cs_cdovb_priv.h
1 #ifndef __CS_CDOVB_PRIV_H__
2 #define __CS_CDOVB_PRIV_H__
5  * Definition of cs_cdovb_scaleq_t and cs_cdovb_vecteq structures
29  * Local headers
32 #include "cs_defs.h"
33 #include "cs_hodge.h"
34 #include "cs_cdo_advection.h"
35 #include "cs_equation_assemble.h"
36 #include "cs_equation_bc.h"
50  * Macro definitions
52
54  * Type definitions
56
57 /*=============================================================================
58  * Structure definitions
59  *============================================================================*/
60
61 /* Algebraic system for CDO vertex-based discretization */
62
63 struct _cs_cdovb_t {
64
65  /* Ids related to the variable field and to the boundary flux field */
68
69  /* System size */
71
72  /* Array storing the value arising from the contribution of all source
73  terms */
75
76  /* Array for extra-operations */
77  cs_real_t *cell_values; /* NULL if not requested */
78
79  /* Assembly process */
81
82  /* Boundary conditions */
87
88  /* Pointer of function to build the diffusion term */
90
91  /* Pointer of function to build the advection term */
94
95  /* If one needs to build a local hodge op. for time and reaction */
98
99 };
100
101 /*============================================================================
102  * Public function prototypes
103  *============================================================================*/
104
105 /*----------------------------------------------------------------------------*/
106
108
109 #endif /* __CS_CDOVB_PRIV_H__ */
void() cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the advection operator in CDO vertex-based (or vertex+cell-based) sch...
Definition: cs_cdo_advection.h:122
cs_cdovb_advection_bc_t * add_advection_bc
Definition: cs_cdovb_priv.h:93
void() cs_equation_assembly_t(const cs_cell_sys_t *csys, const cs_range_set_t *rset, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system Block or no block versions are handled...
Definition: cs_equation_assemble.h:71
Definition: cs_cdovb_priv.h:63
cs_hodge_t * get_mass_matrix
Definition: cs_cdovb_priv.h:97
Definition: cs_defs.h:467
int var_field_id
Definition: cs_cdovb_priv.h:66
cs_param_hodge_t hdg_mass
Definition: cs_cdovb_priv.h:96
cs_cdo_enforce_bc_t * enforce_sliding
Definition: cs_cdovb_priv.h:86
Definition: cs_defs.h:302
cs_flag_t * vtx_bc_flag
Definition: cs_cdovb_priv.h:83
cs_lnum_t n_dofs
Definition: cs_cdovb_priv.h:70
int bflux_field_id
Definition: cs_cdovb_priv.h:67
cs_real_t * source_terms
Definition: cs_cdovb_priv.h:74
cs_cdovb_advection_t * get_advection_matrix
Definition: cs_cdovb_priv.h:92
cs_cdo_enforce_bc_t * enforce_robin_bc
Definition: cs_cdovb_priv.h:85
cs_hodge_t * get_stiffness_matrix
Definition: cs_cdovb_priv.h:89
cs_real_t * cell_values
Definition: cs_cdovb_priv.h:77
Definition: cs_defs.h:298
void() cs_hodge_t(const cs_param_hodge_t h_info, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
Build a local operator for a given cell (stored in cb->hdg for a discrete Hodge operator or in cb->lo...
Definition: cs_hodge.h:63
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:86
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
void() cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme. The local matrix related to this operator is stored in cb->loc.
Definition: cs_cdo_advection.h:101
Definition: cs_param_cdo.h:129
cs_equation_assembly_t * assemble
Definition: cs_cdovb_priv.h:80
cs_cdo_enforce_bc_t * enforce_dirichlet
Definition: cs_cdovb_priv.h:84
