cs_matrix_priv.h
1 #ifndef __CS_MATRIX_PRIV_H__
2 #define __CS_MATRIX_PRIV_H__
5  * Private types for sparse matrix representation and operations.
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_matrix.h"
45  * Macro definitions
49  * Type definitions
51
52 /* Formats currently supported:
53  *
54  * - Native
55  * - Compressed Sparse Row (CSR)
56  * - Modified Compressed Sparse Row (MSR), with separate diagonal
57  * - Symmetric Compressed Sparse Row (CSR_SYM)
58  */
59
60 /*----------------------------------------------------------------------------
61  * Function pointer types
62  *----------------------------------------------------------------------------*/
63
64 typedef void
65 (cs_matrix_set_coeffs_t) (cs_matrix_t *matrix,
66  bool symmetric,
67  bool copy,
68  cs_lnum_t n_edges,
69  const cs_lnum_2_t *restrict edges,
70  const cs_real_t *restrict da,
71  const cs_real_t *restrict xa);
72
73 typedef void
74 (cs_matrix_release_coeffs_t) (cs_matrix_t *matrix);
75
76 typedef void
77 (cs_matrix_copy_diagonal_t) (const cs_matrix_t *matrix,
78  cs_real_t *restrict da);
79
80 typedef void
81 (cs_matrix_vector_product_t) (bool exclude_diag,
82  const cs_matrix_t *matrix,
83  const cs_real_t *restrict x,
84  cs_real_t *restrict y);
85
87  * Matrix types
88  *----------------------------------------------------------------------------*/
89
90 /* Native matrix structure representation */
91 /*----------------------------------------*/
92
93 /* Note: the members of this structure are already available through the top
94  * matrix structure, but are replicated here in case of future removal
95  * from the top structure (which would require computation/assignment of
96  * matrix coefficients in another form) */
97
98 typedef struct _cs_matrix_struct_native_t {
99
100  cs_lnum_t n_rows; /* Local number of rows */
101  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
102  cs_lnum_t n_edges; /* Local number of graph edges
103  (for extra-diagonal terms) */
104
105  /* Pointers to shared arrays */
106
107  const cs_lnum_2_t *edges; /* Edges (symmetric row <-> column)
108  connectivity */
109
110 } cs_matrix_struct_native_t;
111
112 /* Native matrix coefficients */
113 /*----------------------------*/
114
115 typedef struct _cs_matrix_coeff_native_t {
116
117  bool symmetric; /* Symmetry indicator */
118  int max_db_size; /* Current max allocated diag block size */
119  int max_eb_size; /* Current max allocated extradiag block size */
120
121  /* Pointers to possibly shared arrays */
122
123  const cs_real_t *da; /* Diagonal terms */
124  const cs_real_t *xa; /* Extra-diagonal terms */
125
126  /* Pointers to private arrays (NULL if shared) */
127
128  cs_real_t *_da; /* Diagonal terms */
129  cs_real_t *_xa; /* Extra-diagonal terms */
130
131 } cs_matrix_coeff_native_t;
132
133 /* CSR (Compressed Sparse Row) matrix structure representation */
134 /*-------------------------------------------------------------*/
135
136 typedef struct _cs_matrix_struct_csr_t {
137
138  cs_lnum_t n_rows; /* Local number of rows */
139  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
140
141  /* Pointers to structure arrays and info (row_index, col_id) */
142
143  bool have_diag; /* Has non-zero diagonal */
144  bool direct_assembly; /* True if each value corresponds to
145  a unique face ; false if multiple
146  faces contribute to the same
147  value (i.e. we have split faces) */
148
149  const cs_lnum_t *row_index; /* Pointer to row index (0 to n-1) */
150  const cs_lnum_t *col_id; /* Pointer to column id (0 to n-1) */
151
152  cs_lnum_t *_row_index; /* Row index (0 to n-1), if owner */
153  cs_lnum_t *_col_id; /* Column id (0 to n-1), if owner */
154
155 } cs_matrix_struct_csr_t;
156
157 /* CSR matrix coefficients representation */
158 /*----------------------------------------*/
159
160 typedef struct _cs_matrix_coeff_csr_t {
161
162  /* Pointers to possibly shared arrays */
163
164  const cs_real_t *val; /* Matrix coefficients */
165
166  /* Pointers to private arrays (NULL if shared) */
167
168  cs_real_t *_val; /* Diagonal matrix coefficients */
169
170  /* Pointers to auxiliary arrays used for queries */
171
