1 #ifndef __CS_EQUATION_ASSEMBLE_H__ 2 #define __CS_EQUATION_ASSEMBLE_H__ cs_equation_assemble_t * cs_equation_assemble_get(int t_id)
Get a pointer to a cs_equation_assemble_t structure related to a given thread.
Definition: cs_equation_assemble.c:958
void() cs_equation_assembly_t(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Block or no block versions are handled...
Definition: cs_equation_assemble.h:71
void cs_equation_assemble_eblock33_matrix_mpis(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Parallel run without openMP threading.
void cs_equation_assemble_matrix_seqs(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Scalar-valued case. Sequential and withou...
Definition: cs_equation_assemble.c:1472
Definition: cs_defs.h:467
void cs_equation_assemble_matrix_mpis(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Scalar-valued case. Parallel without open...
void cs_equation_assemble_eblock_matrix_seqs(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Sequential run without openMP threading.
Definition: cs_equation_assemble.c:1850
struct _cs_equation_assemble_t cs_equation_assemble_t
Definition: cs_equation_assemble.h:52
Definition: cs_cdo_connect.h:74
Definition: cs_cdo_local.h:93
void cs_equation_assemble_eblock33_matrix_seqt(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Sequential run with openMP threading.
Definition: cs_equation_assemble.c:1593
cs_equation_assembly_t * cs_equation_assemble_set(cs_param_space_scheme_t scheme, int ma_id)
Define the function pointer used to assemble the algebraic system.
Definition: cs_equation_assemble.c:1259
void cs_equation_assemble_matrix_seqt(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Scalar-valued case. Sequential and with o...
Definition: cs_equation_assemble.c:1423
Definition: cs_range_set.h:57
void cs_equation_assemble_eblock_matrix_mpit(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Parallel run with openMP threading.
void cs_equation_assemble_eblock33_matrix_mpit(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Parallel run with openMP threading.
cs_matrix_structure_t * cs_equation_get_matrix_structure(int flag)
Retrieve the pointer to a requested cs_matrix_structure_t structure.
Definition: cs_equation_assemble.c:935
void cs_equation_assemble_finalize(void)
Free matrix-related structures used during the simulation. Display overall statistic about the assemb...
Definition: cs_equation_assemble.c:1216
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
void cs_equation_assemble_matrix_mpit(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Scalar-valued case. Parallel and with ope...
void cs_equation_assemble_eblock_matrix_seqt(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Sequential run with openMP threading.
Definition: cs_equation_assemble.c:1930
Definition: cs_param.h:125
void cs_equation_assemble_init(const cs_cdo_connect_t *connect, cs_flag_t vb_flag, cs_flag_t vcb_flag, cs_flag_t fb_flag, cs_flag_t hho_flag)
Allocate and initialize matrix-related structures according to the type of discretization used for th...
Definition: cs_equation_assemble.c:981
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:86
void cs_equation_assemble_eblock33_matrix_seqs(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block 3x3 entries. Expand each row. Sequential run without openMP threading.
Definition: cs_equation_assemble.c:1517
void cs_equation_assemble_eblock_matrix_mpis(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block NxN entries. Expand each row. Parallel run without openMP threading.
