Main functions dedicated to soil management in groundwater flows when using CDO schemes. More...
#include <assert.h>#include <ctype.h>#include <float.h>#include <math.h>#include <stdlib.h>#include <string.h>#include <bft_mem.h>#include "cs_field.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_parall.h"#include "cs_param.h"#include "cs_post.h"#include "cs_prototypes.h"#include "cs_reco.h"#include "cs_volume_zone.h"#include "cs_gwf_soil.h"
Macros | |
| #define | CS_GWF_SOIL_DBG 0 |
| cs_gwf_soil_t * | cs_gwf_soil_add (const char *z_name, cs_gwf_soil_hydraulic_model_t model) |
| Create and add a new cs_gwf_soil_t structure. A first initialization of all members by default is performed. More... | |
| void | cs_gwf_soil_free_all (void) |
| Free all cs_gwf_soil_t structures. More... | |
| int | cs_gwf_get_n_soils (void) |
| Get the number of allocated soils. More... | |
| cs_gwf_soil_t * | cs_gwf_soil_by_id (int id) |
| Retrieve a soil structure from its id. More... | |
| cs_gwf_soil_t * | cs_gwf_soil_by_name (const char *name) |
| Retrieve a soil structure from its name. More... | |
| cs_real_t | cs_gwf_soil_get_bulk_density (const cs_gwf_soil_t *soil) |
| Retrieve the bulk density associated to the given soil structure. More... | |
| void | cs_gwf_set_iso_saturated_soil (cs_gwf_soil_t *soil, double k_s, double theta_s, double rho) |
| Set a soil defined by a saturated hydraulic model and attached to an isotropic permeability. More... | |
| void | cs_gwf_set_aniso_saturated_soil (cs_gwf_soil_t *soil, double *k_s, double theta_s, double rho) |
| void | cs_gwf_set_iso_genuchten_soil (cs_gwf_soil_t *soil, double k_s, double theta_s, double theta_r, double rho) |
| Set a soil defined by a Van Genuchten hydraulic model and attached to an anisotropic permeability. More... | |
| void | cs_gwf_set_aniso_genuchten_soil (cs_gwf_soil_t *soil, double *k_s, double theta_s, double theta_r, double rho) |
| void | cs_gwf_set_user_soil (cs_gwf_soil_t *soil, void *input, cs_gwf_soil_update_t *update_func, cs_gwf_soil_finalize_t *free_func) |
| Set a soil defined by a user-defined hydraulic model and attached to an anisotropic permeability. More... | |
| void | cs_gwf_soil_set_all_saturated (cs_property_t *permeability, cs_property_t *moisture_content, cs_field_t *moisture_field) |
| Set the properties of the groundwater flow module all soils are considered as saturated. More... | |
| void | cs_gwf_build_cell2soil (cs_lnum_t n_cells) |
| Build an array storing the associated soil for each cell. More... | |
| const short int * | cs_gwf_get_cell2soil (void) |
| Get the array storing the associated soil for each cell. More... | |
| void | cs_gwf_soil_set_by_field (cs_property_t *permeability, cs_field_t *permea_field, cs_property_t *moisture_content, cs_field_t *moisture_field, cs_property_t *soil_capacity, cs_field_t *capacity_field) |
| Set the properties of the groundwater flow module thanks to cs_field_t structure. The consequence is that the related cs_property_t structure relies on only one definition (i.e. for the whole mesh). Fields are updated by using the update function pointer associated to each soil. More... | |
| void | cs_gwf_soil_log_setup (void) |
| Summary of the settings related to all cs_gwf_soil_t structures. More... | |
| #define CS_GWF_SOIL_DBG 0 |
| void cs_gwf_build_cell2soil | ( | cs_lnum_t | n_cells | ) |
| const short int* cs_gwf_get_cell2soil | ( | void | ) |
| int cs_gwf_get_n_soils | ( | void | ) |
| void cs_gwf_set_aniso_genuchten_soil | ( | cs_gwf_soil_t * | soil, |
| double * | k_s, | ||
| double | theta_s, | ||
| double | theta_r, | ||
| double | rho | ||
| [in,out] | soil | pointer to a cs_gwf_soil_t structure |
| [in] | k_s | value of the anisotropic saturated permeability |
| [in] | theta_s | saturated moisture |
| [in] | theta_r | residual moisture |
| [in] | rho | bulk density |
| void cs_gwf_set_aniso_saturated_soil | ( | cs_gwf_soil_t * | soil, |
| double | rho | ||
| void cs_gwf_set_iso_genuchten_soil | ( | cs_gwf_soil_t * | soil, |
| double | k_s, | ||
| double | rho | ||
| [in] | k_s | value of the isotropic saturated permeability |
| void cs_gwf_set_iso_saturated_soil | ( | cs_gwf_soil_t * | soil, |
| double | k_s, | ||
| double | rho | ||
| [in] | k_s | value of the saturated permeability |
| void cs_gwf_set_user_soil | ( | cs_gwf_soil_t * | soil, |
| void * | input, | ||
| cs_gwf_soil_update_t * | update_func, | ||
| cs_gwf_soil_finalize_t * | free_func | ||
| [in] | input | pointer to a structure cast on-the-fly |
| [in] | update_func | pointer to the function used for updating |
| [in] | free_func | pointer to the function used for finalizing |
| cs_gwf_soil_t* cs_gwf_soil_add | ( | const char * | z_name, |
| cs_gwf_soil_hydraulic_model_t | model | ||
| [in] | z_name | name of the volume zone corresponding to the soil |
| [in] | model | type of modeling for the hydraulic behavior |
| cs_gwf_soil_t* cs_gwf_soil_by_id | ( | int | id | ) |
| [in] | id | id to look for |
| cs_gwf_soil_t* cs_gwf_soil_by_name | ( | const char * | name | ) |
| [in] | name | name to look for |
| void cs_gwf_soil_free_all | ( | void | ) |
| cs_real_t cs_gwf_soil_get_bulk_density | ( | const cs_gwf_soil_t * | soil | ) |
| [in] | soil | pointer to a cs_gwf_soil_t structure |
| void cs_gwf_soil_log_setup | ( | void | ) |
| void cs_gwf_soil_set_all_saturated | ( | cs_property_t * | permeability, |
| cs_property_t * | moisture_content, | ||
| cs_field_t * | moisture_field | ||
| [in,out] | permeability | pointer to a cs_property_t structure |
| [in,out] | moisture_content | pointer to a cs_property_t structure |
| [in,out] | moisture_field | pointer to a cs_field_t structure |
| void cs_gwf_soil_set_by_field | ( | cs_property_t * | permeability, |
| cs_field_t * | permea_field, | ||
| cs_field_t * | moisture_field, | ||
| cs_property_t * | soil_capacity, | ||
| cs_field_t * | capacity_field | ||
| [in] | permea_field | pointer to a cs_field_t structure |
| [in] | moisture_field | pointer to a cs_field_t structure |
| [in,out] | soil_capacity | pointer to a cs_property_t structure |
| [in] | capacity_field | pointer to a cs_field_t structure |
