80 #define CS_GWF_GRAVITATION (1 << 0) 81 #define CS_GWF_FORCE_RICHARDS_ITERATIONS (1 << 1) 82 #define CS_GWF_RESCALE_HEAD_TO_ZERO_MEAN_VALUE (1 << 2) 83 #define CS_GWF_ENFORCE_DIVERGENCE_FREE (1 << 3) 84 #define CS_GWF_RICHARDS_UNSTEADY (1 << 4) 85 #define CS_GWF_SOIL_PROPERTY_UNSTEADY (1 << 5) 86 #define CS_GWF_SOIL_ALL_SATURATED (1 << 6) 117 #define CS_GWF_POST_CAPACITY (1 << 0) 118 #define CS_GWF_POST_MOISTURE (1 << 1) 119 #define CS_GWF_POST_PERMEABILITY (1 << 2) 120 #define CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) 121 #define CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) 122 #define CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) 130 typedef struct _gwf_t cs_gwf_t;
233 const char *var_name);
254 const char *var_name,
void cs_gwf_init_setup(void)
Predefined settings for the Richards equation and the related equations defining the groundwater flow...
Definition: cs_gwf.c:974
time step descriptor
Definition: cs_time_step.h:51
void cs_gwf_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Predefined extra-operations for the groundwater flow module.
Definition: cs_gwf.c:1642
void cs_gwf_log_setup(void)
Summary of the main cs_gwf_t structure.
Definition: cs_gwf.c:701
void cs_gwf_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the steady-state of the groundwater flows module. Nothing is done if all equations are unstea...
Definition: cs_gwf.c:1400
cs_gwf_t * cs_gwf_activate(cs_property_type_t pty_type, cs_flag_t flag)
Initialize the module dedicated to groundwater flows.
Definition: cs_gwf.c:605
cs_property_type_t
Type of property to consider.
Definition: cs_property.h:93
Definition: cs_defs.h:467
cs_real_t cs_gwf_integrate_tracer(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
Compute the integral over a given set of cells of the field related to a tracer equation. This integral turns out to be exact for linear functions.
Definition: cs_gwf.c:1547
void() cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer)
Generic function to set the parameters related to a tracer equation.
Definition: cs_gwf_tracer.h:153
Definition: cs_cdo_connect.h:74
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
void cs_gwf_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Last initialization step of the groundwater flow module.
Definition: cs_gwf.c:1154
void cs_gwf_set_post_options(cs_flag_t post_flag)
Set the flag dedicated to the post-processing of the GWF module.
Definition: cs_gwf.c:779
bool cs_gwf_is_activated(void)
Check if the groundwater flow module has been activated.
Definition: cs_gwf.c:585
void cs_gwf_set_darcian_flux_location(cs_flag_t location_flag)
Advanced setting: indicate where the darcian flux is stored cs_flag_primal_cell is the default settin...
Definition: cs_gwf.c:826
void cs_gwf_compute(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the system related to groundwater flows module.
Definition: cs_gwf.c:1471
void cs_gwf_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev)
Update the groundwater system (pressure head, head in law, moisture content, darcian velocity...
Definition: cs_gwf.c:1307
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
Definition: cs_defs.h:298
cs_gwf_tracer_t * cs_gwf_add_tracer_user(const char *eq_name, const char *var_name, cs_gwf_tracer_setup_t *setup, cs_gwf_tracer_add_terms_t *add_terms)
Add a new equation related to the groundwater flow module This equation is a particular type of unste...
Definition: cs_gwf.c:903
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
void cs_gwf_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the groundwater flow module prototype of this function is fixed...
Definition: cs_gwf.c:1788
void cs_gwf_set_gravity_vector(const cs_real_3_t gvec)
Activate the gravity and set the gravitaty vector.
Definition: cs_gwf.c:801
void cs_gwf_add_tracer_terms(void)
Add new terms if needed (such as diffusion or reaction) to tracer equations according to the settings...
Definition: cs_gwf.c:1126
cs_gwf_t * cs_gwf_destroy_all(void)
Free the main structure related to groundwater flows.
Definition: cs_gwf.c:662
Definition: cs_gwf_tracer.h:116
void() cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer)
Generic function to update the terms to build in the algebraic system for a tracer equation according...
Definition: cs_gwf_tracer.h:167
cs_gwf_tracer_t * cs_gwf_add_tracer(const char *eq_name, const char *var_name)
Definition: cs_gwf.c:857
cs_gwf_tracer_t * cs_gwf_tracer_by_name(const char *eq_name)
Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter...
Definition: cs_gwf.c:946
