mesh_t structure. More... | |
| void | cs_equation_common_init (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_flag_t vb_flag, cs_flag_t vcb_flag, cs_flag_t fb_flag, cs_flag_t hho_flag) |
| Allocate a pointer to a buffer of size at least the n_cells for managing temporary usage of memory when dealing with equations The size of the temporary buffer can be bigger according to the numerical settings Set also shared pointers from the main domain members. More... | |
| void | cs_equation_common_finalize (void) |
| Allocate a pointer to a buffer of size at least the 2*n_cells for managing temporary usage of memory when dealing with equations Call specific structure allocation related to a numerical scheme according to the scheme flag The size of the temporary buffer can be bigger according to the numerical settings. More... | |
| cs_equation_builder_t * | cs_equation_init_builder (const cs_equation_param_t *eqp, const cs_mesh_t *mesh) |
| Allocate a new structure to handle the building of algebraic system related to an cs_equation_t structure. More... | |
| void | cs_equation_free_builder (cs_equation_builder_t **p_builder) |
| Free a cs_equation_builder_t structure. More... | |
| cs_gnum_t | cs_equation_prepare_system (int stride, cs_lnum_t x_size, const cs_matrix_t *matrix, cs_range_set_t *rset, cs_real_t *x, cs_real_t *b) |
| Prepare a linear system and synchronize buffers to handle parallelism. Transfer a mesh-based description of arrays x0 and rhs into an algebraic description for the linear system in x and b. More... | |
| void | cs_equation_write_monitoring (const char *eqname, const cs_equation_builder_t *eqb) |
| Print a message in the performance output file related to the monitoring of equation. More... | |
| void | cs_equation_init_properties (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_real_t t_eval, cs_cell_builder_t *cb) |
| Initialize all properties for an algebraic system. More... | |
| void | cs_equation_init_properties_cw (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_real_t t_eval, const cs_flag_t cell_flag, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Initialize all properties for a given cell when building the algebraic system. If the property is uniform, a first call has to be done before the loop on cells Call cs_eqution_init_properties for instance. More... | |
| void | cs_equation_enforced_internal_dofs (const cs_equation_param_t *eqp, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account the enforcement of internal DoFs. Apply an algebraic manipulation. More... | |
| void | cs_equation_enforced_internal_block_dofs (const cs_equation_param_t *eqp, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Take into account the enforcement of internal DoFs. Case of matrices defined by blocks. Apply an algebraic manipulation. More... | |
| cs_real_t * | cs_equation_get_tmpbuf (void) |
| Retrieve a pointer to a buffer of size at least the 2*n_cells The size of the temporary buffer can be bigger according to the numerical settings. More... | |
| size_t | cs_equation_get_tmpbuf_size (void) |
| Get the allocation size of the temporary buffer. More... | |
| cs_equation_balance_t * | cs_equation_balance_create (cs_flag_t location, cs_lnum_t size) |
| Allocate a cs_equation_balance_t structure. More... | |
| void | cs_equation_balance_reset (cs_equation_balance_t *b) |
| Reset a cs_equation_balance_t structure. More... | |
| void | cs_equation_balance_sync (const cs_cdo_connect_t *connect, cs_equation_balance_t *b) |
| Synchronize balance terms if this is a parallel computation. More... | |
| void | cs_equation_balance_destroy (cs_equation_balance_t **p_balance) |
| Free a cs_equation_balance_t structure. More... | |
| cs_equation_balance_t* cs_equation_balance_create | ( | cs_flag_t | location, |
| cs_lnum_t | size | ||
| [in] | location | where the balance is performed |
| [in] | size | size of arrays in the structure |
| void cs_equation_balance_destroy | ( | cs_equation_balance_t ** | p_balance | ) |
| [in,out] | p_balance | pointer to the pointer to free |
| void cs_equation_balance_reset | ( | cs_equation_balance_t * | b | ) |
| [in,out] | b | pointer to a cs_equation_balance_t to reset |
| void cs_equation_balance_sync | ( | const cs_cdo_connect_t * | connect, |
| cs_equation_balance_t * | b | ||
| [in,out] | b | pointer to a cs_equation_balance_t to rsync |
inlinestatic |
| [in] | cell_flag | flag related to the current cell |
| void cs_equation_common_finalize | ( | void | ) |
| void cs_equation_common_init | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t | vb_flag, | ||
| cs_flag_t | vcb_flag, | ||
| cs_flag_t | fb_flag, | ||
| cs_flag_t | hho_flag | ||
| [in] | quant | pointer to additional mesh quantities struct. |
| [in] | vb_flag | metadata for Vb schemes |
| [in] | vcb_flag | metadata for V+C schemes |
| [in] | fb_flag | metadata for Fb schemes |
| [in] | hho_flag | metadata for HHO schemes |
| void cs_equation_enforced_internal_block_dofs | ( | const cs_equation_param_t * | eqp, |
| cs_cell_sys_t * | csys | ||
| | | | | | | | | | | Aii | Aie | | Aii | 0 | |bi| |bi -Aid.x_enf| |---------—| –> |---------—| and |–| –> |----------—| | | | | | | | | | | | Aei | Aee | | 0 | Id | |be| | x_enf |
where x_enf is the value of the enforcement for the selected internal DoFs
| [in,out] | csys | structure storing the cell-wise system |
| void cs_equation_enforced_internal_dofs | ( | const cs_equation_param_t * | eqp, |
| void cs_equation_free_builder | ( | cs_equation_builder_t ** | p_builder | ) |
| [in,out] | p_builder | pointer of pointer to the cs_equation_builder_t structure to free |
| cs_real_t* cs_equation_get_tmpbuf | ( | void | ) |
| size_t cs_equation_get_tmpbuf_size | ( | void | ) |
| cs_equation_builder_t* cs_equation_init_builder | ( | const cs_equation_param_t * | eqp, |
| const cs_mesh_t * | mesh | ||
| void cs_equation_init_properties | ( | const cs_equation_param_t * | eqp, |
| cs_real_t | t_eval, | ||
| [in,out] | cb | pointer to a cs_cell_builder_t structure (diffusion property is stored inside) |
| void cs_equation_init_properties_cw | ( | const cs_equation_param_t * | eqp, |
| const cs_flag_t | cell_flag, | ||
| cs_gnum_t cs_equation_prepare_system | ( | int | stride, |
| cs_lnum_t | x_size, | ||
| const cs_matrix_t * | matrix, | ||
| cs_range_set_t * | rset, | ||
| cs_real_t * | x, | ||
| cs_real_t * | b | ||
| [in] | stride | stride to apply to the range set operations |
| [in] | x_size | size of the vector unknows (scatter view) |
| [in] | matrix | pointer to a cs_matrix_t structure |
| [in] | rset | pointer to a range set structure |
| [in,out] | x | array of unknows (in: initial guess) |
| [in,out] | b | right-hand side |
inlinestatic |
| [in] | c_id | id of the cell to deal with |
| [in] | c_flag | flag related to this cell |
inlinestatic |
| void cs_equation_write_monitoring | ( | const char * | eqname, |
| const cs_equation_builder_t * | eqb | ||
| [in] | eqname | pointer to the name of the current equation |