172  const cs_real_t *d_val; /* Pointer to diagonal matrix
173  coefficients, if queried */
174  cs_real_t *_d_val; /* Diagonal matrix coefficients,
175  if queried */
176
177 } cs_matrix_coeff_csr_t;
178
179 /* CSR_SYM (Symmetric Compressed Sparse Row) matrix structure representation */
180 /*---------------------------------------------------------------------------*/
181
182 typedef struct _cs_matrix_struct_csr_sym_t {
183
184  cs_lnum_t n_rows; /* Local number of rows */
185  cs_lnum_t n_cols; /* Local number of columns
186  (> n_rows in case of ghost columns) */
187
188  /* Pointers to structure arrays and info (row_index, col_id) */
189
190  bool have_diag; /* Has non-zero diagonal */
191  bool direct_assembly; /* True if each value corresponds to
192  a unique face ; false if multiple
193  faces contribute to the same
194  value (i.e. we have split faces) */
195
196  cs_lnum_t *row_index; /* Row index (0 to n-1) */
197  cs_lnum_t *col_id; /* Column id (0 to n-1) */
198
199 } cs_matrix_struct_csr_sym_t;
200
201 /* symmetric CSR matrix coefficients representation */
202 /*--------------------------------------------------*/
203
204 typedef struct _cs_matrix_coeff_csr_sym_t {
205
206  cs_real_t *val; /* Matrix coefficients */
207
208  /* Pointers to auxiliary arrays used for queries */
209
210  const cs_real_t *d_val; /* Pointer to diagonal matrix
211  coefficients, if queried */
212  cs_real_t *_d_val; /* Diagonal matrix coefficients,
213  if queried */
214
215 } cs_matrix_coeff_csr_sym_t;
216
217 /* MSR matrix coefficients representation */
218 /*----------------------------------------*/
219
220 typedef struct _cs_matrix_coeff_msr_t {
221
222  int max_db_size; /* Current max allocated block size */
223  int max_eb_size; /* Current max allocated extradiag
224  block size */
225
226  /* Pointers to possibly shared arrays */
227
228  const cs_real_t *d_val; /* Diagonal matrix coefficients */
229  const cs_real_t *x_val; /* Extra-diagonal matrix coefficients */
230
231  /* Pointers to private arrays (NULL if shared) */
232
233  cs_real_t *_d_val; /* Diagonal matrix coefficients */
234  cs_real_t *_x_val; /* Extra-diagonal matrix coefficients */
235
236 } cs_matrix_coeff_msr_t;
237
238 /* Matrix structure (representation-independent part) */
239 /*----------------------------------------------------*/
240
241 struct _cs_matrix_structure_t {
242
243  cs_matrix_type_t type; /* Matrix storage and definition type */
244
245  cs_lnum_t n_rows; /* Local number of rows */
246  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
247
248  void *structure; /* Matrix structure */
249
250  /* Pointers to shared arrays from mesh structure
251  (face->cell connectivity for coefficient assignment,
252  local->local cell numbering for future info or renumbering,
253  and halo) */
254
255  const cs_halo_t *halo; /* Parallel or periodic halo */
256  const cs_numbering_t *numbering; /* Vectorization or thread-related
257  numbering information */
258
259  const cs_matrix_assembler_t *assembler; /* Associated matrix assembler */
260 };
261
262 /* Structure associated with Matrix (representation-independent part) */
263 /*--------------------------------------------------------------------*/
264
265 struct _cs_matrix_t {
266
267  cs_matrix_type_t type; /* Matrix storage and definition type */
268
269  cs_lnum_t n_rows; /* Local number of rows */
270  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
271
272  cs_matrix_fill_type_t fill_type; /* Matrix fill type */
273
274  bool symmetric; /* true if coefficients are symmetric */
275
276  cs_lnum_t db_size[4]; /* Diag Block size, including padding:
277  0: useful block size
278  1: vector block extents
279  2: matrix line extents
280  3: matrix line*column extents */
281
282  cs_lnum_t eb_size[4]; /* Extradiag block size, including padding:
283  0: useful block size
284  1: vector block extents
285  2: matrix line extents
286  3: matrix line*column extents */
287
288  /* Pointer to shared structure */
289
290  const void *structure; /* Possibly shared matrix structure */
291  void *_structure; /* Private matrix structure */
292
293  /* Pointers to arrays possibly shared from mesh structure
