1 #ifndef __CS_CDOFB_UZAWA_H__ 2 #define __CS_CDOFB_UZAWA_H__ 161 void *scheme_context);
177 void *scheme_context);
193 void *scheme_context);
210 void *scheme_context);
void * cs_cdofb_uzawa_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_uzawa_t structure.
Definition: cs_cdofb_uzawa.c:1113
void cs_cdofb_uzawa_compute_implicit(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Uzawa-Lagrangian Augment...
Definition: cs_cdofb_uzawa.c:1640
time step descriptor
Definition: cs_time_step.h:51
cs_boundary_type_t
Definition: cs_boundary.h:51
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns...
Definition: cs_equation.c:2361
void cs_cdofb_uzawa_set_sles(const cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when an ALU algorithm is used to couple the system...
Definition: cs_cdofb_uzawa.c:1141
Definition: cs_defs.h:467
#define CS_UNUSED(x)
Definition: cs_defs.h:453
void cs_cdofb_uzawa_init_common(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_uzawa.c:988
Definition: cs_cdo_connect.h:74
Definition: cs_navsto_param.h:255
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
void cs_cdofb_uzawa_compute_steady(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a Uzawa-Lagrangian Augmented...
Definition: cs_cdofb_uzawa.c:1196
Definition: cs_defs.h:468
void cs_cdofb_uzawa_compute_steady_rebuild(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_uzawa.c:2617
void * cs_cdofb_uzawa_init_scheme_context(const cs_navsto_param_t *nsp, cs_boundary_type_t *fb_type, void *nsc_input)
Initialize a cs_cdofb_uzawa_t structure.
Definition: cs_cdofb_uzawa.c:1016
static cs_real_t * cs_cdofb_uzawa_get_face_velocity(void *scheme_context)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_uzawa.h:76
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:350
void cs_cdofb_uzawa_compute_theta(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_uzawa.c:2105
