| typedef void() | cs_cdo_time_scheme_t(const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply the time discretization to a local system. More... | |
| cs_cdo_time_scheme_t * | cs_cdo_time_get_scheme_function (const cs_flag_t sys_flag, const cs_equation_param_t *eqp) |
| Retrieve a pointer to the associated cs_matrix_structure_t according to the space scheme. More... | |
| void | cs_cdo_time_update_rhs (const cs_equation_param_t *eqp, int stride, cs_lnum_t n_dofs, const cs_lnum_t *dof_ids, const cs_real_t *values, cs_real_t *rhs) |
| Update the RHS with the previously computed array of values Do not use OpenMP inside this function since it may be called from an OpenMP block. More... | |
| void | cs_cdo_time_diag_imp (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system an implicit time discretization when a CDO scheme is used and the mass matrix related to the time discretization is diagonal (lumping or Voronoi Hodge) More... | |
| void | cs_cdo_time_imp (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system an implicit time discretization when a CDO scheme is used. More... | |
| void | cs_cdo_time_diag_exp (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system an explicit time discretization when a CDO scheme is used and the mass matrix related to the time discretization is diagonal (lumping or Voronoi Hodge) More... | |
| void | cs_cdo_time_exp (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system an explicit time discretization when a CDO scheme is used. More... | |
| void | cs_cdo_time_diag_theta (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system a "theta" time discretization when a CDO scheme is used and the mass matrix related to the time discretization is diagonal (lumping or Voronoi Hodge) More... | |
| void | cs_cdo_time_theta (const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Apply to the local system a "theta" time discretization when a CDO scheme is used. More... | |
| typedef void() cs_cdo_time_scheme_t(const cs_equation_param_t *eqp, const double tpty_val, const cs_sdm_t *mass_mat, const cs_flag_t system_flag, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| [in] | eqp | pointer to a cs_equation_param_t |
| [in] | tpty_val | current value of the time property |
| [in] | system_flag | indicate what is needed to build the system |
| [in] | mass_mat | pointer to a discrete Hodge op. |
| [in,out] | csys | pointer to a cs_sdm_t structure |
| void cs_cdo_time_diag_exp | ( | const cs_equation_param_t * | eqp, |
| const double | tpty_val, | ||
| const cs_sdm_t * | mass_mat, | ||
| const cs_flag_t | system_flag, | ||
| cs_cell_sys_t * | csys | ||
| void cs_cdo_time_diag_imp | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_time_diag_theta | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_time_exp | ( | const cs_equation_param_t * | eqp, |
| cs_cdo_time_scheme_t* cs_cdo_time_get_scheme_function | ( | const cs_flag_t | sys_flag, |
| const cs_equation_param_t * | eqp | ||
| [in] | sys_flag | metadata about how is set the algebraic system |
| void cs_cdo_time_imp | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_time_theta | ( | const cs_equation_param_t * | eqp, |
| void cs_cdo_time_update_rhs | ( | const cs_equation_param_t * | eqp, |
| int | stride, | ||
| cs_lnum_t | n_dofs, | ||
| const cs_lnum_t * | dof_ids, | ||
| const cs_real_t * | values, | ||
| cs_real_t * | rhs | ||
| [in] | stride | number of entries for each DoF |
| [in] | n_dofs | number of DoF to deal with |
| [in] | dof_ids | list of DoF ids or NULL if no indirection |
| [in] | values | array of values |
| [in,out] | rhs | right-hand side to update |