294  (graph edges: face->cell connectivity for coefficient assignment,
295  rows: local->local cell numbering for future info or renumbering,
296  and halo) */
297
298  const cs_halo_t *halo; /* Parallel or periodic halo */
299  const cs_numbering_t *numbering; /* Vectorization or thread-related
300  numbering information */
301
302  const cs_matrix_assembler_t *assembler; /* Associated matrix assembler */
303
304  /* Pointer to shared arrays from coefficient assignment from
305  "native" type. This should be removed in the future, but requires
306  removing the dependency to the native structure in the multigrid
307  code first. */
308
309  const cs_real_t *xa; /* Extra-diagonal terms */
310
311  /* Pointer to private data */
312
313  void *coeffs; /* Matrix coefficients */
314
315  /* Function pointers */
316
317  cs_matrix_set_coeffs_t *set_coefficients;
318  cs_matrix_release_coeffs_t *release_coefficients;
319  cs_matrix_copy_diagonal_t *copy_diagonal;
320
321  /* Function pointer arrays, with CS_MATRIX_N_FILL_TYPES variants:
322  fill_type*2 + exclude_diagonal_flag */
323
324  cs_matrix_vector_product_t *vector_multiply[CS_MATRIX_N_FILL_TYPES][2];
325
326 };
327
328 /* Structure used for tuning variants */
329 /*------------------------------------*/
330
331 struct _cs_matrix_variant_t {
332
333  char name[32]; /* Variant name */
334
335  cs_matrix_type_t type; /* Matrix storage and definition type */
336
337  /* Function pointer arrays, with variants:
338  fill_type + exclude_diagonal_flag */
339
340  cs_matrix_vector_product_t *vector_multiply[CS_MATRIX_N_FILL_TYPES][2];
341
342  /* Measured structure creation cost, or -1 otherwise */
343
344  double matrix_create_cost;
345
346  /* Measured assignment costs for each available fill type, or -1 otherwise */
347
348  double matrix_assign_cost[CS_MATRIX_N_FILL_TYPES];
349
350  /* Measured operation costs for each available operation, or -1 otherwise
351  fill_type*2 + exclude_diagonal_flag */
352
353  double matrix_vector_cost[CS_MATRIX_N_FILL_TYPES][2][2];
354
355 };
356
359 /*=============================================================================
360  * Semi-private function prototypes
361  *============================================================================*/
362
363 /*----------------------------------------------------------------------------
364  * Create CSR matrix coefficients.
365  *
366  * returns:
367  * pointer to allocated CSR coefficients structure.
368  *----------------------------------------------------------------------------*/
369
370 cs_matrix_coeff_csr_t *
372
373 /*----------------------------------------------------------------------------
374  * Destroy CSR matrix coefficients.
375  *
376  * parameters:
377  * coeff <-> Pointer to CSR matrix coefficients pointer
378  *----------------------------------------------------------------------------*/
379
380 void
381 cs_matrix_destroy_coeff_csr(cs_matrix_coeff_csr_t **coeff);
382
383 /*----------------------------------------------------------------------------
384  * Release shared CSR matrix coefficients.
385  *
386  * parameters:
387  * matrix <-- Pointer to matrix structure
388  *----------------------------------------------------------------------------*/
389
390 void
392
393 /*----------------------------------------------------------------------------
394  * Copy diagonal of CSR matrix.
395  *
396  * parameters:
397  * matrix <-- Pointer to matrix structure
398  * da --> Diagonal (pre-allocated, size: n_rows)
399  *----------------------------------------------------------------------------*/
400
401 void
403  cs_real_t *restrict da);
404
405 /*----------------------------------------------------------------------------
406  * Destroy CSR matrix structure.
407  *
408  * parameters:
409  * matrix <-> Pointer to CSR matrix structure pointer
410  *----------------------------------------------------------------------------*/
411
412 void
413 cs_matrix_destroy_struct_csr(cs_matrix_struct_csr_t **matrix);
414
415 /*----------------------------------------------------------------------------
416  * Local matrix.vector product y = A.x with CSR matrix.
