#include "cs_defs.h"#include "cs_base.h"#include "cs_cdo_connect.h"#include "cs_cdo_quantities.h"#include "cs_equation_common.h"#include "cs_equation_param.h"#include "cs_field.h"#include "cs_matrix.h"#include "cs_mesh.h"#include "cs_restart.h"#include "cs_sles.h"#include "cs_source_term.h"#include "cs_time_step.h"
| bool | cs_cdofb_vecteq_is_initialized (void) |
| Check if the generic structures for building a CDO-Fb scheme are allocated. More... | |
| void | cs_cdofb_vecteq_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms) |
| Allocate work buffer and general structures related to CDO vector-valued face-based schemes. Set shared pointers from the main domain members. More... | |
| const cs_matrix_structure_t * | cs_cdofb_vecteq_matrix_structure (void) |
| Get the pointer to the related cs_matrix_structure_t. More... | |
| void | cs_cdofb_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
| void | cs_cdofb_vecteq_finalize_common (void) |
| Free work buffer and general structure related to CDO face-based schemes. More... | |
| void * | cs_cdofb_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
| Initialize a cs_cdofb_vecteq_t structure storing data useful for building and managing such a scheme. More... | |
| void * | cs_cdofb_vecteq_free_context (void *data) |
| Destroy a cs_cdofb_vecteq_t structure. More... | |
| void | cs_cdofb_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued CDO-Fb schemes. More... | |
| void | cs_cdofb_vecteq_init_cell_system (const cs_flag_t cell_flag, const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdofb_vecteq_t *eqc, const cs_real_t dir_values[], const cs_real_t field_tn[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Initialize the local structure for the current cell. More... | |
| void | cs_cdofb_vecteq_setup_bc (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, cs_real_t *p_dir_values[]) |
| Set the boundary conditions known from the settings. More... | |
| void | cs_cdofb_vecteq_diffusion (double time_eval, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdofb_vecteq_t *eqc, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Build the local matrices arising from the diffusion, advection, reaction terms in CDO-Fb schemes. More... | |
| void | cs_cdofb_vecteq_advection_diffusion (double time_eval, const cs_equation_param_t *eqp, const cs_cdofb_vecteq_t *eqc, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| static void | cs_cdofb_vecteq_sourceterm (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_real_t t_eval, const cs_real_t coef, cs_cell_builder_t *cb, cs_equation_builder_t *eqb, cs_cell_sys_t *csys) |
| Compute the term source for a vector-valued CDO-Fb scheme and add it to the local rhs. More... | |
| int | cs_cdofb_vecteq_solve_system (cs_sles_t *sles, const cs_matrix_t *matrix, const cs_equation_param_t *eqp, cs_real_t *x, cs_real_t *b) |
| Solve a linear system arising from a scalar-valued CDO-Fb scheme. More... | |
| static void | cs_cdofb_vecteq_assembly (const cs_cell_sys_t *csys, const cs_range_set_t *rs, const cs_cell_mesh_t *cm, const bool has_sourceterm, cs_cdofb_vecteq_t *eqc, cs_equation_assemble_t *eqa, cs_matrix_assembler_values_t *mav, cs_real_t rhs[]) |
| Perform the assembly stage for a vector-valued system obtained with CDO-Fb scheme. More... | |
| void | cs_cdofb_vecteq_solve_steady_state (const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a vector steady-state diffusion equation with a CDO-Fb scheme One works cellwise and then process to the assembly. More... | |
| void | cs_cdofb_vecteq_solve_implicit (const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a vector diffusion equation with a CDO-Fb scheme and an implicit Euler scheme. One works cellwise and then process to the assembly. More... | |
| void | cs_cdofb_vecteq_solve_theta (const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a vector diffusion equation with a CDO-Fb scheme and an implicit/explicit theta scheme. One works cellwise and then process to the assembly. More... | |
| void | cs_cdofb_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val) |
