Build discrete Hodge operators. More...
#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <limits.h>#include <assert.h>#include "bft_mem.h"#include "cs_log.h"#include "cs_math.h"#include "cs_scheme_geometry.h"#include "cs_hodge.h"
| void | cs_hodge_fb_cost_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc Case of CDO face-based schemes. More... | |
| void | cs_hodge_fb_voro_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc Case of CDO face-based schemes. More... | |
| void | cs_hodge_vb_cost_get_iso_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. Case of CDO vertex-based schemes and isotropic property. More... | |
| void | cs_hodge_vb_cost_get_aniso_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. Case of CDO vertex-based schemes. More... | |
| void | cs_hodge_vb_cost_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| void | cs_hodge_vb_voro_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc Case of CDO vertex-based schemes. More... | |
| void | cs_hodge_vb_wbs_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS standing for Whitney Barycentric Subdivision (WBS) algo. More... | |
| void | cs_hodge_vcb_get_stiffness (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS standing for Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More... | |
| void | cs_hodge_fb_get_mass (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. More... | |
| void | cs_hodge_vcb_wbs_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the WBS algo. This function is specific for vertex+cell-based schemes. More... | |
| void | cs_hodge_vpcd_wbs_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes. More... | |
| void | cs_hodge_vpcd_voro_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes. More... | |
| void | cs_hodge_epfd_voro_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More... | |
| void | cs_hodge_epfd_cost_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More... | |
| void | cs_hodge_fped_voro_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual edges. This function is related to cell-based schemes. More... | |
| void | cs_hodge_fped_cost_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dual edges. This function is related to cell-based schemes. More... | |
| void | cs_hodge_edfp_voro_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal faces. This function is related to face-based schemes. More... | |
| void | cs_hodge_edfp_cost_get (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to primal faces. This function is related to face-based schemes. More... | |
| void | cs_hodge_edfp_cost_get_opt (const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb) |
| void | cs_hodge_matvec (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_param_hodge_t h_info, const cs_property_t *pty, const double in_vals[], cs_real_t t_eval, double result[]) |
| Compute cellwise a discrete hodge operator and multiple it with a vector. More... | |
| void | cs_hodge_compute_wbs_surfacic (const cs_face_mesh_t *fm, cs_sdm_t *hf) |
| Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney Barycentric Subdivision (WBS) algorithm. More... | |
| static const double | cs_hodge_vc_coef = 3./20 |
| void cs_hodge_compute_wbs_surfacic | ( | const cs_face_mesh_t * | fm, |
| cs_sdm_t * | hf | ||
| [in] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | hf | pointer to a cs_sdm_t structure to define |
| void cs_hodge_edfp_cost_get | ( | const cs_param_hodge_t | h_info, |
| [in] | h_info | pointer to a cs_param_hodge_t structure |
| [in] | cm | pointer to a cs_cell_mesh_t struct. |
| void cs_hodge_edfp_cost_get_opt | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_edfp_voro_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_epfd_cost_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_epfd_voro_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_fb_cost_get_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_fb_get_mass | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_fb_voro_get_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_fped_cost_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_fped_voro_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_matvec | ( | const cs_cdo_connect_t * | connect, |
| const cs_param_hodge_t | h_info, | ||
| const cs_property_t * | pty, | ||
| const double | in_vals[], | ||
| cs_real_t | t_eval, | ||
| double | result[] | ||
| [in] | h_info | cs_param_hodge_t structure |
| [in] | pty | pointer to a cs_property_t structure or NULL |
| [in] | in_vals | vector to multiply with the discrete Hodge op. |
| [in,out] | result | array storing the resulting matrix-vector product |
| void cs_hodge_vb_cost_get_aniso_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vb_cost_get_iso_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vb_cost_get_stiffness | ( | const cs_param_hodge_t | h_info, |
Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc Case of CDO vertex-based schemes.
| void cs_hodge_vb_voro_get_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vb_wbs_get_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vcb_get_stiffness | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vcb_wbs_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vpcd_voro_get | ( | const cs_param_hodge_t | h_info, |
| void cs_hodge_vpcd_wbs_get | ( | const cs_param_hodge_t | h_info, |
static |
