Assembly of local cellwise system into a cs_matrix_t structure through the cs_matrix_assembler_t and its related structures. More...
#include "cs_defs.h"#include <assert.h>#include "bft_error.h"#include "bft_mem.h"#include "cs_log.h"#include "cs_matrix_priv.h"#include "cs_matrix_assembler_priv.h"#include "cs_matrix_assembler.h"#include "cs_param_cdo.h"#include "cs_parall.h"#include "cs_sort.h"#include "cs_timer.h"#include "cs_equation_assemble.h"
| cs_matrix_structure_t * | cs_equation_get_matrix_structure (int flag) |
| Retrieve the pointer to a requested cs_matrix_structure_t structure. More... | |
| cs_equation_assemble_t * | cs_equation_assemble_get (int t_id) |
| Get a pointer to a cs_equation_assemble_t structure related to a given thread. More... | |
| void | cs_equation_assemble_init (const cs_cdo_connect_t *connect, cs_flag_t vb_flag, cs_flag_t vcb_flag, cs_flag_t fb_flag, cs_flag_t hho_flag) |
| Allocate and initialize matrix-related structures according to the type of discretization used for this simulation. More... | |
| void | cs_equation_assemble_finalize (void) |
| Free matrix-related structures used during the simulation. Display overall statistic about the assembly stage for CDO schemes. More... | |
| cs_equation_assembly_t * | cs_equation_assemble_set (cs_param_space_scheme_t scheme, int ma_id) |
| Define the function pointer used to assemble the algebraic system. More... | |
| void | cs_equation_assemble_matrix_seqt (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system Scalar-valued case. Sequential and with openMP threading. More... | |
| void | cs_equation_assemble_matrix_seqs (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system Scalar-valued case. Sequential and without openMP. More... | |
| void | cs_equation_assemble_eblock33_matrix_seqs (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Sequential run without openMP threading. More... | |
| void | cs_equation_assemble_eblock33_matrix_seqt (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Sequential run with openMP threading. More... | |
| void | cs_equation_assemble_eblock_matrix_seqs (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Sequential run without openMP threading. More... | |
| void | cs_equation_assemble_eblock_matrix_seqt (const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav) |
| Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Sequential run with openMP threading. More... | |
This function are specific to CDO schemes. Thus one can assume a more specific behavior in order to get a more optimzed version of the standard assembly process.
| void cs_equation_assemble_eblock33_matrix_seqs | ( | const cs_cell_sys_t * | csys, |
| const cs_range_set_t * | rset, | ||
| cs_equation_assemble_t * | eqa, | ||
| cs_matrix_assembler_values_t * | mav | ||
| [in] | csys | cellwise view of the algebraic system |
| [in] | rset | pointer to a cs_range_set_t structure |
| [in,out] | eqa | pointer to an equation assembly structure |
| [in,out] | mav | pointer to a matrix assembler structure |
| void cs_equation_assemble_eblock33_matrix_seqt | ( | const cs_cell_sys_t * | csys, |
| void cs_equation_assemble_eblock_matrix_seqs | ( | const cs_cell_sys_t * | csys, |
| void cs_equation_assemble_eblock_matrix_seqt | ( | const cs_cell_sys_t * | csys, |
| void cs_equation_assemble_finalize | ( | void | ) |
| cs_equation_assemble_t* cs_equation_assemble_get | ( | int | t_id | ) |
| [in] | t_id | id in the array of pointer |
| void cs_equation_assemble_init | ( | const cs_cdo_connect_t * | connect, |
| cs_flag_t | vb_flag, | ||
| cs_flag_t | vcb_flag, | ||
| cs_flag_t | fb_flag, | ||
| cs_flag_t | hho_flag | ||
| [in] | vb_flag | metadata for Vb schemes |
| [in] | vcb_flag | metadata for V+C schemes |
| [in] | fb_flag | metadata for Fb schemes |
| [in] | hho_flag | metadata for HHO schemes |
| void cs_equation_assemble_matrix_seqs | ( | const cs_cell_sys_t * | csys, |
Assemble a cellwise system into the global algebraic system Scalar-valued case. Sequential and without openMP threading.
| [in,out] | eqa | pointer to a matrix assembler buffers |
| void cs_equation_assemble_matrix_seqt | ( | const cs_cell_sys_t * | csys, |
| cs_equation_assembly_t* cs_equation_assemble_set | ( | cs_param_space_scheme_t | scheme, |
| int | ma_id | ||
| [in] | scheme | space discretization scheme |
| [in] | ma_id | id in the array of matrix assembler |
| cs_matrix_structure_t* cs_equation_get_matrix_structure | ( | int | flag | ) |
| [in] | flag_id | id in the array of matrix structures |