| Store solution(s) of the linear system into a field structure Update extra-field values if required (for hybrid discretization) More... | |
| void | cs_cdofb_vecteq_extra_op (const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data) |
| cs_real_t * | cs_cdofb_vecteq_get_cell_values (void *context) |
| Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF used in the linear system are located at primal faces) The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| cs_real_t * | cs_cdofb_vecteq_get_face_values (void *context) |
| Retrieve an array of values at mesh faces for the current context. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| void | cs_cdofb_vecteq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void | cs_cdofb_vecteq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void cs_cdofb_vecteq_advection_diffusion | ( | double | time_eval, |
| const cs_cdofb_vecteq_t * | eqc, | ||
| [in] | time_eval | time at which analytic function are evaluated |
inlinestatic |
| [in] | rs | pointer to a cs_range_set_t structure |
| [in] | has_sourceterm | has the equation a source term? |
| [in,out] | eqc | context structure for a vector-valued Fb |
| [in,out] | eqa | pointer to cs_equation_assemble_t |
| [in,out] | mav | pointer to cs_matrix_assembler_values_t |
| [in,out] | rhs | right-end side of the system |
| void cs_cdofb_vecteq_diffusion | ( | double | time_eval, |
| cs_face_mesh_t * | fm, | ||
| [in,out] | fm | pointer to a facewise view of the mesh |
| void cs_cdofb_vecteq_extra_op | ( | const char * | eqname, |
| void * | data | ||
| [in,out] | data | pointer to cs_cdofb_vecteq_t structure |
| void cs_cdofb_vecteq_finalize_common | ( | void | ) |
| void* cs_cdofb_vecteq_free_context | ( | void * | data | ) |
| [in,out] | data | pointer to a cs_cdofb_vecteq_t structure |
| void cs_cdofb_vecteq_get | ( | cs_cell_sys_t ** | csys, |
| cs_real_t* cs_cdofb_vecteq_get_cell_values | ( | void * | context | ) |
| cs_real_t* cs_cdofb_vecteq_get_face_values | ( | void * | context | ) |
| void cs_cdofb_vecteq_init_cell_system | ( | const cs_flag_t | cell_flag, |
| const cs_real_t | dir_values[], | ||
| const cs_real_t | field_tn[], | ||
| cs_real_t | t_eval, | ||
| [in] | cell_flag | flag related to the current cell |
| [in] | eqc | pointer to a cs_cdofb_vecteq_t structure |
| [in] | dir_values | Dirichlet values associated to each face |
| [in] | field_tn | values of the field at the last computed time |
| void cs_cdofb_vecteq_init_common | ( | const cs_cdo_quantities_t * | quant, |
| void* cs_cdofb_vecteq_init_context | ( | const cs_equation_param_t * | eqp, |
| int | var_id, | ||
| int | bflux_id, | ||
| void cs_cdofb_vecteq_init_values | ( | cs_real_t | t_eval, |
| const int | field_id, | ||
| void * | context | ||
| bool cs_cdofb_vecteq_is_initialized | ( | void | ) |
| const cs_matrix_structure_t* cs_cdofb_vecteq_matrix_structure | ( | void | ) |
| void cs_cdofb_vecteq_read_restart | ( | cs_restart_t * | restart, |
| const char * | eqname, | ||
| void cs_cdofb_vecteq_setup_bc | ( | cs_real_t | t_eval, |
| cs_real_t * | p_dir_values[] | ||
| [in,out] | p_dir_values | pointer to the Dirichlet values to set |
DOXYGEN_SHOULD_SKIP_THIS
| void cs_cdofb_vecteq_solve_implicit | ( | const cs_mesh_t * | mesh, |
| [in,out] | context | pointer to cs_cdofb_vecteq_t structure |
| void cs_cdofb_vecteq_solve_steady_state | ( | const cs_mesh_t * | mesh, |
| int cs_cdofb_vecteq_solve_system | ( | cs_sles_t * | sles, |
| const cs_matrix_t * | matrix, | ||
| cs_real_t * | x, | ||
| cs_real_t * | b | ||
| [in,out] | sles | pointer to a cs_sles_t structure |
| [in] | matrix | pointer to a cs_matrix_t structure |
| [in,out] | x | solution of the linear system (in: initial guess) |
| [in,out] | b | right-hand side (scatter/gather if needed) |
| void cs_cdofb_vecteq_solve_theta | ( | const cs_mesh_t * | mesh, |
inlinestatic |
| [in] | t_eval | time at which the term source is evaluated |
| [in] | coef | scaling of the time source (for theta schemes) |
| void cs_cdofb_vecteq_update_field | ( | const cs_real_t * | solu, |
| void * | data, | ||
| void cs_cdofb_vecteq_write_restart | ( | cs_restart_t * | restart, |
