1 #ifndef __CS_SOURCE_TERM_H__ 2 #define __CS_SOURCE_TERM_H__ 49 #define CS_N_MAX_SOURCE_TERMS 8 // Max number of source terms in an equation 154 const int n_source_terms,
void cs_source_term_dcsd_q5o3_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it the given array of values...
Definition: cs_source_term.c:1593
cs_flag_t cs_source_term_get_flag(const cs_xdef_t *st)
Get metadata related to the given source term structure.
Definition: cs_source_term.c:457
void cs_source_term_pcvd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2098
void cs_source_term_hhovd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term for a cell and add it to the given array of values...
Definition: cs_source_term.c:2579
unsigned char cs_mask_t
Definition: cs_flag.h:152
void cs_source_term_dcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1220
void cs_source_term_compute_from_potential(cs_flag_t loc, const cs_xdef_t *source, cs_real_t time_eval, double *p_values[])
Compute the contribution related to a source term in the case of an input data which is a potential...
Definition: cs_source_term.c:923
void cs_source_term_pvsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:990
void cs_source_term_hhosd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2456
Definition: cs_defs.h:467
void cs_source_term_dcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1093
Set of local quantities and connectivities related to a mesh cell This is a key structure for all cel...
Definition: cs_cdo_local.h:146
void cs_source_term_dcsd_q10o2_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1392
Definition: cs_cdo_connect.h:74
void cs_source_term_dcsd_q1o1_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1312
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
void cs_source_term_pcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1801
cs_flag_t cs_source_term_init(cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
Initialize data to build the source terms.
Definition: cs_source_term.c:482
void cs_source_term_set_reduction(cs_xdef_t *st, cs_flag_t flag)
Set advanced parameters which are defined by default in a source term structure.
Definition: cs_source_term.c:402
void cs_source_term_set_shared_pointers(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_source_term.c:342
void cs_source_term_vcsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1745
void cs_source_term_pvsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1043
void cs_source_term_pcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1841
void cs_source_term_dcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1175
void cs_source_term_hhosd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2325
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:56
Definition: cs_xdef.h:126
cs_flag_t cs_source_term_set_default_flag(cs_param_space_scheme_t scheme)
Set the default flag related to a source term according to the numerical scheme chosen for discretizi...
Definition: cs_source_term.c:362
void cs_source_term_dcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1134
void cs_source_term_pcsd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1929
void cs_source_term_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2147
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition: cs_source_term.c:799
Definition: cs_param.h:125
void cs_source_term_compute_from_density(cs_flag_t loc, const cs_xdef_t *source, cs_real_t time_eval, double *p_values[])
Compute the contribution related to a source term in the case of an input data which is a density...
Definition: cs_source_term.c:857
void cs_source_term_pcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1883
void cs_source_term_pcvd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2280
void cs_source_term_vcsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:1692
void() cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.h:70
void cs_source_term_pcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.c:2055
