1 #ifndef __CS_NAVSTO_SYSTEM_H__ 2 #define __CS_NAVSTO_SYSTEM_H__ 129 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:51
cs_boundary_type_t
Definition: cs_boundary.h:51
cs_navsto_free_scheme_context_t * free_scheme_context
Definition: cs_navsto_system.h:222
bool cs_navsto_system_is_activated(void)
Check if the resolution of the Navier-Stokes system has been activated.
Definition: cs_navsto_system.c:166
Definition: cs_advection_field.h:149
void cs_navsto_system_set_sles(void)
Define the settings for SLES related to the Navier-Stokes system.
Definition: cs_navsto_system.c:511
cs_navsto_param_coupling_t
Definition: cs_navsto_param.h:238
Definition: cs_field.h:124
void *() cs_navsto_free_scheme_context_t(void *scheme_context)
Free the context structure related to a given discretization scheme for the resolution of the Navier-...
Definition: cs_navsto_system.h:93
void cs_navsto_system_finalize_setup(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Last step of the setup of the Navier-Stokes system.
Definition: cs_navsto_system.c:567
cs_navsto_compute_t * compute_steady
Definition: cs_navsto_system.h:240
Definition: cs_defs.h:467
void cs_navsto_system_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step)
Build, solve and update the Navier-Stokes system in case of a steady-state approach.
Definition: cs_navsto_system.c:898
cs_equation_t * cs_navsto_system_get_momentum_eq(void)
Retrieve a pointer to the equation related to the momentum equation.
Definition: cs_navsto_system.c:361
void *() cs_navsto_init_scheme_context_t(const cs_navsto_param_t *nsp, cs_boundary_type_t *fb_type, void *nscc)
Allocate and initialize the context structure related to a given discretization scheme for the resolu...
Definition: cs_navsto_system.h:76
cs_navsto_init_values_t * init_velocity
Definition: cs_navsto_system.h:228
cs_field_t * temperature
Definition: cs_navsto_system.h:189
Definition: cs_cdo_connect.h:74
Structure storing information related to the "physical" boundaries that one want to set on the comput...
Definition: cs_boundary.h:77
void() cs_navsto_compute_t(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Compute for the current time step the new state for the Navier-Stokes system. This means that equatio...
Definition: cs_navsto_system.h:127
Definition: cs_navsto_param.h:255
Definition: cs_cdo_quantities.h:94
void * scheme_context
Definition: cs_navsto_system.h:202
void cs_navsto_system_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the Navier-Stokes system. The prototype of this function is fix...
Definition: cs_navsto_system.c:1013
cs_field_t * velocity
Definition: cs_navsto_system.h:169
cs_navsto_param_time_state_t
Status of the time for the Navier-Stokes system of equations.
Definition: cs_navsto_param.h:204
cs_navsto_init_scheme_context_t * init_scheme_context
Definition: cs_navsto_system.h:215
cs_navsto_param_t * cs_navsto_system_get_param(void)
Retrieve the structure storing the parameters for the Navier–Stokes system.
Definition: cs_navsto_system.c:342
cs_navsto_init_values_t * init_pressure
Definition: cs_navsto_system.h:234
cs_field_t * pressure
Definition: cs_navsto_system.h:182
Structure managing the Navier-Stokes system.
Definition: cs_navsto_system.h:140
cs_navsto_system_t * cs_navsto_system_activate(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_time_state_t time_state, cs_navsto_param_coupling_t algo_coupling)
Allocate and initialize the Navier-Stokes (NS) system.
Definition: cs_navsto_system.c:188
void() cs_navsto_init_values_t(const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *field)
According to the model, coupling algorithm and the space discretization, initialize the field values ...
Definition: cs_navsto_system.h:109
cs_boundary_type_t * bf_type
Definition: cs_navsto_system.h:150
cs_navsto_param_t * param
Definition: cs_navsto_system.h:145
void cs_navsto_system_initialize(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Initialize the context structure used to build the algebraic system This is done after the setup step...
Definition: cs_navsto_system.c:798
Definition: cs_defs.h:298
Definition: cs_navsto_system.h:246
void cs_navsto_system_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Predefined extra-operations for the Navier-Stokes system.
Definition: cs_navsto_system.c:965
Definition: cs_defs.h:468
cs_adv_field_t * adv_field
Definition: cs_navsto_system.h:163
void cs_navsto_system_compute(const cs_mesh_t *mesh, const cs_time_step_t *time_step)
Build, solve and update the Navier-Stokes system.
Definition: cs_navsto_system.c:932
void cs_navsto_system_log_setup(void)
Summary of the main cs_navsto_system_t structure.
Definition: cs_navsto_system.c:1100
void cs_navsto_system_init_setup(void)
Start setting-up the Navier-Stokes system At this stage, numerical settings should be completely dete...
Definition: cs_navsto_system.c:407
Modelling related to the Navier-Stokes system of equations.
Definition: cs_navsto_param.h:69
void * coupling_context
Definition: cs_navsto_system.h:195
void cs_navsto_system_destroy(void)
Free the main structure related to the Navier-Stokes system.
Definition: cs_navsto_system.c:275
cs_field_t * velocity_divergence
Definition: cs_navsto_system.h:176