417  *
418  * parameters:
419  * exclude_diag <-- exclude diagonal if true
420  * matrix <-- Pointer to matrix structure
421  * x <-- Multipliying vector values
422  * y --> Resulting vector
423  *----------------------------------------------------------------------------*/
424
425 void
426 cs_matrix_vec_p_l_csr(bool exclude_diag,
427  const cs_matrix_t *matrix,
428  const cs_real_t *restrict x,
429  cs_real_t *restrict y);
430
431 #if defined (HAVE_MKL)
432 /*----------------------------------------------------------------------------
433  * Local matrix.vector product y = A.x with MSR matrix, using MKL
434  *
435  * parameters:
436  * exclude_diag <-- exclude diagonal if true
437  * matrix <-- Pointer to matrix structure
438  * x <-- Multipliying vector values
439  * y --> Resulting vector
440  *----------------------------------------------------------------------------*/
441
442 void
443 cs_matrix_vec_p_l_csr_mkl(bool exclude_diag,
444  const cs_matrix_t *matrix,
445  const cs_real_t *restrict x,
446  cs_real_t *restrict y);
447
448 #endif /* defined (HAVE_MKL) */
449
450 /*----------------------------------------------------------------------------
451  * Copy diagonal of native or MSR matrix.
452  *
453  * parameters:
454  * matrix <-- Pointer to matrix structure
455  * da --> Diagonal (pre-allocated, size: n_cols)
456  *----------------------------------------------------------------------------*/
457
458 void
460  cs_real_t *restrict da);
461
462 /*----------------------------------------------------------------------------
463  * Create MSR matrix coefficients.
464  *
465  * returns:
466  * pointer to allocated MSR coefficients structure.
467  *----------------------------------------------------------------------------*/
468
469 cs_matrix_coeff_msr_t *
471
472 /*----------------------------------------------------------------------------
473  * Release shared MSR matrix coefficients.
474  *
475  * parameters:
476  * matrix <-- Pointer to matrix structure
477  *----------------------------------------------------------------------------*/
478
479 void
481
482 /*----------------------------------------------------------------------------
483  * Local matrix.vector product y = A.x with MSR matrix.
484  *
485  * parameters:
486  * exclude_diag <-- exclude diagonal if true
487  * matrix <-- Pointer to matrix structure
488  * x <-- Multipliying vector values
489  * y --> Resulting vector
490  *----------------------------------------------------------------------------*/
491
492 void
493 cs_matrix_vec_p_l_msr(bool exclude_diag,
494  const cs_matrix_t *matrix,
495  const cs_real_t *restrict x,
496  cs_real_t *restrict y);
497
498 #if defined (HAVE_MKL)
499 /*----------------------------------------------------------------------------
500  * Local matrix.vector product y = A.x with MSR matrix, using MKL
501  *
502  * parameters:
503  * exclude_diag <-- exclude diagonal if true
504  * matrix <-- Pointer to matrix structure
505  * x <-- Multipliying vector values
506  * y --> Resulting vector
507  *----------------------------------------------------------------------------*/
508
509 void
510 cs_matrix_vec_p_l_msr_mkl(bool exclude_diag,
511  const cs_matrix_t *matrix,
512  const cs_real_t *restrict x,
513  cs_real_t *restrict y);
514 #endif /* defined (HAVE_MKL) */
515
516 /*----------------------------------------------------------------------------*/
517
519
520 #endif /* __CS_MATRIX_PRIV_H__ */
#define restrict
Definition: cs_defs.h:127
void cs_matrix_copy_diagonal_separate(const cs_matrix_t *matrix, cs_real_t *restrict da)
cs_matrix_coeff_csr_t * cs_matrix_create_coeff_csr(void)
Definition: cs_defs.h:467
Definition: cs_matrix.h:80
Definition: cs_halo.h:71
void cs_matrix_copy_diagonal_csr(const cs_matrix_t *matrix, cs_real_t *restrict da)
void cs_matrix_release_coeffs_csr(cs_matrix_t *matrix)
Definition: cs_defs.h:302
void cs_matrix_release_coeffs_msr(cs_matrix_t *matrix)
Definition: cs_matrix.h:90
void cs_matrix_destroy_coeff_csr(cs_matrix_coeff_csr_t **coeff)
cs_matrix_coeff_msr_t * cs_matrix_create_coeff_msr(void)
void cs_matrix_vec_p_l_msr(bool exclude_diag, const cs_matrix_t *matrix, const cs_real_t *restrict x, cs_real_t *restrict y)
void cs_matrix_vec_p_l_csr(bool exclude_diag, const cs_matrix_t *matrix, const cs_real_t *restrict x, cs_real_t *restrict y)
cs_matrix_type_t
Definition: cs_matrix.h:55
int cs_lnum_2_t[2]
Definition: cs_defs.h:308
Definition: cs_defs.h:298
Definition: cs_defs.h:468
Definition: cs_numbering.h:83
void cs_matrix_destroy_struct_csr(cs_matrix_struct_csr_t **matrix)
Definition: cs_matrix.h:67
