#include "cs_advection_field.h"#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_equation_param.h"#include "cs_property.h"
| typedef void() | cs_cdofb_advection_t(const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Define the local convection operator in CDO-Fb schemes. More... | |
| typedef void() | cs_cdofb_advection_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Add the contribution of the boundary conditions to the local system in CDO-Fb schemes. More... | |
| typedef void() | cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme. The local matrix related to this operator is stored in cb->loc. More... | |
| typedef void() | cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Compute the BC contribution for the advection operator in CDO vertex-based (or vertex+cell-based) schemes. More... | |
| void | cs_cdo_advection_set_cip_coef (double new_value) |
| Set the value of the stabilization coefficient used in CIP scheme. More... | |
| double | cs_cdo_advection_get_cip_coef (void) |
| Get the value of the stabilization coefficient used in CIP scheme. More... | |
| void | cs_cdofb_advection_build (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cdofb_advection_t *build_func, cs_cell_builder_t *cb) |
| Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_fb_bc (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Add the contribution of the boundary conditions to the local system in CDO-Fb schemes (without diffusion) More... | |
| void | cs_cdo_advection_fb_bc_wdi (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Add the contribution of the boundary conditions to the local system in CDO-Fb schemes (with a diffusion term activated) More... | |
| void | cs_cdo_advection_fb_bc_v (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Add the contribution of the boundary conditions to the local system in CDO-Fb schemes (without diffusion). Vector-valued case. More... | |
| void | cs_cdo_advection_fb_bc_wdi_v (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Add the contribution of the boundary conditions to the local system in CDO-Fb schemes (with a diffusion term activated). Vector-valued case. More... | |
| void | cs_cdo_advection_fb_upwcsv (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Compute the convection operator attached to a cell with a CDO face-based scheme in the conservative formulation. More... | |
| void | cs_cdo_advection_fb_upwcsv_di (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| void | cs_cdo_advection_fb_upwnoc (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| Compute the convection operator attached to a cell with a CDO face-based scheme in the non-conservative formulation. More... | |
| void | cs_cdo_advection_fb_upwnoc_di (const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| void | cs_cdo_advection_vb_upwcsv_di (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when diffusion is activated and an upwind scheme and a conservative formulation is used The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vb_upwcsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion and an upwind scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vb_cencsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vb_mcucsv (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a mixed centered/upwind scheme with a conservative formulation is used. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vb_upwnoc_di (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| void | cs_cdo_advection_vb_upwnoc (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion when an upwind scheme and a conservative formulation is used. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vb_cennoc (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered scheme and a non-conservative formulation is used. The local matrix related to this operator is stored in cb->loc. More... | |
| void | cs_cdo_advection_vcb_cw_cst (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advection field is cellwise constant. More... | |
| void | cs_cdo_advection_vcb (const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme. More... | |
| void | cs_cdo_advection_vb_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Compute the BC contribution for the convection operator. More... | |
| void | cs_cdo_advection_vcb_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Compute the BC contribution for the convection operator with CDO V+C schemes. More... | |
| void | cs_cdo_advection_cell_upwind_coef (const cs_cdo_quantities_t *cdoq, cs_param_advection_scheme_t scheme, cs_real_t coefval[]) |
| Compute the value of the upwinding coefficient in each cell knowing the related Peclet number. More... | |
| typedef void() cs_cdofb_advection_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| [in,out] | cb | pointer to a convection builder structure |
| [in,out] | csys | cell-wise structure storing the local system |
| typedef void() cs_cdofb_advection_t(const cs_cell_mesh_t *cm, const cs_real_t fluxes[], cs_sdm_t *adv) |
| [in] | fluxes | array of advctive fluxes on primal faces |
| [in,out] | adv | pointer to a cs_sdm_t structure to update |
| typedef void() cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| [in] | t_eval | time at which one evaluates the advection field |
| [in,out] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | b | pointer to a convection builder structure |
| typedef void() cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb) |
| void cs_cdo_advection_cell_upwind_coef | ( | const cs_cdo_quantities_t * | cdoq, |
| cs_param_advection_scheme_t | scheme, | ||
| cs_real_t | coefval[] | ||
| [in] | cdoq | pointer to the cdo quantities structure |
| [in] | scheme | type of scheme used for the advection term |
| [in,out] | coefval | pointer to the pointer of real numbers to fill in: Peclet number in each cell out: value of the upwind coefficient |
| void cs_cdo_advection_fb_bc | ( | const cs_equation_param_t * | eqp, |
| cs_cell_sys_t * | csys | ||
| void cs_cdo_advection_fb_bc_v | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_fb_bc_wdi | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_fb_bc_wdi_v | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_fb_upwcsv | ( | const cs_cell_mesh_t * | cm, |
| const cs_real_t | fluxes[], | ||
| cs_sdm_t * | adv | ||
| [in] | fluxes | array of computed fluxes across cell faces |
| [in,out] | adv | pointer to a local matrix to build |
| void cs_cdo_advection_fb_upwcsv_di | ( | const cs_cell_mesh_t * | cm, |
| void cs_cdo_advection_fb_upwnoc | ( | const cs_cell_mesh_t * | cm, |
| [in,out] | cb | pointer to a local matrix to build |
| void cs_cdo_advection_fb_upwnoc_di | ( | const cs_cell_mesh_t * | cm, |
| double cs_cdo_advection_get_cip_coef | ( | void | ) |
| void cs_cdo_advection_set_cip_coef | ( | double | new_value | ) |
| [in] | new_value | value of the stabilization coefficient |
(DOXYGEN_SHOULD_SKIP_THIS)
| void cs_cdo_advection_vb_bc | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t | t_eval, | ||
| cs_face_mesh_t * | fm, | ||
| void cs_cdo_advection_vb_cencsv | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_cennoc | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_mcucsv | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwcsv | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwcsv_di | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwnoc | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vb_upwnoc_di | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vcb | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_advection_vcb_bc | ( | const cs_cell_mesh_t * | cm, |
| void cs_cdo_advection_vcb_cw_cst | ( | const cs_equation_param_t * | eqp, |
| void cs_cdofb_advection_build | ( | const cs_equation_param_t * | eqp, |
| cs_cdofb_advection_t * | build_func, | ||
| [in] | build_func | pointer to the function building the system |
