Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
#include <cs_navsto_param.h>
Data Fields | |
| int | verbosity |
Algorithm properties | |
Set of properties: properties and their related fields are allocated according to the choice of model for Navier-Stokes | |
| cs_param_dof_reduction_t | dof_reduction_mode |
| cs_param_time_scheme_t | time_scheme |
| cs_real_t | theta |
| cs_param_space_scheme_t | space_scheme |
| cs_navsto_param_model_t | model |
| bool | has_gravity |
| cs_real_3_t | gravity |
| cs_navsto_param_time_state_t | time_state |
| cs_navsto_param_sles_t | sles_strategy |
| cs_navsto_param_coupling_t | coupling |
| cs_real_t | gd_scale_coef |
| cs_quadrature_type_t | qtype |
| cs_real_t | residual_tolerance |
| int | max_algo_iter |
| cs_param_advection_form_t | adv_form |
| cs_param_advection_scheme_t | adv_scheme |
Physical properties | |
| cs_property_t * | density |
| cs_property_t * | lami_viscosity |
Initial conditions (IC) | |
Set of parameters used to take into account the initial condition on the pressure and/or the velocity. CAUTION: so far, there is no check if the different IC are compatible with the boundary conditions for instance | |
| bool | velocity_ic_is_owner |
| int | n_velocity_ic_defs |
| cs_xdef_t ** | velocity_ic_defs |
| bool | pressure_ic_is_owner |
| int | n_pressure_ic_defs |
| cs_xdef_t ** | pressure_ic_defs |
Boundary conditions (BC) | |
Set of parameters used to take into account the boundary conditions on the pressure and/or the velocity. | |
| const cs_boundary_t * | boundaries |
| bool | velocity_bc_is_owner |
| int | n_velocity_bc_defs |
| cs_xdef_t ** | velocity_bc_defs |
| bool | pressure_bc_is_owner |
| int | n_pressure_bc_defs |
| cs_xdef_t ** | pressure_bc_defs |
| adv_form |
Type of formulation for the advection term
| adv_scheme |
Type of scheme for the advection term
| const cs_boundary_t* boundaries |
| coupling |
Choice of algorithm for solving the system
| density |
Density of the fluid, pointer to cs_property_t used in several terms in the Navier-Stokes equations
How are defined the Degrees of freedom
| gd_scale_coef |
Default value to set the scaling of the grad-div term when an artificial compressibility algorithm or an Uzawa-Augmented Lagrangian method is used
| gravity |
Vector related to the gravity effect
| has_gravity |
Take into account the gravity effect: true or false
| lami_viscosity |
Laminar viscosity, pointer to cs_property_t associated to the diffusion term for the momentum equation
| max_algo_iter |
Maximal number of iteration of the coupling algorithm. Not useful for a monolithic approach. In this case, only the maximal number of iterations for the iterative solver is taken into account
| model |
Modelling related to the Navier-Stokes system of equations
Number of boundary conditions associated to the pressure field.
Number of initial conditions associated to the pressure
Number of definitions related to the settings of the boundary conditions for the velocity field.
Number of initial conditions associated to the velocity
| pressure_bc_defs |
Pointers to the definitions of the boundary conditions associated to the pressure field.
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t if an equation solves the pressure field.
| pressure_ic_defs |
Pointers to the definitions of the initial conditions associated to the pressure. In order to force a zero-mean pressure, the code can compute the average of the resulting pressure and subtract it
| qtype |
A cs_quadrature_type_t indicating the type of quadrature to use in all routines involving quadratures
Tolerance at which the Navier–Stokes is resolved (apply to the residual of the coupling algorithm chosen to solve the Navier–Stokes system)
| sles_strategy |
Choice of strategy for solving the SLES system
| space_scheme |
Discretization scheme for space
| theta |
Value of the parameter for the time scheme when a theta-scheme is used
| time_scheme |
Discretization scheme for time
| time_state |
Status of the time for the Navier-Stokes system of equations
| velocity_bc_defs |
Array of pointers to the definition of boundary conditions for the velocity field
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t Most of the time this should be false since an equation is associated to to the resolution of the velocity field (the momentum equation).
| velocity_ic_defs |
Pointers to the definitions of the initial conditions associated to the velocity. The code does not check if the resulting initial velocity satisfies the divergence constraint.
True if the definitions are stored inside this structure, otherwise the definitions are stored inside the a cs_equation_param_t structure dedicated to the momentum equation.
| verbosity |
Level of display of the information related to the Navier-Stokes system
