#include "cs_base.h"#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_param.h"#include "cs_xdef.h"
| void | cs_evaluate_set_shared_pointers (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect) |
| void | cs_evaluate_density_by_analytic (cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
| Compute the value related to each DoF in the case of a density field The value defined by the analytic function is by unity of volume. More... | |
| void | cs_evaluate_density_by_value (cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t retval[]) |
| Evaluate the quantity defined by a value in the case of a density field for all the degrees of freedom Accessor to the value is by unit of volume. More... | |
| void | cs_evaluate_potential_by_analytic (cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
| Evaluate the quantity attached to a potential field for all the DoFs when the definition relies on an analytic expression. More... | |
| void | cs_evaluate_potential_by_qov (cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t vvals[], cs_real_t wvals[]) |
| Define a value to each DoF in the case of a potential field in order to put a given quantity inside the volume associated to the zone related to the given definition wvals may be NULL. More... | |
| void | cs_evaluate_potential_by_value (cs_flag_t dof_flag, const cs_xdef_t *def, cs_real_t retval[]) |
| Evaluate the quantity attached to a potential field for all the DoFs. More... | |
| void | cs_evaluate_average_on_faces_by_value (const cs_xdef_t *def, cs_real_t retval[]) |
| Evaluate the average of a function on the faces. More... | |
| void | cs_evaluate_average_on_faces_by_analytic (const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
| Evaluate the average of a function on the faces Warning: retval has to be initialize before calling this function. More... | |
| void | cs_evaluate_average_on_cells_by_value (const cs_xdef_t *def, cs_real_t retval[]) |
| Evaluate the average of a function on the cells. More... | |
| void | cs_evaluate_average_on_cells_by_array (const cs_xdef_t *def, cs_real_t retval[]) |
| void | cs_evaluate_average_on_cells_by_analytic (const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
| Evaluate the average of a function on the cells Warning: retval has to be initialize before calling this function. More... | |
| cs_real_t | cs_evaluate_scal_domain_integral_by_array (cs_flag_t array_loc, const cs_real_t *array_val) |
| Evaluate the integral over the full computational domain of a quantity defined by an array. More... | |
| static void | cs_evaluate_average_on_faces (const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
| static void | cs_evaluate_average_on_cells (const cs_xdef_t *def, cs_real_t time_eval, cs_real_t retval[]) |
inlinestatic |
| [in] | def | pointer to a cs_xdef_t pointer |
| [in,out] | retval | pointer to the computed values |
| void cs_evaluate_average_on_cells_by_analytic | ( | const cs_xdef_t * | def, |
| cs_real_t | time_eval, | ||
| cs_real_t | retval[] | ||
inlinestatic |
| void cs_evaluate_average_on_faces_by_analytic | ( | const cs_xdef_t * | def, |
| void cs_evaluate_density_by_analytic | ( | cs_flag_t | dof_flag, |
| const cs_xdef_t * | def, | ||
| [in] | dof_flag | indicate where the evaluation has to be done |
| void cs_evaluate_potential_by_analytic | ( | cs_flag_t | dof_flag, |
| void cs_evaluate_potential_by_qov | ( | cs_flag_t | dof_flag, |
| cs_real_t | vvals[], | ||
| cs_real_t | wvals[] | ||
| [in,out] | vvals | pointer to the first array of computed values |
| [in,out] | wvals | pointer to the second array of computed values |
| void cs_evaluate_potential_by_value | ( | cs_flag_t | dof_flag, |
| cs_real_t cs_evaluate_scal_domain_integral_by_array | ( | cs_flag_t | array_loc, |
| const cs_real_t * | array_val | ||
| [in] | array_loc | flag indicating where are located values |
| [in] | array_val | array of values |
| void cs_evaluate_set_shared_pointers | ( | const cs_cdo_quantities_t * | quant, |
