1 #ifndef __CS_DOMAIN_SETUP_H__ 2 #define __CS_DOMAIN_SETUP_H__
Definition: cs_defs.h:467
void cs_domain_def_time_step_by_value(cs_domain_t *domain, double dt)
Define the value of the time step.
Definition: cs_domain_setup.c:408
void cs_domain_init_cdo_structures(cs_domain_t *domain)
After having read the mesh and the first setup stage build the connectivities and mesh quantities rel...
Definition: cs_domain_setup.c:500
void cs_domain_set_output_param(cs_domain_t *domain, int nt_interval, int nt_list, int verbosity)
Set to true the automatic update of all advection fields.
Definition: cs_domain_setup.c:282
void cs_domain_set_time_param(cs_domain_t *domain, int nt_max, double t_max)
Set parameters for unsteady computations: the max number of time steps or the final physical time of ...
Definition: cs_domain_setup.c:309
void cs_domain_automatic_time_step_settings(cs_domain_t *domain)
Set time step parameters for unsteady computations when this is not already done. This situation shou...
Definition: cs_domain_setup.c:334
void cs_domain_def_time_step_by_function(cs_domain_t *domain, cs_time_func_t *func, void *func_input)
Define the value of the time step thanks to a predefined function.
Definition: cs_domain_setup.c:366
Definition: cs_domain.h:87
void cs_domain_finalize_setup(cs_domain_t *domain)
Last setup stage of the cs_domain_t structure.
Definition: cs_domain_setup.c:577
void() cs_time_func_t(int time_iter, double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the number of iteration already done...
Definition: cs_param.h:88
Definition: cs_defs.h:468
void cs_domain_initialize_systems(cs_domain_t *domain)
Initialize systems of equations and their related field values according to the user settings...
Definition: cs_domain_setup.c:660
void cs_domain_initialize_setup(cs_domain_t *domain)
First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equati...
Definition: cs_domain_setup.c:444
void cs_domain_setup_log(const cs_domain_t *domain)
Summary of the main domain settings.
Definition: cs_domain_setup.c:701
